06-16-2019, 10:33 AM | #51 |
Re: 67 (Crew Cab) C30
I placed the floor the first time here.
This is Pass. side lower A-pillar side. Driver side lower A-pillar side And some pliers I modified to clamp the floor to the Toe board.
06-16-2019, 10:54 PM | #52 |
very interesting modified pliers, I may have to borrow that idea from you.
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
06-16-2019, 11:33 PM | #53 |
I have a radical idea!
Nice work!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
06-16-2019, 11:37 PM | #54 | |
I got the idea from my pliers like this. They would not work without modification. So I bought a $3 pair + (20% discount ) from Harbor Fr .
06-16-2019, 11:38 PM | #55 |
06-20-2019, 07:30 AM | #56 |
Got the floor pan back in location.
Next I will work on the lower A-pillars. They came in the mail yesterday. And of course the Cab Footwell Patches. .
06-22-2019, 08:16 AM | #57 |
Measuring for my roof cut.
I am still fine tuning the floor fit. I got these body hammers at a yard sale a few years ago. Got to find the right ones to fix this gap.
06-22-2019, 08:20 AM | #58 |
This combo of hammer and slapper fixed it.
06-24-2019, 11:33 PM | #59 |
I am still fitting the floor pan.
I decided to bolt in a center hump I got from a swap meet. I used long bolts and used some of them as studs to line all the floor pan and Firewall up even more. .
06-29-2019, 10:08 AM | #60 |
Here some more progress on my Floor.
First of all, I am still debating on whether to incorporate the jack handle stamping into my new floor pan. Of course I would weld this in under the rear seat. It is the only solid section in the original floor. I finally got the big gap closed between the toe panel and the new floor pan. The reason this was such a problem. Is the original welds in the toe panel was not welded very good from the factory. Maybe a Friday evening or Monday morning (production line) thing. About 6" up the toe panel and 14' across the bottom there was a 1" gap when I pulled the floor mat out. This caused the cab to settle over time. I have it all Squared Up and fitting again Finally. .
06-29-2019, 10:14 AM | #61 |
Looking good and I love the adapted vise grips,too, great idea.
06-29-2019, 10:28 AM | #62 |
This is What helped me the most.
I bolted the best fitting center hump I had. (without using the Original one) I used long bolts as studs screwed in from the bottom (So I could pull the floor hump down with a washer and nut ) And the bolts I could start from the top side, I put nuts and washers on them and slowly tighten the nut and worked with each bolt till I got the Trans hump pulled down tight. This put the toe panel and the floor fit good in the front center of the floor.
06-29-2019, 10:37 AM | #63 | |
The other pliers That I found to do this was to Heavy and was trying to bend the sheet-metal. .
06-29-2019, 10:42 AM | #64 |
That is a great way to use those cool pliers and the hi hump to get that gap lined up.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-29-2019, 11:43 PM | #65 | |
06-29-2019, 11:55 PM | #66 |
Here's a Picture or 2
of my current Cab fixture. .
07-07-2019, 12:53 PM | #67 |
Now that my floor-pan is fitting like I want it too.
I cut some more tubing and drill holes in the tubes to use the seat mounting bolts and welded that to my cross-bracing. So I can remove the floor Again I chose to do this for easy access to the foot-well patches that I'm going to replace. Once I fit both foot-well patches, I will tack them in & put the floor back. Then I will repair the lower A-Pillar. Doing it this in this order I can keep the location of the 2 lower a-pillar and lower fender mounting holes in the ( same ) location. I used a small dremel tool on the spot welds. It worked good for this area. .
07-07-2019, 01:04 PM | #68 |
More pictures of foot-well removal.
Used this dremel with cut-off wheels that came with it to stay out of the lower A-pillar. I lined the patch up and scribed it on the back side for my cut line. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 07-07-2019 at 01:20 PM. |
07-07-2019, 01:12 PM | #69 |
My next step will be sand blasting. and rust treatment. .
07-07-2019, 01:19 PM | #70 |
Since I am replacing the Toe-board
I removed the floor braces that attach to the toe-board for easier installation of the floor pan. This is a tool I made too break the welds loose. .
07-07-2019, 02:04 PM | #71 |
BlahBlahBlah
Holy moly! You guys that can pull this sort of thing off are amazing. Great job so far.
07-07-2019, 02:10 PM | #72 | |
I hope to get a little more done today. .
07-07-2019, 03:11 PM | #73 |
Wow , great work .
07-07-2019, 03:27 PM | #74 |
07-07-2019, 10:14 PM | #75 |
Got some sandblasting done.
It all cleaned up good. I need to get some more media. I Got a little more blasting work to do. .
