Old 09-06-2019, 11:13 PM   #1
basketcase
basketcase's Avatar
20 Inch Tire Pressures
I have this '84 in my shop that a friend bought last weekend at the RM Sotheby's Fall Auburn auction. I'm fixing a few items on it, just some odds and ends that didn't get finished during the repaint. It's a low mile rust free Georgia truck with all the options. Engine is a 305 4bbl and it is a real nice truck. No mods to the driveline.They said it's lowered 5 and 7. Wheels are American Racing 20x8 and 20x10 as best I can measure on the width with 245/45 on the front and 275/45 on the rear.
I haven't been able to find the recommended tire pressures for these tires. Maximum pressure is 49psi. I'd like to know what pressure members with these tires run.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 09-06-2019, 11:51 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 20 Inch Tire Pressures
I would probably run 45 if it was mine...but id put 45 in and see how it rides...might try 40 just to compare...sometimes 5lbs makes a big difference in ride quality...but with those short sidewalls its may not be great anyway
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-08-2019, 01:03 AM   #3
VWNate1
VWNate1's Avatar
Post Discerning Tire Pressures For _ANY_ Tire
I agree you're going to want near 40 ~ 45 PSI but as mentioned, 3 to 5 PSI can make a HUGE difference in ride and more importantly handling and traction ~
Use chalk or some white paint across the tread from one side to the other then go drive it and see if the chalk / paint wears of faster in the middle or edges,if in the middle you need less pressure, if on the edges you need more pressure .
Remember : only add one or two pounds at a time and do both tires on each axle to the *exact* same pressure .
Do the rears first then the fronts, the Customer will think you're a genius and you can then make more $ setting up the proper tires pressures on anything .
Try it on your own tires and discover how much faster, er, SAFER (right) you can drive along with far longer tire life .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 09-08-2019, 09:01 AM   #4
geezer#99
geezer#99's Avatar
Too much pressure!
I ran 245 45 20 all around on my Daytona r/t at 34 psi. They were good for 40,000 miles.
The wider back tires on the truck I’d run a couple psi less.
Old 09-08-2019, 06:51 PM   #5
SKR
I run 28-30 in mine.
2007 GMC 2500 CCSB LBZ
1991 GMC 1500 RCSB 350
1981 GMC Street Coupe RCSB 454
SKR is offline   Reply With Quote
Old 09-09-2019, 10:55 AM   #6
1967KaiserM715
1967KaiserM715's Avatar
Re: Discerning Tire Pressures For _ANY_ Tire
I'm quoting this, because this is the correct way to make sure any aftermarket tire/rim package is set up correctly. with so many different tires, and pressure ratings, it is almost impossible to say what will work best. typically you should find you want the rear tires a few PSI lower then the front.
In this case, I believe Stock(GM) Manufacture recommended pressures for C/K10 trucks was 32 front, 28 rear. that would be a good place to start the chalk test, a lot of people worry about the bottom "bulge" and think a tire is under-inflated, but this is not always the case, only the tire wear can tell you if it is under or over inflated.
1967KaiserM715 is offline   Reply With Quote
Old 09-09-2019, 12:39 PM   #7
basketcase
basketcase's Avatar
Good advice. These tires are new but don't ride the best. I think the owner is going to change to a smaller grey painted center American TTII, Probably 17 or 18 with more side wall. He wants it to match his Americans he has on his mid engine 383 1966 Corvair. I just want to make sure his tires are properly inflated and safe in the meantime. I found some 17s listed with the same width and backspacing as the 20s so I'll recommend those to him. I have 17s on my daily driver and have always been happy with the ride.
Tom
Old 09-09-2019, 01:23 PM   #8
VWNate1
VWNate1's Avatar
Post Correct Tire Pressures
The ride should have nothing to do with it .
Traction = SAFETY and that is also going to be the best driving pleasure you get out of it .
The soft ride is what caused all those Fords S.U.V.'s to roll over and kill children and innocents ~ the dealers deliberately underinflated the tires, this made the trucks ride like cars and also overheated the tires to their failure point due to excessive sidewall flexing .
Corvairs are well known for spinning out easily and also rolling over in average driving, this too was because no one bothered to accept the front tires required different pressures than the rear tires .
Think about this before you carry your beloved family and friends in your vehicles with cool looking tires .
Most of the original tire pressures were specified for bias ply tires that are thankfully no longer available ~ radial tires always require higher pressures than do bias ply .
