What goes here? (Interior bedside gap)
I just got some new interior bedside panels and they look great! But, there's a gap I need to solve for. It's between the interior panel and bedrail, about 3/4" toward the front, and basically 0" at the rear. What goes there? It looks like it needs to be a tapered filler or some sort. Is this the infamous "chrome strip"?
Re: What goes here? (Interior bedside gap)
Yep chrome strip would be even with the top of bed side, strip is 66 3/4" long.
![]() Join Date: Mar 2009
I don't remember a gap like that on mine. I will have to check.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
![]() Join Date: May 2011
![]() Join Date: Apr 2006
I’m hopeful the guy that makes the carpet strips will make these. Mine aren’t bad but it would be nice to have a new set.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
The new bedside panels don’t fit. Should be snug against bedside. You might try and roll back the material and trim the backer board.
![]() 72 blazer 4x4 4" 35's 02 f150 work truck 15 f350 super crew long bed 6.7 4x4(stock but loaded) 02 f350 horse hauler 7.3 (need to sell) |
So you're saying that the rigid backer board should stop at the back edge of the B-pillar and just the vinyl should continue up over the B pillar to the door opening? Can anyone with factory panels confirm this?
Carpe manana
![]() ![]() Join Date: Dec 2010
OEM rear panels have a cardboard backing that (for lack of a better descriptor) conform to the contour bend of the B pillar and are affixed posterior from the B-pillar by the chrome strips along the top and screwed to the face of the B-pillar, the stands along the quarter panels, and to the rear "post" near the tailgate. This is the best example pic I can post at the moment. There is nothing amiss with your panels. A set of the chrome strips is what you need for best fitment.
It's also worth noting that for single wall tops there are two styles of upper stainless top to bedside trim pieces: one with and one without CST panels.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 07-28-2019 at 09:35 AM. Reason: added detail |
#10 | |
Carpe manana
When possible I will. At the moment my Blazer is having a few details tended to at a local resto shop: http://www.musclecarrestorations.com...Blazer-72-001/
If you post a pic of the top to bedside trim pieces you have we can try to sort out if they are CST or non-CST pieces as a lot of changes may have occurred since the Blazer was built. From what I recall, the non-CST pieces project down along the inner bedside and may interfere with the chrome panel retainer strips. The CST top to bedside strips are reproduced and are of good quality (or were). The panel strips can be re-chromed at a fairly reasonable cost if you locate a set.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 07-28-2019 at 03:04 PM. |
![]() Join Date: Nov 2013
From the factory assembly manual....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#13 | |
I wonder if those strips can be approximated using aluminum or stainless j-channels. Those can be bought in various profiles at lengths up to 8ft. |
On my '70 I used some textured ABS plastic sheet for side panels...
I bought some aluminum "J" channel for the top trim and some push-on vinyl trim for the ends and bottom.... it fits so snugly that I only used about 3 or 4 black trim screws per side
#15 | |
#16 | |
only regret......just wish I had made it a little taller to come flush with the bedside....
#17 |
Following - great information!
#18 |
Thanks for the help so far, this may all be old news, but given how hard it is to find this info I bet others have similar questions. Here's another weird wrinkle, it appears as though the door panel trim used for '67-'71 is the same profile, but just shorter pieces. Can anyone confirm that?
https://www.manestruckparts.com/stor...Category_ID=19 |
#19 | |
#20 |
![]() Join Date: Aug 2015
I have heard of someone using multiple pieces of the reproduction door panel trim instead of the long rear strips. They said they cut the contoured ends where the two pieces met, and the seam didn’t stand out when installed.
71 K5 CST Blazer 350 70 Suburban 350 71 Chevelle SS 454 69 Olds 442 454 (yes, Chevy power!) 68 Camaro RS 327 66 Chevelle SS 396 Members I have met: 62cdan, 60case, daddymoo2, aotte1, 70shortfleet, countr, Cowboy#40, chevy71super, davischevy |
#21 |
I was thinking the same thing. That said, I wonder who is reproducing the door trim. They should easily be able to make "longer" versions of the door trim using the same roll-tooling.
#22 |
Agree but that’s only if it’s rolled. Given how the ends are formed, it’s possible it’s all done in a long die.
#23 |
Yeah. I'd put good money on roll-forming with a secondary operation to form the ends. Either way Im sure those tools are somewhere overseas and not likely to be willing to do "one-off work. Buying three sets of door trim, welding them together, grinding/polishing the welds, and having it plated would work, but sure sounds expensive!
#24 | |
#25 |
OK, I think after some serious searching (and concluding that I'll never find a set of OE strips) I think I've settled on using these stainless steel tile bullnoses. They won't have the exact profile of the original, but they're a nice radius and can be polished to a mirror finish.
Alternately, the local Home Depot has some chrome plated options https://www.homedepot.com/p/Custom-B...DC98/305238415 Last edited by harrij4; 08-22-2019 at 08:45 PM. |
