Old 03-13-2019, 08:46 AM   #1
NewBayColony
NewBayColony's Avatar
Is There a Non Sincro 1st gear 3 Spd in a 67/68
Does anyone have/had a 67 or a 68 3 speed with a non syncro first gear. I thought they were all syncro after 66 but I have read in trucks the base trans up to 68 was a CS10 Syncromesh 3 speed and the next option up the list was a CE10 FULLY SYNCRONIZED. GM's description and wording. In the 69 option list, the only 3 speed is the fully syncronized one. I am looking for the linkage from the column to the transmission for the NON syncro transmission in another thread and I need to know if they even made them. Thanks.
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 03-13-2019, 09:02 AM   #2
Jcab256
Re: Is There a Non Sincro 1st gear 3 Spd in a 67/68
Yes, my Dad had a 68 c10 like that when I was growing up, that I believe was original
Jcab
1972 GMC Camper Special 402 Big Block
Jcab256 is offline   Reply With Quote
Old 03-13-2019, 12:32 PM   #3
Husker
Husker's Avatar
My 68 3 speed is non synchronized.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-13-2019, 01:05 PM   #4
weim55
I don't claim to be an expert on the subject but this is what I've experienced in 30+ years of hands on with these trucks. Never seen a 4 bolt side cover non synchro 1st column shift 3speed in any C series '66 and up, 6 or V8. I looked over at the GM heritage site for transmission lineup for '67. Shows what you found: base 6 cylinder 3 speed C10 uses a different ' synchromesh ' then all of the other C 10-30 series. The description of the three speeds available is very vague. They show a single picture to represent all of the three speeds available and it happens to be the older 4 bolt Muncie pictured (?!) Makes no sense at all (?)
I own a very typical almost zero option '67 C10 with the base 250 6cylinder and three speed on the column. My truck has the Warner (NOT a Saginaw NOT a 4 bolt Muncie) three speed column shift that I believe has an 8 bolt side cover and does not have a synchronized first gear. Everything about this truck looks completely original and unmolested. I'll try to get some pictures of this if I'm at the house this weekend.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 03-13-2019, 10:33 PM   #5
zicc1835
zicc1835's Avatar
No synchros in the 67 3 speed I have sitting in the shed for years
zicc1835 is offline   Reply With Quote
Old 03-14-2019, 09:05 AM   #6
NewBayColony
Ron
Thanks for the come back Husker. Any way of getting a picture of your side cover on the transmission or at least seeing if it's got 4 bolts? Thanks.
72 C20 292 3OTT
Old 03-14-2019, 09:06 AM   #7
NewBayColony
Thanks Steve.
72 C20 292 3OTT
Old 03-14-2019, 09:10 AM   #8
NewBayColony
Thanks for the come back,too. Again, can you look and see if the side cover has 4 bolts? I want to make sure I'm looking for something that exists .
72 C20 292 3OTT
Old 03-14-2019, 03:03 PM   #9
Husker
Husker's Avatar
Sure when I get home if I don't forget.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 03-14-2019, 03:49 PM   #10
jabborabbo
jabborabbo's Avatar
My ‘67 L6 GMC SPID shows SM318 for the tranny...1st gear is not synchronized....
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 03-14-2019, 07:41 PM   #11
factorystock
factorystock's Avatar
IMO, the old non synchro should have been put out to pasture immediately after the new full synchro came out. GM kept the old non synchro on base 6 cylinder pickups through '68, used the newer full synchro on optional engines during '66, '67 and '68. Finally in '69, all engines used the full synchro.
factorystock is offline   Reply With Quote
Old 03-15-2019, 09:49 AM   #12
NewBayColony
That should be the 4 bolt side cover. It's always referred to as an M18 or with an overdrive, M19. Thanks!!
72 C20 292 3OTT
Old 03-15-2019, 09:51 AM   #13
NewBayColony
I have the synchro 7 bolt in it now with the 4.57 rear end. I bought a M19 overdrive transmission to let me go on the highway and have a little more fun driving it. Now I just have to get the linkage for it.
72 C20 292 3OTT
Old 03-15-2019, 09:54 AM   #14
67ChevyRedneck
67ChevyRedneck's Avatar
So that's what my C10 had (the M18). I drove my 67 for the first 4/5 years with the I-6 and 3spd, and man did it suck not having a syncro 1st gear. I guess it taught me to come to a complete stop at stop signs...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-15-2019, 10:18 AM   #15
NewBayColony
After driving 7/8/9/10/13/18 speed completely nonsynco transmissions for 30 something years, having only one is not a big problem. I miss the rev matching.
72 C20 292 3OTT
Old 03-15-2019, 06:54 PM   #16
Husker
Husker's Avatar
Here is mine. I swapped to a 5 speed.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 03-17-2019, 11:00 AM   #17
NewBayColony
Ron
I have a friend who did that 5 speed swap. Now you know my next questions, Do you have the linkage for the 3 speed and if so, would you sell it and ship it? Thanks, Jeff
72 C20 292 3OTT
Old 03-17-2019, 01:22 PM   #18
CSTGURU
CSTGURU's Avatar
I know that in canada 1967 and 68 trucks had NON-syncro for sure. at least as base equip.
CSTGURU is offline   Reply With Quote
Old 03-17-2019, 03:41 PM   #19
weim55
Ron
What year truck is this out of?
Old 03-17-2019, 05:07 PM   #20
weim55
This is the original three speed in my '67 250 6 cylinder C10. It is a 9 Bolt Side cover Warner T89. Only second and third gear are synchronized. This transmission was the optional heavy duty three speed for most Chevrolet trucks 1955 through,I believe, 1966. Wondering if Chevrolet may have used these on the base six cylinder C10 in 1967 in 1968 (??). Wondering if GM had a stockpile of these transmissions they needed to use up and just got rid of them on the base trucks for those two model years (??) This particular truck did not come with an SPID for me to cross just in case there is a possibility there was an option for this as a HD 3 speed upgrade as in '55- '66.
Old 03-17-2019, 05:13 PM   #21
weim55
Warner T89
Old 03-17-2019, 05:16 PM   #22
NewBayColony
Warner T89
Thanks for that effort Steve. Another Transmission in the mix. I have seen "Heavy Duty" 3 speeds listed.
You still got real snow. Mine is on it's way out!
72 C20 292 3OTT
Old 03-17-2019, 06:12 PM   #23
Husker
Husker's Avatar
it is from a 68.
I will have to round up the shift linkage.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 03-17-2019, 06:48 PM   #24
NewBayColony
it is from a 68.
Ron
I'm sure that is exactly what I'm looking for so it would be greatly appreciated.
72 C20 292 3OTT
Old 03-18-2019, 12:32 PM   #25
weim55
it is from a 68.
Ron
1968 , Wow! Stunned GM still used this early box well past last use in passenger cars. Thanks why I love this site, learn something new all the time......
