08-04-2019, 10:10 AM | #1 |
Wiring Question for those who used 95 Silverado starters??
Looking to upgrade my starter to a newer smaller style Silverado starter from the mid-late nineties. How did you guys wire these up? I only see a stud for the 12v from the battery and a stud for the purple wire from the keyed ignition. What do I do with my yellow coil wire??
Thanks |
08-04-2019, 10:16 AM | #2 |
Who Changed This?
Re: Wiring Question for those who used 95 Silverado starters??
I stripped mine out of the harness when I put in the HEI. You will have to find a different source for ignition power during cranking, if you aren't using an HEI or other ignition. If you still have points, you can tap into the purple wire to power a relay that will power the coil when cranking. You'd still use that yellow wire, in that case.
08-04-2019, 10:45 AM | #3 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-04-2019, 08:33 PM | #4 |
Thanks guys, that’s just the info I was looking for as I also am running HEI.
