02-25-2019, 07:31 PM | #1 |
why the difference
found these two why did they make 2 and which came first.
02-25-2019, 08:32 PM | #2 |
Re: why the difference
From what I've been told the solid one was the 1st design and they went with the multi-piece one to help dampen vibrations through the shifter and give it a bit of a buffer from people being too forceful with shifts and munching gears.
02-25-2019, 09:27 PM | #3 |
ok. i was thinking they had a casting defect and this how they solved it in house...
02-25-2019, 09:38 PM | #4 |
Great timing on this question, I was just wondering the same thing. Are both of these styles correct for the SM420? Anybody know if the change was made by date or application (C10 vs C30 or K vs C truck etc).
Any chance of a picture showing the entire sticks side by side? Thanks for info Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
02-25-2019, 09:50 PM | #5 | |
02-26-2019, 06:44 AM | #6 |
Check The Champ, Demonstrator
Seems to be something going on for 1965.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
02-26-2019, 06:54 AM | #7 |
Took a picture course it doesn't load. Parts Book states first jobs 1 piece construction less sleeve. After jobs welded construction with sleeve.
part number 3665527 60-62. 3822568 63-64 Same part number as 63-64 for first jobs 65 3860941 65 After Jobs There are illustrations for a 60-62 4spd transmission and also 63-66. So there must be a difference as well between the two.
02-26-2019, 11:23 AM | #8 |
There is actually another later version during the square body era.
The sleeve version shown here has a square feature that fits in the base with rubber molded between the two. A later version is round internally and has 2 “O” rings to provide the isolation. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-27-2019, 01:55 AM | #9 |
Yes,
More pictures by you or anybody else would be great, Thanks
02-27-2019, 07:22 AM | #10 |
here u go
02-27-2019, 07:23 AM | #11 |
03-11-2019, 10:50 PM | #12 |
I'm trying to figure out what I have in my pile 'o parts.
My two solid sticks are identical, but the multi-piece one is thicker and about 6" shorter, plus the bend is closer to the base. Would this be correct for a 65? Are the transmission towers different depending on which stick it came with, or are they all interchangeable? Finally has anybody replaced the rubber within the lower end? Factory manual refers to them as 'Polyurethane "O" rings'. Where would you get the correct part? Thanks, Tom
03-12-2019, 12:59 AM | #13 | |
03-12-2019, 02:39 AM | #14 | |
Novak sells the solid one and says this as title "Stick, shifter cane, SM420 & SM465 transmissions, upgraded one-piece version" Last edited by 350TacoZilla; 03-12-2019 at 02:45 AM. |
