11-29-2018, 06:10 PM | #26 |
6>8 Plugless........
Re: 67 (Crew Cab) C30
Randy, I don't think you did post it and I would like to see it as well.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-29-2018, 07:02 PM | #27 | |
Thanks for that info. I studied your build extensively for quite awhile. I don't remember those details in your build. I have a back log of pics now of stuff That I have been mocking up. So I can understand how it wasn't. I can almost picture the reverse flip now. But like they say your pics would be worth a million words. Thanks Dwayne
11-29-2018, 07:07 PM | #28 |
I'm almost positive I didn't post it, I will take some pics and number the pieces with a marker and post up on my thread, I will try to do that this weekend.
11-29-2018, 07:18 PM | #29 |
Thanks Randy
That will help A lot. I'm Going to start working on a jig this weekend for those letters on the hood . It is going to be a coin toss for me when it comes time to put the hood on. Do I use Original hood or Hood Scoop Repop ? So I could use the jig if I go that route. I already have some angles and (Ruff) blueprints drew up. Dwayne
11-29-2018, 07:21 PM | #30 |
I guess i will order the hood letters then, looks like i will need them soon...
11-29-2018, 07:32 PM | #31 |
The center jig is the (time consuming one).
Once the holes are drilled in the center with this jig the two side jigs will line up. The side jigs are Simple.
12-27-2018, 11:08 PM | #32 |
I got some time to work on bracing the cab
for replacing the whole floor. I made brackets to utilize the bolt holes for dash and gas tank mounting bolt holes.
12-27-2018, 11:11 PM | #33 |
More pics
12-28-2018, 12:42 AM | #34 |
I drove to Cleveland ,Tn. today and
purchased a Coach Controls Coupe23B long wiring package. Thanks to member halfstep for bringing this business to my attention. Met with the owner of the company. (He has exp. with NASA,Race cars, Old cars and etc.) Spoke with him about my build and talked about the package that would be best for my Build. For the people that are staying (Factory-Style) there is other company's that have options that are more suited for that type of build. Maybe my next build will be more (original). I have been studying the wiring of our trucks. I even made a big copy of wiring diagram that is saved in the FAQ . (3rd picture at the bottom.) He was impressed when I explained to him how easy it was to find this type of info and the knowledge base of this Forum. When He showed his Wiring Schematic I knew that was a good plan for my Build. (1st picture is front & 2nd is the back ) This wiring diagram is the layout of his kit. It is very easy to understand. I wanted this kit now so I can build my cab to pick the best location.
12-28-2018, 01:08 AM | #35 |
Here is the link for Coach Controls
http://coachcontrols.com/ This is pictures of the Power Center 1st With cover on 2nd With cover off 3rd Wiring and acc. included.
12-28-2018, 01:53 AM | #36 |
This is the wiring for the switches.
03-27-2019, 11:42 PM | #37 |
Update on my build.
I purchased 2 3rd door rocker panels for suburban. I cut one of them into pieces and reversed It.
03-27-2019, 11:43 PM | #38 |
03-27-2019, 11:49 PM | #39 |
I found this at a Swap meet
04-26-2019, 12:04 AM | #40 |
A little update.
These are pictures of Us working on getting the old floor-pan removed. My Hired hand was in the Middle of Things. She will show up in the next post. This is where I marked out maximum to cut for cab corner patches. . .
04-26-2019, 12:15 AM | #41 |
04-26-2019, 12:16 AM | #42 |
04-26-2019, 12:24 AM | #43 |
This number in the (red) circle was stamped in the sheet-metal. .
05-04-2019, 11:05 PM | #44 |
I got the floor pan removed today.
Here is a few Pictures. 1st one is my helper before the process. 2nd is before I cut the floor out 3rd is bottom of floor after it's out. 4th is top of floor after it's out. . .
05-25-2019, 01:13 AM | #45 | |||
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
05-25-2019, 02:44 PM | #46 |
Yeah she is getting big.
Right now I am working towards making the piece between the cab corners. I bought a bead roller. Now I just need to order my sheet-metal. Once I get it made and welded in. I will put the floor pan in then replace the gas tank brackets. Got some brackets in good condition from a board member.
06-16-2019, 09:04 AM | #47 |
I have been working on fitting the front floor pan.
From Woodall Industries/Taiwan. Here is the Quality Inspector. She is checking for Defects. My truck has the braces under the gas tank. So I have to remove the weld nuts and drill out the holes that are not there. .
06-16-2019, 09:24 AM | #48 |
I removed the weld nut there was 4 spot welds on pass. side. There was 6 spot welds on drivers side I center punched from the bottom to locate the position for hole to be drilled in the front center bolt. The weld nut is there for these bolts on both L/R side. Next is a repeat on driver side. Well maybe a little different. The hole to be drilled in picture below (the red circle with the dot) Has to be drilled thru the floor-pan brace also. I will show that in the next posts.
06-16-2019, 10:19 AM | #49 |
Starting on driver side weld nut
This one had 6 spot welds. It has 3 spot welds on the nut cage. I left these intact.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 06-16-2019 at 10:35 AM. |
06-16-2019, 10:26 AM | #50 |
Not so great of a picture.
The driver-side I had to drill the bottom inside hole in the floor brace. the Drivers side was already there. Neither of these Inside holes have weld nuts. That's not a big deal thou.
