Old 06-15-2019, 03:33 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
Multi function switch
I have a 99 OBS Crew cab needs a new switch, watched a few videos read a bunch.
Do you need to pull the steering wheel for a no air bag column?
Old 06-15-2019, 05:54 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Multi function switch
Nope dont need to pull the wheel off or the upper plastic column cover. #25 torx bit and a 1/4" end wrench.
And a 4mm socket will work on the invert torx head on the lower cover.
Brittle parts though go slow
Old 06-17-2019, 08:24 AM   #3
shifty
Questionable
shifty's Avatar
I am needing to replace mine also, '98, airbag.
Found a YouTube video that showed how to replace it without disabling SRS or taking off the wheel, just remove the two halves of the clamshell.
For the life of me, I cannot find the video anymore and it's pissing me off. I've had the replacement part for weeks now.
All the videos from 1aa auto (or whatever) on YouTube all show removing the wheel and disabling SRS.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-17-2019, 09:27 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Not sure what differences between the two columns. But I didn't even pull the key tumbler. Left the top half of the clam in place.
Now my wipers work correctly too.
Old 06-20-2019, 11:06 AM   #5
SCOTI
SCOTI's Avatar
Good info so Thanks for sharing!
Where are you guys sourcing the replacement Multi Function Switch?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-20-2019, 02:38 PM   #6
shifty
Questionable
shifty's Avatar
Sorry, long answer to a short question.
I had a bunch of credit on eBay/PayPal before they split. My Hazard switch has been stiff as hell for a while, I think a PO spilled something in it. I know there's a replacement kit for just the hazard bit, but the white text is wearing off my stalk, so I figured I'd replace the whole thing, clean it up, re-sell for $20-30 or something.
"Standard" brand has a pretty good reputation on their parts, very similar (or maybe the source) to Dorman, so I picked up theirs, p/n: DS698T
https://www.ebay.com/itm/400669584334
I got mine from eBay, but during a price drop from that seller. I think I got out the door for around $50, which was $5 cheaper than the one currently eligible for Amazon Prime, and about $30 cheaper than my big-box store with a 10% coupon.
There's a
Old 06-20-2019, 05:58 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
GM one from Amazon $200 ish
Check this out at Amazon.com
ACDelco D826A GM Original Equipment Turn Signal, Headlight Dimmer, Windshield Wiper and Washer Switch with Lever https://www.amazon.com/dp/B000C9MN90..._hiadDbJ7T0MVK
Old 06-21-2019, 09:29 AM   #8
shifty
Questionable
shifty's Avatar
4x price was is a huge difference for me. Only reason I didn't pay that high premium cost is Standard Motor Products manufactures at least some of Delco's stuff (Fuel Spider being one speedy talks about) so I was comfortable dropping $50 on a company that's trusted enough for Delco to re-brand parts on.
Old 06-21-2019, 10:19 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
$200 is a cheap price to pay too not do it a 2nd time.
