Old 05-03-2019, 06:38 PM   #801
SoCoC10
SoCoC10's Avatar
Re: What did you do to your Blazer/Jimmy today?
Drilled lots of holes in the replacement tailgate. Installed new trim and lenses. Getting there.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 05-03-2019, 07:44 PM   #802
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Where did you buy your tailgate band? Nice work and looking great.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-03-2019, 09:17 PM   #803
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice! Any issues with the trim clips backing out?
Old 05-03-2019, 11:29 PM   #804
SoCoC10
SoCoC10's Avatar
I got the tailgate band from Classic Parts. Honestly the one from LMC was a Trim Parts product and it was nicer.
I used original clips on the tailgate trim and the repop clips on the tail light trim. By gutting the tail lights you can get to back side the tail light trim clips. To get to the tailgate clips it's a PITA. No backing out yet but it been all of 8 hours.
Old 05-06-2019, 11:05 PM   #805
SoCoC10
SoCoC10's Avatar
Disassembled the cluster, cleaned, painted the needles and reassembled cluster in to a new housing. Body worked, primed and painted both inner fenders. Put the roll bar to use after painting the hood hinges, the grill supports and window washer bottle bracket.
Old 05-07-2019, 01:09 AM   #806
Chulisohombre
Chulisohombre's Avatar
Originally Posted by DeadheadNM View Post
Bummer! I’ve had to deal with little leaks because the tower clamps aren’t that good and noticed a few drips under the k20 - I’m hoping the heater core didn’t burst when temps dipped below minus 30. The coolant in the radiator wasn’t frozen so I’m hopeful. Heater core replacement is such a pita.
Yeah it had leaked before. The core connectors may just need to be brazed again once I get it out. But after almost 50 years, it’s probably toast. I’ve had the blazer for 20 of those with no issue with the core thus far.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 05-13-2019, 01:45 PM   #807
GMCNUT
GMCNUT's Avatar
Been working on my interior lately and after finishing with new door panels turned my attention to mounting the GM accessory 8 Track. Took more effort than I expected with gas pedal interference to overcome, but she's in there now and in the exact right location correctly reusing the left AC control screw as it should etc.
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 05-13-2019, 06:08 PM   #808
SoCoC10
SoCoC10's Avatar
I don't know about you but one of my favorite things to do is do the job I already paid someone to do. Only thing worse is doing the same job over and over again. Painted the roll bar and a few other odds and ends the paint shop neglected to paint.
Old 05-13-2019, 06:20 PM   #809
Ol Blue K20
But it looks good....
Dale
Old 05-13-2019, 06:26 PM   #810
72gmguy
72gmguy's Avatar
Isn't that a roll bar for a 73- newer? How does it fit in a first gen?
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 05-15-2019, 08:02 AM   #811
SoCoC10
SoCoC10's Avatar
Like a glove. In fact I replaced the complete rear raised floor of the Blazer with a rust free floor from another Blazer and it must have had the exact same roll bar in because all the mounting holes lined up. Must have been a common roll bar. I can tell you if it's a factory GM, Hickey or a dealer installed aftermarket? Maybe someone here knows?
Old 05-15-2019, 08:04 PM   #812
litebulblsc
litebulblsc's Avatar
I did this
litebulblsc is offline   Reply With Quote
Old 05-15-2019, 08:59 PM   #813
Ol Blue K20
Originally Posted by litebulblsc View Post
I did this
Goodness!!!!
Dale
Old 05-15-2019, 09:04 PM   #814
Chulisohombre
Wow. Not much left of the other one. That looks like a hickey rollbar to me. I’ve seen two versions though. One like yours and one where the leg bolts higher up in the middle of the wheelwell.
Old 05-15-2019, 09:17 PM   #815
1rippen6
That's a factory roll bar out of a 73 up, I had one in my 71 years ago.
Found a link
http://67-72chevytrucks.com/vboard/s...d.php?t=678355
1rippen6 is offline   Reply With Quote
Old 05-15-2019, 11:11 PM   #816
SoCoC10
SoCoC10's Avatar
New weatherstripping on the top and doors. Hottest day in 7 months and I put the top on. Just not right.
Old 05-17-2019, 07:46 AM   #817
lks dcvn
lks dcvn's Avatar
^ Looking good Troy! Agree - I'm hoping to get the top off one of my blazer projects in the next week.
lks dcvn is offline   Reply With Quote
Old 05-24-2019, 10:17 PM   #818
SoCoC10
SoCoC10's Avatar
Thanks! Made some more progress this week. Got the rear hatch painted, weatherstripped and installed. Made the final adjustment on the door latches by adding one more shim to both uppers on the latches. Fenders hung. Going to paint shop for touch up final cut and buff.
Old 05-28-2019, 12:33 PM   #819
duramaxguy
'72 K5 4x4. Steering got really loose the other day while rolling down the road. Inspection showed severely worn tie rod ends. Replaced all tie rod ends and pitman arm linkage. Also found severely worn ball joints on the driver side. Replaced those as well. All of the components were original equipment, so I think we got our money's worth out of that stuff. Off to the tire shop for alignment, but inital drive test indicated like-new steering behavior.
duramaxguy is offline   Reply With Quote
Old 05-30-2019, 10:30 PM   #820
Another 72
Towed it to Tennessee in preparation for an upcoming move. We move next week. My garage looks like a pretty boring place right now!
Rob
"1967 Wanna Be" 1972 K5 Blazer
Another 72 is offline   Reply With Quote
Old 05-31-2019, 07:41 AM   #821
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Had steel caps that were chrome plated and stainless caps professionally polished by same company. Hard to tell which are chrome and which are stainless unless the light is just right. Both types have a mirror finish.
Old 05-31-2019, 09:36 AM   #822
Ol Blue K20
WOW! They are pretty. Almost a shame to paint them.
Dale
Old 05-31-2019, 05:35 PM   #823
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Painting these will be a bear - it's a lot of tape work. I wonder how GM painted these? Molds?
Old 05-31-2019, 06:18 PM   #824
SoCoC10
SoCoC10's Avatar
Disassembled center console cleaned polished and painted.
Old 05-31-2019, 06:21 PM   #825
SoCoC10
SoCoC10's Avatar
Cleaned and painted new bucket seat backs and freshened up the door panels.