-Nate
Geezer
Old 09-12-2019, 01:45 AM   #9
mikelom
I would put 32-25 psi.
mikelom is offline   Reply With Quote
Old 09-12-2019, 01:30 PM   #10
VWNate1
VWNate1's Avatar
Post Re: 20 Inch Tire Pressures
And there you have it :
A ten pound spread on tire pressure is HUGE and can be unsafe .
-Nate
Geezer
Old 10-09-2019, 06:39 AM   #11
tino0217
I have 275 40/R20 160's on my 71 C10 long bed, i hve 32 in the front and 34 in the back. I live in Seattle so i get a lot of spin in the rain on take off ,manual, any suggestions?
tino0217 is offline   Reply With Quote
Old 10-10-2019, 05:33 PM   #12
VWNate1
VWNate1's Avatar
Pix of the actual tires so discern the actual width, wider tires look nice but loose traction in rain / snow very quickly .
Feathering the clutch might help, I don't know many who still know how to do it .
-Nate
Geezer
Old 10-12-2019, 01:42 AM   #13
tino0217
I appreciate the reply bro, the clutch is feathered that's how I bought the truck from this young kid, he was a wizard and only 23yrs old. what I did tonight was I put some chalk on the tires to to see where it was wearing. so I have the tires inflated properly. So I'm going to load up the German Shepherd go for a drive see how it drives hopefully problem solved I can't lose any sleep over the traction in the rain due to the fact I live in Seattle it is my every day Runner but it is what it is I would rather have my tires properly inflated . so they're 34 in the front and 30 in the back and I threw three tires in the rear of the bed. Thanks again brother love these forums. God bless
Old 10-12-2019, 07:59 AM   #14
MikeB
MikeB's Avatar
Every vehicle I've owned with 18"-20" wheels and 45-50 series tires called for 32-35 psi cold. And that was anywhere from a 3600 lb. Mustang to a 5200 lb. F150.
I'd start with 34 psi and then have your customer use a tread depth gauge to measure across the tread every 1000 miles or so.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-12-2019, 09:31 AM   #15
geezer#99
geezer#99's Avatar
Doesn’t matter what or how you drive in the right conditions you’ll spin the tires.
A little oil residue with moisture at our normal winter temps makes for slippery conditions.
Old 10-12-2019, 09:00 PM   #16
VWNate1
VWNate1's Avatar
You're welcome .
I've driven in Seattle and yes, it's slippery there most of the time . (try rural Western Wa. state for some hair raising fun) .
An old snow season trick we did in the 1960's was to buy a BIG scrap 1/4" thick iron plate that fir the length of the bed and barely between the inner fender wells so it didn't slide around, that'll work wonders as will a few bags of sand etc....
-Nate
Geezer
Old 10-13-2019, 01:12 PM   #17
UKNOWME
UKNOWME's Avatar
Too high of psi and you’ll wear the center on the tread down too quick. I’ve been running 28 psi in all my staggered 20s on many trucks for years and they wear evenly. The rating on the sidewalk is max psi for max load, not what is recommended for all applications
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 10-13-2019, 01:17 PM   #18
VWNate1
VWNate1's Avatar
Post Proper Pressures
Good trying to get the great unwashed to grasp this simple concept .
It's why chalking or paint striping the tires works best .
-Nate
"Too high of psi and you’ll wear the center on the tread down too quick. I’ve been running 28 psi in all my staggered 20s on many trucks for years and they wear evenly. The rating on the sidewalk is max psi for max load, not what is recommended for all applications "
-Nate
Geezer
Old 10-13-2019, 03:34 PM   #19
tino0217
Yeah, i have 3 fully inflated tires on the eear of the bed
Old 10-13-2019, 03:39 PM   #20
tino0217
Re: Proper Pressures
Like i said i chalked a line across the tires which shows if they're wearing in the middle or outside part of the tire. I don't have staggered tires but ended up with 30psi intge back and 34 in front. That was at cold temperature. I'm gonna check again today
Old 10-27-2019, 04:40 PM   #21
Ceeten
I run around 30
Ceeten is offline   Reply With Quote
Old 10-29-2019, 02:25 PM   #22
tino0217
the chalking worked, no problem
Old 10-30-2019, 03:28 PM   #23
VWNate1
VWNate1's Avatar
Thumbs up Re: 20 Inch Tire Pressures
See ? .
It's simple and works well .
-Nate
Geezer
Old 10-30-2019, 10:17 PM   #24
tino0217
I've shared it family members and my friends
