05-31-2019, 06:24 PM | #826 |
Re: What did you do to your Blazer/Jimmy today?
Vinyl wrapped the door panel inserts.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
05-31-2019, 06:47 PM | #827 |
05-31-2019, 07:50 PM | #828 |
Proprietor of Dale's Corner
X2!!! They look great. Did you take pics of the process?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-31-2019, 08:25 PM | #829 |
Not complicated at all. Just used a prepsol to clean the inserts. Back of the vinyl has grids to make measuring easier. Cut to length and width. Removed the top 1 1/2 of the backer and attached all the way across the top. Then worked the vinyl from the larger area to the smaller area. Used a firm squeege to get air bubble out as you move along. Make sure the vinyl is tight against both sides of the raised perimeter detail and use a brand new razor blade to cut the vinyl off the top of the detail. Use the center of the razor blade and hold almost horizontally. I did each of the six perimeter sections one at a time. Making sure the vinyl was attached well and used 3-4 razor blades.
05-31-2019, 09:26 PM | #830 |
Carpe manana
Damn fine work! I appoint you the new Cheyenne Superman - how much for a set of panel inserts?
05-31-2019, 09:38 PM | #831 |
Awesome work!!! Man-I really want a center console like that; bet they're rare as hens teeth, huh?
-Bruce 1971 K5 Blazer 4WD |
06-03-2019, 06:07 PM | #832 | |
Got some satin black on all the seat brackets and air cleaner assembly. Would have more pictures but had to pack up early because of another thunderstorm.
06-03-2019, 06:30 PM | #833 | |
06-03-2019, 10:02 PM | #834 |
Thank you, SoCoC10! What type of dough should I expect to shell out (don't want to hijack the thread-can PM if preferred).
06-04-2019, 07:52 PM | #835 |
Here's a screenshot of the vinyl I used. Took a month to get it.
simicrintz I PMed you
06-04-2019, 08:05 PM | #836 |
Cool, thanks
06-05-2019, 11:58 AM | #837 |
3M di noc is what I used on my wagoneer worked out very well
https://www.amazon.com/s?k=3m+di-noc...l_6evfwr4oxw_e it is rated for marine use so good in the sun and water uv. |
06-06-2019, 08:53 PM | #838 |
Getting closer
06-06-2019, 09:52 PM | #839 |
Carpe manana
Did you remember to install those foam thingys between the cowl and upper fender?
06-08-2019, 02:16 PM | #840 |
Carpe manana
Had a 71-72 GM accessory cruise master cruise control installed. See the button under the dash.
06-08-2019, 08:30 PM | #841 |
Welded lower shock mounts on my 14BFF and finished cleaning and painting the rear frame while it's exposed
06-11-2019, 09:26 AM | #842 |
That's awesome! Time to pack it up, put it to the test and get it out on the road!
06-11-2019, 09:28 AM | #843 |
Wipers, wiper arms, antennae, grill assembly and front bump installed.
06-11-2019, 09:32 AM | #844 |
That blazer looks amazing. You're doing a fantastic job!
'72 K20 Ochre/white 350/350/205 4" Lift 35's '72 GMC K10 red orange/white 400/350/205 '69 C20 Longhorn 454 TH400 '72 Blazer CST 4x4 '70 Blazer 4X4 |
06-11-2019, 11:40 AM | #845 |
Have tried it yet. That's cool
06-11-2019, 11:41 AM | #846 |
Looking great!
06-12-2019, 09:43 PM | #847 |
Thanks guys! Butt-oning things up. Installed the gravel guards, bumper brackets, license plate bracket and rear bumper.
06-12-2019, 09:55 PM | #848 |
Looking great....
06-13-2019, 11:09 PM | #849 |
Carpe manana
Sorry Dale I missed this. Not yet. Still at the shop getting a few other tweaks like an odometer swap, choke adjust, and slider windows: http://www.musclecarrestorations.com...Blazer-72-001/
06-13-2019, 11:38 PM | #850 | ||
I'm trying....
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
