Old 01-29-2017, 11:43 PM   #1926
crakarjax
crakarjax's Avatar
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
Originally Posted by Jaybob View Post
Interesting tidbit:
The bellhousing extenion on an Gen 3 and Gen 4 LS motor (4.8, 5.3, 5.7, 6.0, 6.2, 7.0) is shorter than a GEN 1 and Gen 2 SBC (262, 265, 267, 283, 302, 305, 307, 327, 350, 400). There is approximately a ~7/16 difference between bellhousig extension and crank flange between the LS and SBC. The LS is shorter, the SBC is longer. Also the position of the cylinders relative to the bellhousing is different. The cylinders in an LS block are also approximately ~7/16" closer to the bellhousing. This means the cylinders are actually ~3/4" close the transmission in an LS motor than an SBC. So even with a longer water pump on the from, they still have similar or better radiator clearance.
The way you've done it, is the motor as far back as it'll go without firewall interference?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-29-2017, 11:47 PM   #1927
Jaybob
Yes, you couldn't go back another 1/2"!
Jaybob is offline   Reply With Quote
Old 01-30-2017, 01:18 PM   #1928
crakarjax
crakarjax's Avatar
I'm running an f-body pan and I'm wondering if I could go back even farther by dropping the engine down a bit. How far is the bottom of your truck pan from the crossmember?
Old 01-30-2017, 06:39 PM   #1929
I hope most of you realize that glock..... has not been on the board for many years, and last I heard I don't think he has this truck anymore.
Old 01-30-2017, 10:42 PM   #1930
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Trucks been sold for a long time.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-31-2017, 02:30 AM   #1931
crakarjax
crakarjax's Avatar
That's ok, we can pick up where he left off
Old 01-31-2017, 12:40 PM   #1932
Jaybob
I don't think very much. The firewall is pretty flat fight there. The passenger side cylinder head will hit the fire wall. My truck pan probably hangs an inch below the crossmember. You will have to dent the firewall to go back further I think.
Old 07-29-2019, 04:34 PM   #1933
G-NUT
G-NUT's Avatar
Originally Posted by glock35ipsc View Post
Can you say..... "like butta??!!"
I got the door alignment tool today. Ran to the shop like a little kid when I got home to try it. Stuck it on the truck, use my long Snap-On 1/2" ratchet, and gave it a good firm pull up. Took it off and..... butta!
Take two fingers and give it a fling, and it shuts tight!
Saweet!!!!!!!
I know this is an old post and this is likely a stupid question but I recently bought this same tool off Amazon, I haven't used it yet, but how does it work? I mean when you lift up on it with a breaker bar or the like, don't you have to get to the door hing bolts to tighten them up? How do you get to them when doing this without having a fender off?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 07-30-2019, 09:07 PM   #1934
nlped
nlped's Avatar
I bought this tool after Bob posted about it many moons ago. You don’t have to loosen the hinge bolts. You literally are ‘tweeking’ the existing hinge arrangement.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-31-2019, 12:53 PM   #1935
G-NUT
G-NUT's Avatar
Thanks for that quick response. I now have a '84 burb. I'll try it on one of the doors.
