Old 11-21-2019, 02:03 AM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Power Steering Pump fitment probs on LM7 5.3 K10 swap
I'm in the process of swapping a 5.3L LM7 into my 1970 K10. I was planning to use the stock 5.3 PS pump and stock PS/Alt accessory bracket. I'm having a problem with fitment of the PS pump. The low pressure line hits on the frame. Anyone else have interference problems with the PS pump? I don't really want to try to bend that line in fear of damage. I'm wondering if there is a different style pump that would work with the stock accessory bracket. Any help would be appreciated.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 11-21-2019, 04:10 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Power Steering Pump fitment probs on LM7 5.3 K10 swap
are you referring to the return line?..got a pic?..trying to picture in my mind where its hitting
what engine mounts are you using? maybe you could raise the engine up some...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-21-2019, 10:00 AM   #3
ls1nova71
ls1nova71's Avatar
I just carefully bent mine, but my engine may be in a different position than yours, so it may not have been as close.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-21-2019, 05:00 PM   #4
derotoreut
derotoreut's Avatar
So I tried to bend it a bit. I can't really go any more. As it is my line will be coming out right behind the PS pulley.
I bent this line and only have about 1/8" clearance from frame. When engine is running it will probably still hit.
Name:  Steering pump1.jpg
The line is now directly behind where pulley will go.
Name:  Steering pump2.jpg
~ Dan
Old 11-21-2019, 05:16 PM   #5
mongocanfly
I bent mine to point out a little...but mine is about 2in above the frame rail
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-21-2019, 07:07 PM   #6
First c10
First c10's Avatar
Hey Dan, I messaged mine to make a tighter curve off the pump. I have about a good inch clearance from the frame. My motor is pretty solid and I don't think it will ever move enough to hit. I also rotated the curve to point more to the fender to avoid the pully. I will try and get a picture but may be this weekend before I get it.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 11-21-2019, 07:59 PM   #7
derotoreut
derotoreut's Avatar
Thanks for the information. I look forward to seeing pictures when you have a chance.
~ Dan
Old 11-21-2019, 09:09 PM   #8
truckdude239
truckdude239's Avatar
can you not bend it down so its down between the frame its just rubber return hose
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-21-2019, 10:03 PM   #9
derotoreut
derotoreut's Avatar
Dave, I thought about doing this. I may still try. I really like the idea of having the line between the frame anyway. I'll let you know if I try it.
~ Dan
Old 11-23-2019, 09:28 PM   #10
derotoreut
derotoreut's Avatar
I decided to bend the PS pump line down so it would fit between the frame rails. Should be good now.
~ Dan
Old 11-23-2019, 10:12 PM   #11
mongocanfly
That should work..!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-24-2019, 11:28 AM   #12
First c10
First c10's Avatar
Sorry dan I have been working and haven’t got a chance to get to my shop for a pitcture.
Looks that in the rail looks fine. My motor might sit higher then yours since my line is above the rail.
GO GO!!!
