Old 11-09-2019, 03:14 PM   #1
jimbosprint
jimbosprint's Avatar
Cold Case radiator for '67-72
I needed a new radiator for my '72 C20, and in my research on this forum I came across Cold Case radiators. I don't like the way most aluminum radiators look boxy and don't have a stock appearance, and this Cold Case radiator was perfect for my truck for that reason. The large 2-row design is also interesting. I reached out to a company rep who offered a discount if I would write this thread with the install and review.
Here are some pics of the Cold Case and my old factory 2-row:
jimbosprint is offline   Reply With Quote
Old 11-09-2019, 03:18 PM   #2
jimbosprint
Re: Cold Case radiator for '67-72
The radiator showed up yesterday and I installed it today. Install was easy. It fits decently in the factory brackets, though it doesn't quite sit in the rubbers the same as a factory radiator. My only comment for the engineers would be to angle the lower radiator hose up a little more away from the frame.
I will update this thread with a review after I get a chance to run it a little.
Old 11-09-2019, 03:41 PM   #3
HO455
HO455's Avatar
What part number did you receive? I tried a Cold Case and was unsatisfied with the fit of the radiator and returned it. This is a link to my repair thread scroll to post 333 for the start of the radiator story. I hope you have a better result than I did.
http://67-72chevytrucks.com/vboard/s...698377&page=14
RIP Bob Parks.
Old 11-09-2019, 06:05 PM   #4
jimbosprint
The part number is GMT558A. I read your thread before I ordered this and I was a little worried about the fit, but this one fit as well as any other aftermarket aluminum radiator that I've seen. The tanks are 3", the same width as my original radiator. They just don't have the seams that go into the rubbers like the factory radiator.
Old 11-09-2019, 08:11 PM   #5
jimbosprint
Test drive went well. I have a 180 degree thermostat in the truck and the temp gauge never gets up to the middle.
Old 11-09-2019, 11:56 PM   #6
HO455
HO455's Avatar
Good to hear things are working properly.
RIP Bob Parks.
Old 11-10-2019, 05:49 AM   #7
my kids toy
The cold case rad for LS motors is one not to purchase
my kids toy is offline   Reply With Quote
Old 11-10-2019, 11:26 AM   #8
robs71
robs71's Avatar
The installation looks good,factory shroud makes a nice job...just to give Cold Case a plug...we picked one up this summer at a Carlisle show in Pa for my sons 540 hp small block 427 in his 67 nova..bolted right up...we have a 195 degree thermostat in it and it runs right on that even in 100 degree heat.
robs71 is offline   Reply With Quote
Old 11-10-2019, 02:29 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Thanks for the post. I was hoping you were installing in a truck with a small block and A/C as I have to do something with my rad and been going back and forth whether to go aluminium or get my original redone. I see your point about the lower rad hose connector should be angled up a touch more. I like the look of it in the truck with the shroud installed. If the top part of the rad that shows was painted black it'd look pretty close to factory.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-10-2019, 03:52 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
I put in a CC radiator with no issues that I recall. But then I already had a 4-row brass job from the factory. I had issues with the fan and the shroud from before that installation. I bent up some aluminum and made my own new shroud.
~Steven
Simi Valley, CA
Old 11-10-2019, 03:58 PM   #11
Already Gone
How long have you been using it now, mileage too if possible, and I would assume you've had no issues or you would have mentioned them.
Old 11-10-2019, 07:48 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
My truck mostly sits. The radiator has been in it for 14 months. No idea on mileage. Certainly less than 1000 miles, anyway.
~Steven
Simi Valley, CA
Old 11-11-2019, 04:23 PM   #13
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I tried it...twice...sent them both back, but mine was for the LS swap.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-12-2019, 12:39 PM   #14
Andy4639
Old member
Andy4639's Avatar
I bought 5 aluminium radiators so far off E bay from CHR racing. 3 of them are for C-10's 1 for the 64 SS Impala and my dad's 56 Bel Air. All of them are nice units and are welded together no plastic. The one in my 71 C-10 has been in it for 6 years now. They are all less than $200.00. They all where for Auto so they have the trans cooler in them. This last one was $120.00 and it has the angled up lower hose mount as well. No problems at all with them.
Only problem I had is this last one came in damaged. Last week, the box looked as though they threw it around. I sent the seller pictures of it and they sent me a new one no problems, should be here tomorrow. The box had staples but none of them where holding anything together. It had 1 band around it in the middle of the box that was keeping the box together.
He told me to keep this one. This wasn't the seller's fault I don't think but he made it right with no qestions asked. In less than a week I will have another one if it shows up tomorrow like the tracking say's.
So I took a block of wood and fixed it. I will put it up and have it for a back up if I need one later on.
Before & after:
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2019, 05:30 PM   #15
Already Gone
Before & after:
So Andy no fitment problems and they bolt right in? What I like is you said you've had one in your C10 for 6 years and I know yoiu drive it lots and have been on the Hot Rod Power Tour with your C10 and its usually super hot on the HRPT.
Old 11-12-2019, 05:58 PM   #16
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Cold Case radiator for '67-72
Mine in the 71 C 10 is not a factory drop in. It did require some work for it to be bolted in but over all it's not bad. I use the heavy duty black foam to sit the radiator on in the bottom.The one in the ramp truck is 3 years old. It is using stock hold downs. It's not a perfect fit but it works fine. This one is going into the 68 step for my daughter.
To keep from hi jacking this thread PM me if you want anymore on it.
Old 11-19-2019, 01:15 AM   #17
Already Gone
What was indoor truck originally, a 3 core or 4 core rad?
Old 11-19-2019, 01:33 AM   #18
jimbosprint
I just looked and the old radiator that was in my truck when I bought it was a narrow 3-row. It was so skinny I thought it was a 2-row.
Old 11-21-2019, 06:06 AM   #19
Already Gone
Thanks for the info.
Old 11-08-2021, 06:37 AM   #20
mcmlxix
Collector of Projects
mcmlxix's Avatar
So how about a long term update? Any issues?
Rich
1972 K5 Blazer CST Click HERE
Old 11-08-2021, 05:05 PM   #21
jimbosprint
I sold the truck, but as far as I know the new owner has not had any problems.
radiator
