Old 11-17-2019, 07:11 PM   #1
hubdawg
Top crack repair
Wondering if the best fix for these joints is seam sealer
hubdawg is offline   Reply With Quote
Old 11-18-2019, 05:28 PM   #2
hubdawg
Re: Top crack repair
Bueller.......Bueller........Anybody? trying to do this week and really trying to do it right...lol
Old 11-18-2019, 08:47 PM   #3
truckster
truckster's Avatar
I'm not a bodywork expert, but I think the answer would be that seam sealer would be a temporary fix at best. The top is made of SMC (sheet molded composite, similar to fiberglass) and what you're seeing is a structural defect. Seam sealer isn't meant for structural problems.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 11-18-2019, 09:47 PM   #4
litebulblsc
litebulblsc's Avatar
Those are factory seams. What ever they used, is cracking out. The other common place i found for this to happen is in the gutters. I am of no help on the correct fix.
litebulblsc is offline   Reply With Quote
Old 11-18-2019, 09:57 PM   #5
truckster
truckster's Avatar
You might try the paint and bodywork subforum.
Old 11-19-2019, 12:51 PM   #6
hubdawg
I'm thinking grind the old sealer out and recoat with new seam sealer and re-raptor the top. Definitely not structural just where the top was seamed at the factory, years of on and off probably pushed the 50 year old product to it's max.
Old 11-19-2019, 02:32 PM   #7
A1971Blazer
A1971Blazer's Avatar
grind and feather out the seam and repair with stranded fiberglass epoxy filler
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-19-2019, 04:37 PM   #8
hubdawg
Got a heads up from a local guy who recommended PC 11 marine epoxy which can be sanded and painted. I'll let you know how it turned out
Old 11-19-2019, 07:57 PM   #9
truckster
truckster's Avatar
Originally Posted by hubdawg View Post
Definitely not structural...
The seams on SMC are structural. It's where two pieces of molded composite were joined together. Look at the curve at the top of the window and you can see a crack around the radius.
Old 11-19-2019, 08:13 PM   #10
litebulblsc
Probably not corrcect to call it not structural. But the "crack" at the window is still just the seam opening.
Old 11-19-2019, 09:00 PM   #11
truckster
truckster's Avatar
I wasn't talking about the seam. It looks like there's a small crack that's around the radius of the window opening. The red lines point to what I'm talking about.
Old 11-27-2019, 02:26 PM   #12
rayray767
Following
rayray767 is offline   Reply With Quote
