Old 09-29-2019, 11:53 AM   #1
roll_the_dice
roll_the_dice's Avatar
Quick, dumb EFI Fuel Filter question
OK, I am going to run my fuel lines for my system today (hopefully). I am using FiTech EFI system with an in tank fuel pump...so I will have a return line. I have the fitech fuel filter.
I know in a conventional carb setup it is close to the carb...I can't find anything for an in-tank pump setup for the Fitech...only with an inline pump or their command center.
My question is...
Does it matter where in the fuel line it is? Do I put it close to the gas tank or in the engine bay? Or anywhere that is convenient?
roll_the_dice is offline   Reply With Quote
Old 09-29-2019, 01:36 PM   #2
nsb29
nsb29's Avatar
Re: Quick, dumb EFI Fuel Filter question
In a convenient location away from exhaust
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 09-29-2019, 02:16 PM   #3
slepysal
slepysal's Avatar
On the frame would work.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-29-2019, 03:29 PM   #4
Rickysnickers
I too will be running some fuel lines for an in tank pump. From what I've read, you can put it anywhere in the supply line you want. As someone said, keep it away from heat and also moving parts.
Old 09-29-2019, 03:49 PM   #5
roll_the_dice
Thanks guys...Much appreciated.
I think I will tuck it on the frame under the drivers side door. Fairly easy to get to if I need to or when I have to replace it.
Old 09-30-2019, 05:58 PM   #6
Clyde65
Clyde65's Avatar
I ran mine for my LS from tank, inside the driver side frame rail and then across the trans crossmember, then up the trans to the motor.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-01-2019, 09:29 AM   #7
roll_the_dice
So your fuel line goes from the rear down the drivers frame rail...then across the trans crossmember and up the trans to the back of the engine to the EFI?
Sounds like a good way to run it...I started mine yesterday down the drivers side frame in the engine bay and up to the EFI...
I tucked the filter in the frame right where the bed starts behind the cab...should be an easy location to get to if need be.
