Old 08-22-2019, 11:13 AM   #1
DieselSJ
Need ehlp - ID this plug
Had my steering column out and when I put it all back together I cannot remember where this plug goes. I cannot find that color combination on my wiring diagram.
Any ideas?
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 08-22-2019, 08:45 PM   #2
Re: Need ehlp - ID this plug
I cannot see it clearly, but it looks like the brake pedal switch. plug
Old 08-26-2019, 05:07 PM   #3
DieselSJ
Thanks but nope - I have that one already. Wires are pink with black trace and purple on this one.
Old 08-26-2019, 05:43 PM   #4
sweetk30
sweetk30's Avatar
did you use to have cruise control ? some early units had a vac cut out switch to dump the diaphragm and also a switch on it .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-26-2019, 07:53 PM   #5
I know pink w/black is a switched 12V lead, but like you I don't see that color combo used in my electrics diagrams either.
Only thing rining in my mind now might be for safety belts connection. What year is the truck and is it 2wd/4wd?
Old 08-27-2019, 12:35 PM   #6
DieselSJ
That might be it...didn't think about the old vac switch also having electrical connector. I did tear out all of the factory cruise wiring when I had the column out. Thank you!!
Old 08-27-2019, 02:35 PM   #7
sweetk30
sweetk30's Avatar
if you did this also make sure to plug the hose off . i chased down a vac leak sound under the dash of my first truck and forgot this and replaced a brake booster for nothing . . . . it was the dam hose sucking air when i hit the brakes .
Old 08-27-2019, 04:44 PM   #8
DieselSJ
Oh yeah. All of the underhood stuff has been gone for a while and the vac hose disconnected.
On a side note, if anyone needs a complete factory CC setup (minus the lever on the column) send me a PM.
