Old 12-05-2019, 11:47 AM   #1
underliner6
underliner6's Avatar
Going back to OE Steering Wheel
After searching, I see many threads on going from an OE steering wheel to an Aftermarket but not the other way around.
Can anyone tell me what is needed to replace the old grant wheel in my truck with an original steering wheel? Do I need a new OE steering wheel mounting kit?
Thanks for any insight.
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
underliner6 is offline   Reply With Quote
Old 12-05-2019, 12:26 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Going back to OE Steering Wheel
If you buy a original type steering wheel no. The wheel has the mount made into it. You will need the horn cap and the parts that go inside the wheel to make the horn work depending on what year steering wheel you end up with. My pictures are of a OE 70's model steering wheel.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-05-2019, 12:57 PM   #3
underliner6
Thank you for answering my question and providing me the photos! I’m glad it’s that’s simple.
Jim
Old 12-05-2019, 01:02 PM   #4
Andy4639
Old member
Andy4639's Avatar
Your welcome,
Getting the right parts is sometimes the hardest part.
Putting them in correctly is also important. There are links to how they go in. Just use the search button.
Old 12-05-2019, 03:59 PM   #5
Baime
Jim,
I put an OEM 1967 steering wheel into my 71 C2500, and I really like it.
The fawn color even matches my steering column and glove box cover.
The horn hardware also fit right in.
Good luck. JP
1971 GMC C2500 LWB (My first truck.)
Baime is offline   Reply With Quote
Old 12-05-2019, 05:00 PM   #6
underliner6
Originally Posted by Baime View Post
Jim,
Good luck. JP
Looks awesome. IMO, you can’t beat the look of a period correct Chevrolet wheel in these trucks.
Jim
Old 12-05-2019, 05:55 PM   #7
flattie39
Junior Member
I agree - the look of the OE wheel is best in our trucks. If you want the OE look but would still like the extra leg room of an aftermarket wheel, Brothers has a new 15" OE replica wheel that works well.
Ken
flattie39 is offline   Reply With Quote
Old 12-05-2019, 06:32 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Andy is that the seldom-seen gasket on the horn cap?
Baime - greetings from next door in Eau Claire.
Old 12-05-2019, 08:04 PM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: Going back to OE Steering Wheel
It sure is. As far as i know it's original to.
There are other wheels out there that look good in our trucks at least I think so any way. Here are a few of mine.
67 Chevelle wheel in my 71 C10.
Then the old Corvette wheel that I made the horn cap for my 67 Ramp truck.
The 3 spoke wood wheel going in the 68 with factory tilt. I'll be making a 1 off horn cap for it as well.
Then 1 of the 2 spoke wooden wheels I have. All the horns work like they are suppose to also.
Old 12-05-2019, 09:36 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Here are the horn parts you will need. There are two different metal cups. The '67 & '68 is 1" tall and the '69-'72 is 3/4" tall. 2nd pic posted by leddzepp.
LockDoc
Leon
Old 12-05-2019, 11:59 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
My main issue with Grants was that one came off in my hands in traffic.
Funny stuff when Laurel & Hardy or the 3 Stooges do it, not so funny when it's _you_ and you're downtown. I stuck it back on and white-knuckled my way home. [I think they should be outlawed.]
But I was lucky, the PO had included the OEM wheel with the '71 Jimmy, when I bought it.
I put the stock 17" wheel back on and, for once, it handled better. Pulled thru turns perfectly, and pointed where I wanted it without a second look.
The Grant wheel was twitchy and had to be reclocked a couple times.
With manual steering, a small diameter wheel is a lot of extra work just making turns.
Also the larger diameter wheel gives you a lot more leverage when the P/S fails.
Grant wheels are for kids.
If you [or the PO] lost the original parts, The Car and Truck shops has a lot of the harder-to-find small parts.
I hear the repop steering wheels are not that good. Better to acquire an original wheel and repair it if needed.
Old 12-06-2019, 11:35 AM   #12
68 P.O.S.
That sounds like an installation problem, not a steering wheel problem I laugh cause I've done that to myself once. Wasn't paying attention and didn't put the nut back on before a long test drive. That made for a fun ride
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-06-2019, 11:37 AM   #13
Baime
I sort of cheated, because I like the earlier OEM steering wheels (67-69?) better than the original one that came with my 1971 truck. I was surprised how nice the older one fit, matched the interior, and the horn even works. The metal cup used with the horn button is a different height from the later version.
