Old 04-04-2019, 12:11 PM   #326
Beach-Burban
Beach-Burban's Avatar
Re: What did you do to your Suburban Today?
Originally Posted by iriereggaeman View Post
#Beach-Burban
Lookin' good! I have the same mirrors. They work well for me but probably won't have the same rear-view your big ones had. (more turning your head to double-check)
I had a problem with the mirror on the passenger side - the existing holes didn't allow clear sight of the mirror from the driver's seat. I had to shim up the bottom a bit to get it to work.
Thanks iriereggaeman...Even "tucked-in" those big ones vibrated badly and were starting to tear-up the passenger side door. Besides, with the size and color of "OUR" Suburbans...other drivers will make room!
http://67-72chevytrucks.com/vboard/a...1&d=1554393056
Passenger door has been bulged-out at the holes and it crackled the paint on the top three...but I've got some fitment issues with this side as well due to previous repairs by original owner. Entire drivers side has never been hit and is super straight. May be the reason he put on the large mirrors???
Woody
Beach-Burban is offline   Reply With Quote
Old 04-23-2019, 06:51 PM   #327
Beach-Burban
I got a little more ambitious today...thought I'd quickly pull out my grill to clean-up a few things, and boy, did that turn into a can of worms! The bright side after taking off much more than I thought I would have to, I can easily access my radiator core support body mounts that I received from GMC Pauls. Unfortunately, the Body Mount Kit is back-ordered!
Woody
Old 04-23-2019, 07:05 PM   #328
Beach-Burban
Question for those more knowledgable than me...is the grill surround normally pop-riveted in place as mine was?
Woody
Old 04-23-2019, 08:44 PM   #329
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Woody
Woody
It has likely been changed out at some point. They are riveted from the factory but not with that style pop rivet. Factory ones have no hole.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 04-24-2019, 01:00 AM   #330
Beach-Burban
Originally Posted by richard2717 View Post
Woody
Richard
Thanks Richard...now I don't have to search for the right screws...when the time comes, i'll just pop-rivet it back together.
Woody
Old 04-24-2019, 08:21 PM   #331
Beach-Burban
Did my radiator core support frame cushions today...took a while but pretty straight forward. Side by side shows how compressed the upper cushions were. 20 years ago, the original owner must have taken the easy route as the bottom cushions appear to have been changed before, but not the uppers or bolts!
Woody
Old 04-24-2019, 08:25 PM   #332
richard2717
I started on my body mounts as well but decided to go the long route
Members I have met.
Old 04-24-2019, 08:40 PM   #333
Beach-Burban
Here's the finished product with a little black paint added to hide the "Never-Seize" that gets everywhere!
Woody
Old 04-24-2019, 08:44 PM   #334
Beach-Burban
Those are gonna be some tall mounts, Richard...
Old 04-24-2019, 09:04 PM   #335
Beach-Burban
A bit of advice...if your radiator core support cushion set comes with square washers that look like these, don't use them. The square hole is a little bit too large and the carriage bolt shoulder spun inside of it. The hole in the original washer fit the shoulder of the new bolts perfectly. Also, the originals have the square hole "off-set" for a reason...which is to keep the entire washer from spinning around. I had both problems while I was assembling the first side ending up doing it 3 times. Use the original square washers to avoid this issue.
Woody
Old 09-17-2019, 12:16 AM   #336
Waders
Waders's Avatar
Today I decided it is finally time to put the body back on the frame.
