Old 10-27-2019, 12:12 PM   #1
65chevysub
65chevysub's Avatar
Utility box removal
Hi everyone. I'm looking at buying an 84 C20, with a utility box with liftgate, and if I get it, want to replace it with a standard longbed. ( I don't want a short bed). I ve looked on YouTube, and did Google searches but can't find out how to do it except on new trucks. Can anyone help me with this?
TIA
65chevysub is offline   Reply With Quote
Old 10-27-2019, 01:44 PM   #2
Re: Utility box removal
I have seen them mounted with the just the outer four stock location bolts and the factor 8 bolt holes. More than likely it uses the front 2 bed mounts and the 2 rearward ones. That is the setup I have seen most. Once they are off, disconnect the fuel filler tube and the wiring for lights, then it just lifts off like a factor fleetside bed.
Old 10-27-2019, 02:44 PM   #3
65chevysub
65chevysub's Avatar
Thanks. I should be able to drop a long bed on in place of it, right?
Old 10-28-2019, 10:37 AM   #4
Honest Bob
Honest Bob's Avatar
Depends on if its a cab and chassis or a regular pickup frame. A regular pickup bed on a cab and chassis will end up with a couple inch gap between the cab and bed.
Honest Bob is offline   Reply With Quote
Old 10-28-2019, 10:53 AM   #5
65chevysub
65chevysub's Avatar
Is there a way of telling by looking at it, or only if I remove the utility box?
Old 10-28-2019, 11:00 AM   #6
rpmerf
rpmerf's Avatar
Should be able to look at the VIN to determine if it was sold as a pickup or cab and chassis. I don't know the digit or code to look for though.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-28-2019, 12:02 PM   #7
maxx442a1
IIRC it is 56" from the back of the cab to the center of the axle on a regular pickup and 60" on a C & C.
maxx442a1 is offline   Reply With Quote
