#26 |
Re: Need Advice! Do I Need a New Camshaft????
It's covered in assembly lube and you're seeing the teeth that got damaged. Like I said, the gear is ACDelco 10456413. It's the right gear though.
#27 |
Gawd dayum you're right. How the hell did I do that?
#28 |
#29 |
I have no earthly idea how I did that or how I never caught it this whole time. This is one of those moments that you hate putting it online and gotta tuck your tail between your legs lol but we all make really stupid mistakes when working on cars. If anyone here says they haven't done something stupider, they are either lying or never worked on a car. One of those mistakes you'll never make again. Thanks everyone
#30 |
Pics say a thousand words, even if they are bad words..... glad you know what happened. move on....
#31 |
#32 |
I’m talking complete new dizzy with the gear installed wrong.
Mallory dual point. 30 years ago. |
#33 | |
#34 | |
Sorry, didn't read up far enough before I responded .... yeah, I've got a loooong list of upside down, backwards, wrong size, lost pieces confessions.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! Last edited by RustyBucket; 11-10-2019 at 11:53 PM. |
#35 | ||
"I ain't nobody, dork."
Learn from your mistakes... I'm 51 and still learnin' too.
![]() Gary
#36 |
Now that we know what went wrong, do you guys think that this lends itself more or less now to the cam being chewed up too bad to keep running it?
#37 |
I'd pull it and post up pics of it next. Youve gotten this far, so fix it right and don't just let this thread die. I say you gotta document the repairs too.
#38 |
I believe you indicated you loosen the oil pan and tried to remove it but could not based on the clearance to the frame. How confident are you on resealing the pan gasket with the clearance issue. Most of the time the oil pan will be a leaker, no one needs a leaker.
#39 |
Hopefully you have a hoist/crane to lift the block a bit to get the pan fully off and make room to do the gasket cleaning/replacement. Now is a good time to find a camera and inspect your cam dist drive gear. Either that or pull it out. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#40 | |
#41 |
I guess you didn't understand how I described how I do it.....my process works great for me, I use the dizzy to turn the oil pump shaft.... its the old lift and turn the rotor method, been doing it for years like back into the 60's.
#42 |
![]() Join Date: Sep 2014
YoungPups method works perfect......If the the dist body is not seated tight on the intake you are not tight like prom night. The engine will run fine but NO oil pressure if you do it wrong.
#43 | |
I always used a long screwdriver to turn the shaft. |
#44 |
I just dont like telling people to stick a screw driver down into the engine. If this process works for you and you always used a screw driver to align the oil pump. Great stuff
But its Bad enough the dizzy gear gets installed wrong Plus bumping the starter to destroy the dizzy gear and maybe the cam gear. Cant imagine what could happen if something got dropped into the intake. Geee now what ? |
#45 |
It's pretty hard to lose a 16" screwdriver down the distributor hole.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#46 |
And its really hard to put the dizzy gear on backwards too but sh$t happens
Posted via Mobile Device |
#47 |
#48 |
Hey Geezer. Can you explain what “DF” means ?
So i guess this the way people get treated in this forum. Looks like i will be the one suspended. Poor soul.....hope he gets help !!!! Last edited by YoungPup1977; 11-16-2019 at 12:17 PM. |
#49 |
#50 |
I have thought of taking an old distributor and grinding the teeth off the gear. You could just drop it in and turn the rotor where you want it. You could also use it to prime the oil pump.
I just don't pull the distributor enough to make it worth my wild so I use a screwdriver. |
Tags |
camshaft, distributor, gear, rebuild, sbc 350 |