71 GMC swb 4x4 ...sold
72 suburban "family cruiser" in progress
67 chevy blazer truck
59 Chevy belair 2dr-high school sweetheart
Waders is offline   Reply With Quote
Old 09-24-2019, 01:26 PM   #337
fourspeedwagon
fourspeedwagon's Avatar
Not sure I drove mine in 2018 and definitely didn’t in ‘19 yet.. but, DW’s late model possibly blew a head gasket yesterday (radiator overflow can full of oil) so she’ll need to use my daily, which means the ol Sub gets duty. A little time on the charger and a couple dribbles of fuel down the carb and whammo! Running and not sounding too bad. Topped off the air pressure, evicted an army of spiders and started a basic pre trip inspection. We’ll know by tonight if it works out as well as hoped
1951 GMC 250 Open Express Pickup
1968 Suburban C10
1971 C20 Olive
“People are shocked when they find out I’m not a good electrician”
Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it”
fourspeedwagon is offline   Reply With Quote
Old 10-01-2019, 05:04 AM   #338
Average Joe
Average Joe's Avatar
Sucks about your late model pukin a head gasket but happy to hear your old Burb will see some miles. Did ya have any luck with the seat swap?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 10-05-2019, 11:44 PM   #339
Waders
Waders's Avatar
The body is finally back on the frame! Best of all, I freed up space in my garage so I can park in there this winter.
Now I'll be back to metal work.
Probably time to start a build thread...
Old 11-13-2019, 05:53 PM   #340
Beach-Burban
Finally put new seatbelt in...six out of the nine being 3 point shoulder straps for the grandkids! The belts will be coming out again when I replace the carpet and have the original seats reupholstered...so I'll paint the brackets at that time...but for now, they're working great!
Woody
Old 11-13-2019, 05:58 PM   #341
Beach-Burban
Old 11-13-2019, 05:59 PM   #342
HO455
HO455's Avatar
How or what did you use for an anchor for the top of the three point belts?
RIP Bob Parks.
Old 11-13-2019, 05:59 PM   #343
Beach-Burban
Old 11-13-2019, 06:47 PM   #344
Bigdav160
Bigdav160's Avatar
I never thought of mounting the retractors there. I haven't mounted mine yet.
I mounted the front one's to the lower part of the B-pillar
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-13-2019, 10:50 PM   #345
Beach-Burban
My fronts already had the retractors installed by PO which made that part of installing the new ones a lot easier because he used really nice "L" brackets that I reused. They mount to the floor between the "B-pillar" and inline with the seat back...but they appear to use a factory mounting point as the nut under the frame seems to be factory welded in (???in case someone ordered optional 3 points up front???). The retractors mounted with different amounts of difficulty depending on which row of seats I was working on...with the middle row being the hardest (shorter seat brackets)...but all in all, it was pretty straight forward.
Woody
Old 11-13-2019, 11:09 PM   #346
Beach-Burban
The top rail has plastic plugs threaded into the seatbelt anchor points exactly where they are needed...as does the "B-pillar". The seatbelt vendor knew exactly which bolt thread to supply as well as the bolt being "shouldered" for the top swivel and perfect length/fit. The vendor said in all his years, he had never seen any '67 to '72's with optional 3 points installed by the factory, yet they were set up for them! Lucky us!!!
Woody
Old 11-14-2019, 10:53 PM   #347
HO455
HO455's Avatar
Woody
Attachment 1957901
That is one nice addition that my 67 doesn't have. Definitely lucky for you. But less than optimal for me as not only dont I have the nice attachment points you do I also didn't learn any cool trick to get them attached either.
Maybe you have a late run truck that was pulled in to engineering to do testing.
Congratulations on your nice easy installation it looks good.
RIP Bob Parks.
Old 11-15-2019, 02:10 AM   #348
Beach-Burban
Wow...now I want to know when they started readying burbs for the 3 points? Maybe a new thread entitled: Does your Suburban have anchor points in top rail? If so, what year?
Wish I could help you figure out how to get those anchors up there! Seems like a lot of work, though!
Woody
Old 11-15-2019, 10:18 PM   #349
aerotest
Mine has factory shoulder anchor points for all three rows.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 11-15-2019, 11:23 PM   #350
HO455
HO455's Avatar
Oh great another show off !!
And no mention of what year either.
RIP Bob Parks.
