02-19-2019, 09:04 PM | #1 |
Need some advice
I need some help guys, so I have suddenly run into an issue where my 69 C10 will be my daily driver. So I have a budget of 10k to put a new motor and transmission, new tires, and new brakes(disc up front). Can some one recommend a shop in OKC area, and let me know if my budget is reasonable? I have not purchased anything for it yet, and this build will be mild, I would like reliability and driveability to be the main focus. I would prefer to swap the transmission to a manual. It currently has a sbc 350 and turbo 400 in it. I am not averse to the idea of a rebuild but would like other options as well. I don't have the space or knowledge to do most of this so I will be relying on a shop. I know that affects the budget but it can't be helped. I appreciate any and all help or advice.
Mike
Mike P. PO2 (USN) 1969 C10- 350 sbc, th-400, (alternate driver) 2017 Dodge Grand Caravan |
02-19-2019, 09:14 PM | #2 |
Re: Need some advice
Btw, how do you edit the signature?
02-19-2019, 09:35 PM | #3 |
Go to User CP in the blue bar at the top of the page. Click on Edit Signature on the left.
As far as your budget, are you willing to learn to do any of the work yourself? At roughly $100/hr labor is going to eat into your budget pretty quickly. If the transmission works well, I would leave it for now. It may be fun to change them yourself, but that TH400 is a very dependable transmission and it would help your budget considerably to leave it there. There's a lot of labor involved in the swap. Really, the place to start would be an honest assessment of what you have now. If the engine runs well, why replace it? Tires, brakes, steering, and lights are safety items, so they should go to the top of the list.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 02-19-2019 at 09:40 PM. |
02-19-2019, 09:52 PM | #4 |
The transmission is starting to slip, and the motor isn't running properly. It was installed about 30 years ago and needs either rebuilt or replaced. I am not averse to getting them repaired but I want reliability and peace of mind. I wouldn't mind learning to do it, but I am hesitant to screw up and cost myself money through avoidable errors.
02-19-2019, 10:02 PM | #5 |
This is probably not what you want to hear, and I promise I'm not trying to be a jerk, but consider this:
Spend 5k on a reliable vehicle from craigslist. Spend the other 5k on making your old truck your fun toy. This way, you don't have to worry about downtime while working on a truck that is also needed as a Daily Driver.
1967 C-10 4-speed, 350v8 |
02-19-2019, 10:28 PM | #6 | |
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-19-2019, 11:38 PM | #7 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-21-2019, 04:22 PM | #8 | |
Less stress and more enjoyment getting the truck squared away. IF you decide on transmission work, there's a shop in Del City that does good work, owner is Tommy - DC Transmissions. He is not inexpensive (if anyone is) but he does good work and will make sure everything is right.
'68 GMC 3/4 Ton 350, 700R4 |
02-23-2019, 02:59 PM | #9 |
I echo the advice of getting a reliable daily driver and leaving the truck as more of a toy. I recently did the same spending $3000 on a 2001 Accord with 100k on it. It was always garaged so it’s in nice shape and had lots of work done fairly recently like timing belt and tires so I won’t have to spend any $ (knock on wood) for awhile and I should get another 100k with minimal investment. There are these kinds of cars out there. Plus, while the girlfriend is happy to ride in the truck, there are times she’d rather be in the boring but more comfortable sedan.
As for the truck. You could get a reliable truck for your budget depending on the route you go. What’s wrong with the engine exactly? Not running right sounds like an issue that could be resolved by tuning, maybe new carb or other parts instead of completely rebuilding or replacing. If the engine isn’t smoking or rattling itself to death you could just replace carb, replace distributor, timing gear set, cam, fuel pump (eliminating all the usual causes of reliability issues), have the trans rebuilt and have brake system completely overhauled with front disks for about $5000. That’s if you buy the engine and brake parts and take them to a shop for installation to avoid the shop marking them up. So it’s actually feasible to buy a daily driver and make your truck completely reliable within your budget. |
02-23-2019, 03:38 PM | #10 |
Doing as much of the leg work as possible will help keep costs under control. Obtaining all the parts for the conversion to manual will be really costly if you have it hired out, not to mention the cost of cleaning them up. With no space to work on the truck or store a parts truck you are at the mercy of whom ever you hire.
My suggestion would be to take your 10k and buy the best $8000 truck that is outfitted how you want it leaving $2000 to chang out consumable parts like water pump, alternator, radiator, fuel pump, have the carburetor rebuilt. And of course your current truck would be sellable to contribute to the fund. Going this route gets you on the road sooner and avoids the possibility of your truck disappearing into repair shop hell.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
