Old 05-31-2019, 06:24 PM   #826
SoCoC10
SoCoC10's Avatar
Re: What did you do to your Blazer/Jimmy today?
Vinyl wrapped the door panel inserts.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 05-31-2019, 06:47 PM   #827
dirish
dirish's Avatar
Those look great!
dirish is offline   Reply With Quote
Old 05-31-2019, 07:50 PM   #828
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by dirish View Post
Those look great!
X2!!! They look great. Did you take pics of the process?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-31-2019, 08:25 PM   #829
SoCoC10
SoCoC10's Avatar
Not complicated at all. Just used a prepsol to clean the inserts. Back of the vinyl has grids to make measuring easier. Cut to length and width. Removed the top 1 1/2 of the backer and attached all the way across the top. Then worked the vinyl from the larger area to the smaller area. Used a firm squeege to get air bubble out as you move along. Make sure the vinyl is tight against both sides of the raised perimeter detail and use a brand new razor blade to cut the vinyl off the top of the detail. Use the center of the razor blade and hold almost horizontally. I did each of the six perimeter sections one at a time. Making sure the vinyl was attached well and used 3-4 razor blades.
Old 05-31-2019, 09:26 PM   #830
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Damn fine work! I appoint you the new Cheyenne Superman - how much for a set of panel inserts?
Old 05-31-2019, 09:38 PM   #831
simicrintz
Awesome work!!! Man-I really want a center console like that; bet they're rare as hens teeth, huh?
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 06-03-2019, 06:07 PM   #832
SoCoC10
SoCoC10's Avatar
Not really. They are out there. Check your local K5 Facebook pages or marketplace. I had an extra one just sold to a member here.
Got some satin black on all the seat brackets and air cleaner assembly. Would have more pictures but had to pack up early because of another thunderstorm.
Old 06-03-2019, 06:30 PM   #833
1rippen6
Where did you get the vinyl? Thanks
1rippen6 is online now   Reply With Quote
Old 06-03-2019, 10:02 PM   #834
simicrintz
Thank you, SoCoC10! What type of dough should I expect to shell out (don't want to hijack the thread-can PM if preferred).
-Bruce
1971 K5 Blazer 4WD
Old 06-04-2019, 07:52 PM   #835
SoCoC10
SoCoC10's Avatar
Here's a screenshot of the vinyl I used. Took a month to get it.
simicrintz I PMed you
Old 06-04-2019, 08:05 PM   #836
1rippen6
Cool, thanks
Old 06-05-2019, 11:58 AM   #837
DemkoG
3M di noc is what I used on my wagoneer worked out very well
https://www.amazon.com/s?k=3m+di-noc...l_6evfwr4oxw_e
it is rated for marine use so good in the sun and water uv.
DemkoG is offline   Reply With Quote
Old 06-06-2019, 08:53 PM   #838
SoCoC10
SoCoC10's Avatar
Getting closer
Old 06-06-2019, 09:52 PM   #839
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Did you remember to install those foam thingys between the cowl and upper fender?
Old 06-08-2019, 02:16 PM   #840
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Had a 71-72 GM accessory cruise master cruise control installed. See the button under the dash.
Old 06-08-2019, 08:30 PM   #841
litebulblsc
litebulblsc's Avatar
Welded lower shock mounts on my 14BFF and finished cleaning and painting the rear frame while it's exposed
litebulblsc is offline   Reply With Quote
Old 06-11-2019, 09:26 AM   #842
SoCoC10
SoCoC10's Avatar
That's awesome! Time to pack it up, put it to the test and get it out on the road!
Old 06-11-2019, 09:28 AM   #843
SoCoC10
SoCoC10's Avatar
Wipers, wiper arms, antennae, grill assembly and front bump installed.
Old 06-11-2019, 09:32 AM   #844
Austinjay
Austinjay's Avatar
That blazer looks amazing. You're doing a fantastic job!
'72 K20 Ochre/white 350/350/205 4" Lift 35's
'72 GMC K10 red orange/white 400/350/205
'69 C20 Longhorn 454 TH400
'72 Blazer CST 4x4
'70 Blazer 4X4
Austinjay is online now   Reply With Quote
Old 06-11-2019, 11:40 AM   #845
Ol Blue K20
Have tried it yet. That's cool
Dale
Old 06-11-2019, 11:41 AM   #846
Ol Blue K20
Looking great!
Dale
Old 06-12-2019, 09:43 PM   #847
SoCoC10
SoCoC10's Avatar
Thanks guys! Butt-oning things up. Installed the gravel guards, bumper brackets, license plate bracket and rear bumper.
Old 06-12-2019, 09:55 PM   #848
Ol Blue K20
Looking great....
Dale
Old 06-13-2019, 11:09 PM   #849
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sorry Dale I missed this. Not yet. Still at the shop getting a few other tweaks like an odometer swap, choke adjust, and slider windows: http://www.musclecarrestorations.com...Blazer-72-001/
Old 06-13-2019, 11:38 PM   #850
IronCanine
I'm trying....
IronCanine's Avatar
...Butt-oning things up. Installed the gravel guards, bumper brackets, license plate bracket and rear bumper.
Troy- Blazer looks fantastic. Great job.
...at the shop getting a few other tweaks like an odometer swap, choke adjust, and slider windows: http://www.musclecarrestorations.com...Blazer-72-001/
Pete...sliders look outstanding. Died when I saw the antenna ball in the first pic.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
