#676 |
Re: What did you do to your truck today.The 3rd chapter
Reading all theses awsome post makes me feel bad. All I did was replace some valve cover gaskets and remover the rest of the trasmission spark control wiring.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
#677 |
Drove mine to Home Depot, an appointment, and to 7-11 for a soda.
#678 |
Feel like thats all I have been doing the last two weeks. Painting today.
But then I start on the cab.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#679 |
Bed is completely painted . Now I need to get the wood installed and put it back on the truck. Never intended to make it a show truck but I need to redo one fender . Got a bug and a run. Also had to settle for a little less gloss so I could get the motling out of the paint . Lots of misting ,only problem with single stage metallic paints.
At least it's on the fender I hope to replace . Put a 67 with spare tire mount on my 68. Hope to find a real nice 68 fender.
#680 |
I guess its acceptable.
#681 |
![]() Join Date: Oct 2014
I'd say more than acceptable, very nice job! A trick I learned a long time ago from an "old timer": When painting a single stage metallic that tends to mottle is after the last coat is sprayed take whats left in the cup and fill the cup with reducer. Then drop the pressure to about 20 lbs. Open the fan pattern wide open and mist over the whole part. The reducer will melt in and the metallic will settle evenly. It worked for me on a 77 step side I sprayed years ago.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
#682 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 07-09-2019 at 05:10 PM. |
#683 |
And its 1000% better the the general painted things . My uncle always commented in the GM MARK OF Excellence stickers on cars and trucks at the body shop . His interprition GM MARK OF CRUDNESS.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 07-09-2019 at 05:24 PM. |
#684 |
Really didn't think I would like the saddle fawn color . I was contemplating 503 green for the truck but now I really like the color.
#685 |
![]() Join Date: Dec 2013
Blasted /primed and painted under dash pedal assemble . One more bite off the elephant
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#686 |
Test fitting panels and epoxy prime on this one this weekend .
#687 |
Looks great.
#688 |
I sold both of my trucks,1970 C10 original paint,original owner,and my 1985 C10, having some loneliness today,gonna have to build my 1967 soon
#689 |
Painted the bed supports and started the install
#690 |
Wood is working out nicely. Drilling all the holes then going to seal it . Need to hit it with some 220 on the da sander first . Decided to leave it raw no stain . Just seems to go better with the paint .
#691 |
Cleaned everything and hit the lens with micromesh and finished with the buffer
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#692 |
Who Changed This?
![]() Join Date: Jan 2013
Looks nice! I want to eventually do something with my truck's dash. The vacant gauge hole on the right will be for trans temp, and the tach will replace the vacuum gauge as in your location. I'd like to do something with the gas gauge, with a way to tell fuel level in the main and saddle tanks. I know that that option was out there; I just need to research it. It looks goofy to have that huge gauge for the fuel level, to me.
#693 |
Finally located a new (reman) gearbox. Claims its a 3.5 turn. Almost completely installed. I just have to finish hooking up the steering shaft and linkage. It's a PITA to do by yourself, on your back with the sun blazing on you, after a full day shift at work, and sweat running down into your eyes.
1971 C20 Longhorn 350/350 "Conquistador" Last edited by vitamin_c95; 07-15-2019 at 10:59 PM. |
#694 | |
#695 |
![]() ![]() Join Date: Mar 2016
Beautiful.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#696 |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
Not today, but this past weekend I did use it for it's intended purpose. Took it to my cabin for the weekend and brought back some firewood.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#697 |
Thanks . I'm waiting on the oil finish to arrive. Had to order it as it's not a stocked item around here . Penofin marine oil . I could have taken a ride to the coast some marinas carry it. Should be here tomorrow
#698 |
Test runs on the offset washers and holes . Came out well in the test piece we shall see on the actual boards
#699 |
Who Changed This?
If you make that truck too nice, all you are ever going to haul in it is ass.
#700 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
lol. ......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
