09-12-2019, 03:35 PM | #1 |
350 with hydraulic clutch?
Is anyone running a hydraulic clutch on their 350? if so how hard was the conversion and what product did you use? Im doing a auto to manual conversion and feel the hydraulic clutch and bellhousing would work better that the original type set up. Thanks for your time
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR" |
09-12-2019, 03:43 PM | #2 |
All about them K’s
Re: 350 with hydraulic clutch?
Several of us do. I used a captainfab master cylinder mount and clutch pedal linkage, with a gm slave and luk clutch from NAPA all in an aluminum 80’s sm465 bell housing. There’s pictures of my setup in the link in my signature look starting around page 5 or 6.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
09-12-2019, 03:58 PM | #3 |
Nothing works better than original
I BELIEVE IN JOHN 3:16 |
09-12-2019, 04:07 PM | #4 |
Thank you so much!
09-12-2019, 04:09 PM | #5 |
Another quick question, will that bellhousing work with a 4 speed Saginaw transmission?
09-12-2019, 04:46 PM | #6 |
All about them K’s
That I can’t answer for you, unfortunately I’ve only messed with the 465’s.
09-12-2019, 06:22 PM | #7 |
The center hole where the front bearing retainer goes is smaller on the saginaw. I don't remember if anyone makes a sleeve or not.
09-12-2019, 06:23 PM | #8 |
Why run that old non syncro 420..................get a sm465
09-13-2019, 02:09 AM | #9 |
Location: Herculaneum MO (20 minutes south of St. Louis
OP stated that he had a Saginaw. SM420 is a Muncie & the only non synchro gears are granny low and reverse
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
09-13-2019, 07:43 AM | #10 |
A car bellhousing or truck 3 speed works with the Saginaw 4 speed. I think both Novak and Advanve Adapters make register rings to fit the car trans to the truck large bore bellhousing.
