Old 03-11-2019, 08:54 AM   #176
8man
Re: Starting a 52 Chevy 3100 Project.
X2, and I'm one those pics will help. Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-11-2019, 09:37 AM   #177
28TudorAZ
28TudorAZ's Avatar
Originally Posted by joedoh View Post
nice work! those e brake pictures will be a great reference for future guys.
Thanks. It's an early 90 Chevy c1500 pedal one bolt goes on the bottom hinge the top I drilled another hole in the emergency brake and behind the hinge outside and the front was welded on. You could easily make it bolt by adding the plate I added behind it
Someone had cut speaker holes but I am leaving them as access holes to put in door pins for the dome light. Also bought the release cable at the auto parts store and it bolted directly to it without modification.
28TudorAZ is offline   Reply With Quote
Old 03-11-2019, 04:19 PM   #178
El_C10
Very nice work man!! Just picked me up a 51 and weighing out my options. Thanks for the inspiration 28TudorAZ!!!
El_C10 is offline   Reply With Quote
Old 03-11-2019, 08:43 PM   #179
28TudorAZ
28TudorAZ's Avatar
Thanks! I am coming up on 1 year in 2 months so I better get my butt in gear. I wanted to get finished in a year. Found these ad pictures the other day from when I bought it.
Old 03-17-2019, 11:14 PM   #180
28TudorAZ
28TudorAZ's Avatar
Built the gas pedal.
Old 03-18-2019, 12:45 AM   #181
joedoh
joedoh's Avatar
heyoooo!
Old 03-18-2019, 08:46 AM   #182
8man
Looking good.
8man-aka Robert
Old 03-18-2019, 10:08 AM   #183
Matt_50
Looks good, what insulation did you use behind the seat?
1950 Build
Matt_50 is offline   Reply With Quote
Old 03-18-2019, 11:05 PM   #184
28TudorAZ
28TudorAZ's Avatar
Thank guys. Any progress is good.
I used the $15 rolls from Lowe's.
Old 03-19-2019, 01:18 AM   #185
Driver_WT
Driver_WT's Avatar
Can you post a link to the $15 roll from Lowes?
Thanks.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 03-19-2019, 10:48 AM   #186
28TudorAZ
28TudorAZ's Avatar
Thanks.
I am doing the whole inside including ceiling and doors with it. I want it as airtight as possible.
https://www.lowes.com/pd/Peel-Seal-I...ashing/1018733
Old 03-19-2019, 11:12 AM   #187
NeoJuice
Thanks.
I used some of this on my truck by other peoples suggestions.
https://www.lowes.ca/metal-duct/fros...erm=frost-king
NeoJuice is offline   Reply With Quote
Old 03-19-2019, 11:20 AM   #188
Driver_WT
Driver_WT's Avatar
Thanks guys. Greatly appreciated.
Wade
Old 03-25-2019, 08:04 PM   #189
28TudorAZ
28TudorAZ's Avatar
Seat and seat belts put in.
Old 03-25-2019, 08:06 PM   #190
8man
Nice. What is the seat out of.
8man-aka Robert
Old 03-25-2019, 08:18 PM   #191
Matt_50
Are you doubling up on the sound deadener?
1950 Build
Old 03-26-2019, 09:31 AM   #192
28TudorAZ
28TudorAZ's Avatar
Early 90s chevy truck. Pick n pull. $50 reupholstered $350
Old 03-26-2019, 09:32 AM   #193
28TudorAZ
28TudorAZ's Avatar
I did on the carpet. Went with a carpet padding as well.
Old 04-18-2019, 07:46 PM   #194
28TudorAZ
28TudorAZ's Avatar
Finished the pastry work on the front of the cab and started routing the engine wiring. I plan on getting the font end back on in the next week.
Old 06-20-2019, 04:43 PM   #195
28TudorAZ
28TudorAZ's Avatar
Havent posted in a while. Making some progress. My dad is bringing the doors over at the end of the week. Hopefully get them painted and put on over the weekend. Then its wiring and fluids.
Old 06-20-2019, 07:05 PM   #196
8man
It is looking good.
8man-aka Robert
Old 06-22-2019, 06:22 PM   #197
28TudorAZ
28TudorAZ's Avatar
It is looking good.
Thank! Doors and front bumper arrived at my house yesterday. Built the battery box from the s10 one.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
Old 06-23-2019, 08:22 AM   #198
8man
Did you do any type of stiffener on the inside of the firewall for the battery box?
8man-aka Robert
Old 06-23-2019, 08:39 AM   #199
28TudorAZ
28TudorAZ's Avatar
The brace going down to the inner fender is welded to the bottom of the box. When I push on it the whole truck moves so it is really solid. Also where I shortened it on one side it has really thick angle iron.
Old 06-23-2019, 08:50 AM   #200
8man
I may steal this idea.
Thanks.
8man-aka Robert