I would have left the original steering wheel in my truck, but it was all melted near the steering column. I'm assuming from the sun.
I really dislike the looks of the modern non-OEM looking steering wheels. Everyone's taste is different, and I think that makes it more fun.
My truck is a 3/4 long bed fleet side GMC. A lot of people don't want that version of these trucks. I call it a "truck truck". It isn't trying to be sports car. I just really like it, and it is usable.
Take care, JP
Old 12-06-2019, 02:18 PM   #14
71gmcC15
71gmcC15's Avatar
I also put a 67 steeing wheel in My 71 gmc. Fit just fine. Although it fawn and it should be black. My original looked like it whent through a fire. That was the firest thing I ever did to my gmc.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 12-06-2019, 02:55 PM   #15
underliner6
LockDoc
Thanks for the photos! I will not be using a horn in the truck and don’t care to hook it up. Will I still need those horn parts for the structural integrity of the wheel?
Jim
Old 12-06-2019, 03:43 PM   #16
Andy4639
Old member
Andy4639's Avatar
Question Re: Going back to OE Steering Wheel
NO!
It's not a good idea not to have the horn working though. It's not that hard to do. The wiring is already there in the column are it should be.
Old 12-06-2019, 04:42 PM   #17
69 customcamper
Ken
Do not buy that Wheel as it is dynacorn . Also brothers sucks for taking care of the customer . I bought one in July , installed it september , and the last bit of hot days we had gave it a nice big crack !! They will not respond to my emails and cant get them on the phone . Junk !! I have the same one on another truck I bought as an OER brand and its been 2 years not cracked same sun
Mike
69 customcamper is offline   Reply With Quote
Old 12-06-2019, 06:56 PM   #18
LockDoc
LockDoc's Avatar
Originally Posted by Andy4639 View Post
NO!
Actually yes, the cancelling cam (the piece with the white tower on it) holds the top bearing in place. It may be under the aftermarket wheel.
LockDoc
Leon
Old 12-07-2019, 09:31 AM   #19
underliner6
LockDoc
Got it! Thanks for answering my questions!
Jim
Old 12-07-2019, 10:23 AM   #20
palallin
Don't know about your state, but the horn is necessary pass inspection in MO.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 12-07-2019, 11:31 AM   #21
RustyBucket
RustyBucket's Avatar
I've always liked the look & feel of these Impala wheels.... '59-'60. Same diameter as stock(BIG) and fit the column nicely with no adapter.
PS: good idea to have a working horn... bad feeling as somebody looking the wrong way backs into my truck.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 12-08-2019, 02:02 AM   #22
'68OrangeSunshine
It was the PO's install.
Yeah, it's funny because I'm alive, and I can take a joke.
But the small wheel was a drag.
Old 12-08-2019, 02:14 AM   #23
'68OrangeSunshine
Right now, I have a Seafoam Green loaner wheel on my Orange '68 Stepside with Fawn interior. The original Fawn wheel is in my room getting puttied w/JB-Weld and sanded down, and will soon be repainted Fawn. When it's back on the '68, I'll give the slime green wheel the facelift treatment, and fix the cracks and paint it black and try it on my '71 Jimmy. I may even move the Wiper Switch to the left, and put a Manual Throttle Knob over the Choke, like on a '68. That way both my trucks will have similar dash set ups.
Old 12-08-2019, 09:09 AM   #24
underliner6
Fortunately no inspection on this side of the state.
Jim
Old 10-08-2020, 11:11 AM   #25
EagleChief
EagleChief's Avatar
So, I know this is an older thread, but I'm going through the same thing right now... even had started a thread asking questions just like this. And yes, I did use the search function previously, but didn't find this thread.
Anyway, I want to hook up my horn, but when I see the pictures the OP put up, I don't have the black wire that is shown. One of the previous owners of my truck, mounted a push button under the dash to use for the horn (which doesn't work). I'd like to get rid of that, and hook up the horn the way it should be. Does anyone know which wires I need to be looking for?
EDIT - I had the exact same Grant wheel as the OP in my truck. I'm putting in an '80's Chevy wheel in it's place.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
