Old 05-07-2019, 06:30 PM   #26
gmc684x4
Re: Bmxbang's 71 Project
I like the look of the 71/72 milk crate grill more then the 69/70 grill
gmc684x4 is offline   Reply With Quote
Old 05-07-2019, 08:04 PM   #27
bmxbang
They definantly both have there pros and cons but for me the 69/70 grill has more pros that my current 71 front end. If I had unlimited funds id have a 67-68 but I don't want to swap the whole front clip.
bmxbang is offline   Reply With Quote
Old 05-15-2019, 06:00 PM   #28
bmxbang
I'm taking advantage of my old step side bed while I still have it and using the truck like a truck.
Old 06-02-2019, 11:45 AM   #29
bmxbang
scored a few needed parts for the new grill at a local swap meet today for an awesome price and a few emblems just because.
Old 07-28-2019, 05:25 PM   #30
bmxbang
no updates just cleaned it up today. been focusing on the house this summer so the truck got put on the back burner. Should have some fun things happing again this winter.
Old 07-29-2019, 03:24 PM   #31
68Gold/white
Looks waaay better now, than it did with the blingy wheels that came on it!!! At least it's useable, now!!!
68Gold/white is offline   Reply With Quote
Old 10-03-2019, 05:46 AM   #32
bmxbang
wife got me some headers for my birthday! now to lock down what mufflers I want and then get the exhaust buttoned up!
71 C-10 SWB
LS Swap
Old 11-03-2019, 07:19 PM   #33
bmxbang
finally getting around to making some progress with the old exhaust out of the way I have been cleaning up the frame rails. that has consisted of pulling out all the old fuel lines and cleaning up and re running some of the Newer wiring and adding new clamps for the current fuel lines and current wiring. I wanted to get that all done before the new exhaust goes in. Still have a ways to go but its looking a lot nicer and less and less like a rats nest under there
71 C-10 SWB
LS Swap
Old 11-05-2019, 04:35 PM   #34
bmxbang
Got both sides of the Speed Engineering Long tube Headers in today for a test fit. Both sides fit no problems with frame clearance. Only problem is my stock transmission crossmember was re used and I have decided instead of putting some pretty extensive bends in the exhaust to just go ahead and replace the crossmember with one from Ingenuity Fab and Speed to make running the exhaust a whole lot easier and to keep it tucked up near the frame rails and out of site.
71 C-10 SWB
LS Swap
Old 11-05-2019, 09:42 PM   #35
TexasLS1
TexasLS1's Avatar
Looking good!!
TexasLS1 is offline   Reply With Quote
Old 11-06-2019, 09:30 AM   #36
cebra
I used a very cheap trans dapt one from Summit (maybe $50) and it fit great in the stock holes and provided tons of clearance for my exhaust/Speed Engineering headers. Just a FYI.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 11-06-2019, 10:03 AM   #37
bmxbang
Originally Posted by TexasLS1 View Post
Looking good!!
thanks, it's making progress! Slow and steady lol
Thanks for the heads up! I went ahead and already ordered the other one as I didn't think the cheaper ones would give me the clearance I wanted for the 3" exhaust tubbing lol should have waited! I appreciate it!
71 C-10 SWB
LS Swap
Old 11-09-2019, 07:14 PM   #38
68Gold/white
If that cross member doesn't work, THere's a company called Dirty Dingo that makes one...
Old 11-09-2019, 07:56 PM   #39
bmxbang
I'll know soon it came in today looks super stout ill be test fitting it up tomorrow.
71 C-10 SWB
LS Swap
Old 11-09-2019, 08:03 PM   #40
68Gold/white
LOL, I checked their website. Did not sign up. Did see a cross member, that thing looked like it weights as much as my ex wife...
Old 11-09-2019, 08:07 PM   #41
bmxbang
Ha Ha! Its not to bad I think its between 20-25 lbs!
71 C-10 SWB
LS Swap
Old 11-10-2019, 04:40 PM   #42
bmxbang
Got the new Transmission Crossmember all fitted this morning and pulled it back out to throw some paint on it! should have it thrown back in tomorrow afternoon. Next up exhaust
71 C-10 SWB
LS Swap
Old 11-10-2019, 08:16 PM   #43
68Gold/white
Looking forward to exhaust pictures!!!
Old 11-14-2019, 06:51 PM   #44
bmxbang
Had my buddy Dave weld up the V band clamps today on the headers and some 3" exhaust tubing. Sadly this will be the only pretty picture of welds I will get to post. Im going to clamp the mufflers and then just dump it after the mufflers.
71 C-10 SWB
LS Swap
Old 11-19-2019, 01:39 PM   #45
bmxbang
finally got around to ordering mufflers going to go with Black Widow Venom 250's I think they sound amazing on the ls motors with a cam. Hopefully get the exhaust wrapped up in another week or so then it's time to tear apart the rear end and give it a refresher.
71 C-10 SWB
LS Swap
Old 11-22-2019, 04:24 PM   #46
bmxbang
finally got the new mufflers in today, my schedule is a mess up until after thanksgiving so fingers crossed ill have them installed sometime within the next week.
71 C-10 SWB
LS Swap
Old 12-05-2019, 01:08 PM   #47
bmxbang
https://youtu.be/QMuuTtgCv78
Finally got a clip of the exhaust set up on the truck today im pretty happy with the sound. Its little loud inside the cab with no insulation whatsoever yet but ill get over that
71 C-10 SWB
LS Swap
Old 12-06-2019, 01:54 AM   #48
ShortHaul
ShortHaul's Avatar
Damn that sounds MEAN! I love what you've done with her so far... My initial thought on the first post was "yuk, ditch those blingy wheels and drop it to the floor..." and sure enough within a few posts, you had done exactly that! Keep up the good work, and post some more videos of that exhaust sound! maybe a drive by if you can? I've got a 6.0L swap in my '62 Impala, and I kept the flowmaster 44s that were on it when it was a 350/th350. It sounds good, but I've always liked the Black Widows, I feel like they're made just for LS swaps.
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 12-06-2019, 10:26 AM   #49
TruDom
nice! i've had my eye on the black widow mufflers for when i do my ls swap. ya sold me... sounds great.
TruDom is offline   Reply With Quote
Old 12-06-2019, 08:32 PM   #50
bmxbang
I appreciate it! Ill try next week to grab a driving video since I have a few days off. Ill post it up in this thread when I do!
Im a fan! they are a little pricier than good old flow masters but I think they are worth it for a little different sound.
71 C-10 SWB
LS Swap
