03-19-2019, 10:01 PM | #1 |
Re: How to: Ruin a perfectly good C10
Just spent the last week going through this build thread and found myself writing down ideas to follow up on and parts to look into for a few of my builds.
Excellent work on all fronts Chris - you are doing top notch stuff! What shifter boot are you considering for the Muncie? I replaced the one in the 70 GMC Jimmy with a new one (Amazon cheapie) and it ripped after using it for driving in/out of the garage... I should have known. |
03-19-2019, 11:27 PM | #2 | |
A guy with a truck
As for the shift boot, the plan is for a factory (or re-pop, most likely) oval-shaped 4wd boot and trim ring, just keeping with the stock-ish theme. Hurst makes this handy little piece to adapt the flat handle to a round-ish boot hole: https://www.hurstshiftersonline.com/...ommet-p590.htm
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-19-2019 at 11:36 PM. |
03-19-2019, 11:48 PM | #3 |
A guy with a truck
Had some power steering hoses made-up at the local hydraulics shop yesterday. Quick turn, cheap, and fit nicely. The high-side snakes behind the tensioner bracket, while low side has a pretty much straight shot to the reservoir.
That allowed pressing-on of the pump pulley and then measuring for the serpentine belt. I’m happy to report that it only took two trips to the LAPS to get the right one Baby steps...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
