#51 |
Re: Project El Viejito, '66 C10 LWB BBW Build
Onto the next task which was connecting the Lokar shift linkage from the trans to the shifter, runs through all the gears and no interference.
Finally I could start cleaning up the dash and getting the Dakota Digital gauges put in place.
Chuck Instagram: c_lo_garage Check out my 1966 C10 project "El Viejito" here: http://67-72chevytrucks.com/vboard/s...d.php?t=674614 |
#52 |
Looking good, you're on the home stretch. I am envious of your progress!
#53 | |
I'm pretty stoked to be able to sit in the truck and start it up though. I've been double checking things and crossed off 90% of the items on my punchlist. The couple items that are left, don't keep it from driving. I'm looking forward to this weekend as I'm going to load this up and take it to the C10 Intervention show that's going on in Nor Cal. I didn't have time to get it road ready, so I'll focus on that after I get back from the show. I will be able to back it off the trailer and drive it into the show.
#54 |
![]() Join Date: Feb 2009
Looks good! your making great progress and will be really happy you ls swap your truck. I just completed mine. I'll be at the intervention also. i'll have to come by and check it out.
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors 2007 chevy 2500 hd 4x4 duramax |
#55 |
Before I could finish the rear brake lines, I had to have the rear end gone thru. I got new seals and bearings, there was fluid leaking from the pinion. Also I got a new kit to make the rear brakes new.
Pulled the axle and got it cleaned up, painted and made new again. Then it was time to fish it back under the truck which was difficult, thanks to the fuel tank in the way. Also, the back set a little high for me, so on top of the 6" lowering springs I added a 1" drop block
#56 | |
I'll be sure to keep an eye out for your build at the show. I heard there was a cruise on Sat, know anything about that?
#57 |
Yes, there is a cruise on sat from 2-5 and if your registered it tells on the paperwork you received about were you start and end. Then at night there is a mixer they call it at crooked lane brewery after the cruise. Let me know if you need the start and end point of cruise and I can check on my paperwork when I get home and give it to you.
#58 |
Just read through the build, nice truck! Any updates?
#59 |
This message is for LH Lead Foot:
It won't let me send the message because you're at max capacity for messages. Good morning LH, I apologize for the delayed response. I haven't logged in here in a while. My 66 is lowered about 4/6 and I used the GM oil pan for F Bodys that I purchased from Dirty Dingo. There was no dipstick hole on my particular block for the dipstick. I had to drill a hole thru a provision on my block, I can't remember the size of hole I had to drill, but I found the information online. I believe I had a thread on here regarding that. My engine is a pullout from an 03 Envoy, it's the aluminum block/heads. So my original oil pan had the hole thru it for the 4wd axles and the sump was at the front. I needed to purchase a new oil pan anyway. My plans are to eventually have the truck on airbags, so the F body works perfect for that. I also purchased from Dirty Dingo their LS adapter plates that have 4 different engine placement locations. Here are the part numbers for both items I bought from Dirty Dingo, hope it helps. 1 x Complete Oil Pan Swap Kit for LS1 Camaro / Firebird (F-Body) (DD-LS-OP-CAM) = $349.99 1 x Dingo Double-D 3/8 Steel LS Adapter Plates (DD-LS-DOUBLE-D-S) = $59.99 Let me know if you have any other questions and I'll help if I can.
#60 |
Thanks a lot Old Soul, I haven't checked my thread in a while, so it's behind on updates.
I was able to trailer the truck to the C10 intervention show last September (which was my goal). Now the truck is legal and I've been driving it around and enjoying it like I always wanted. I'll try to update this thread with more photos, but here's a picture from a few weeks ago rolling into a show.
#61 |
The small things I done to the truck lately are added hinges and latches to remove the chains for my tailgate. I temporarily added a roll pan to the bed. The front end now has a POL sway bar and I've started changing out all the weather stripping.
Up next on the to-do-list is to put a bed floor back in, as it's currently totally open.
#62 |
Right on, awesome picture! That can't be the only one ya got!!
Also, what size rubber did you end up with? Love the look.. I'm working on installing a similar drop right now.. 4.5/7 but sticking with 20s, those 22s do look killer though! Wish I could find a set of transits, they're tough to find. Where'd you score your set from? I've tried several dealerships near me and none sell them because of a core price. I've even asked what their core price was and if they'd be willing to sell me a set if I paid their core price, no dice. |
#63 | |
As for my truck's setup, my stance is just like yours. I'm running a 2" lowering spring in the front and 2 1/2" drop spindle. In the rear I'm running a 6" lowering spring and 1" block. I'm running a 265/35/22 on all 4 corners, I wanted as much sidewall as possible without too big a diameter wheel.
#64 | |
#65 | |
#66 | |
I believe the transits are 22x9, the 265/35/22 fits the rim perfect, but maybe somebody else could verify that. I couldn't even tell you the backspacing, as they only come 1 way unless they are modified, which they weren't. I do know that they are almost the perfect backspacing if the truck gets bagged. The rears clear the bedside and the fronts are tucked in nicely. If I ever take the wheel back off, I'll measure the backspacing and post it here.
