Old 11-08-2019, 06:49 PM   #201
joedoh
joedoh's Avatar
Re: Jans 53
haha gorgeous!
I had a BMW friend who was married, he had some scheel seats in the living room and a M10 head with dual webers on the kitchen table. outside the driveway and back yard were FULL of projects. his wife didnt mind at all.
she lived one street over in her own place. he tried to fill up the driveway there with projects though and she had them towed to his place
edit: he is still at it. there are probably 10 cars in the back yard, and every bmw in the picture is his, from the blue one on the right to the green one on the extreme left and all up the driveway (the mini is built by BMW too)
Old 11-08-2019, 07:26 PM   #202
NorCalGal
NorCalGal's Avatar
Re: Jans 53
I am guilty of rebuilding a manual transmission on my kitchen island once (I did put plywood underneath to protect the tile). It was warmer and the lighting was way better than the garage.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 11-08-2019, 10:59 PM   #203
olcarguy
Re: Jans 53
Your truck is looking good Jan, soon to be driving down the road.
olcarguy is offline   Reply With Quote
Old 11-09-2019, 07:47 AM   #204
Jemezcrusher
Re: Jans 53
Originally Posted by NorCalGal View Post
Plugging along in the undercoating world. Last of the fenders done today, still have a lots of little painting projects to do on some brackets and core support. Thankfully the weather here is cooperating so far.
I used bed liner inside the fenders, under the cab, and also coated the running boards. I hope to drive my 50 regularly and don’t want to worry too much about rocks flying.
Should help reduce some road noise too
Jemezcrusher is offline   Reply With Quote
Old 11-12-2019, 09:21 AM   #205
reaper71
reaper71's Avatar
Re: Jans 53
You've done some really nice work Jan!
Mark
reaper71 is offline   Reply With Quote
Old 12-04-2019, 11:24 PM   #206
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Spent the day rebuilding my hinges. Think I’m going put a little blob of weld on the side of the pin after I cut and taper the end so it can’t ever back out while in the truck
Jan's 53
Old 12-05-2019, 10:10 AM   #207
youngrodder
youngrodder's Avatar
Re: Jans 53
I need to rebuild my hinges as well....I'm thinking of out outsourcing that task. Was it as much of a pain as most people say it is?
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-05-2019, 01:54 PM   #208
8man
Re: Jans 53
Where are the cover plates? I know you have them.
Keep it going!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 12-05-2019, 02:11 PM   #209
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Marc
Not bad at all, had to heat up the the hinges to knock out the pins, welded up the door spring holes and redrilled them to 15/64 then drilled out the hinge pins to 11/32 lubed with some never seize.
Jan's 53
Old 12-05-2019, 02:17 PM   #210
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Keep it going!
Yes Robert I saved myself a set. I think I’m going to drill my holes in the hinge and plug weld the plates on from the rear of the hinges
Jan's 53
Old 12-05-2019, 04:26 PM   #211
youngrodder
Re: Jans 53
Why are you not using the springs (cause the repop springs easily break)? The cover plates are a great idea. That is what is screwed up on most OE hinges. Who was reproducing them?
Marc
Old 12-05-2019, 05:01 PM   #212
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Marc
I’m using the springs but the spring holes on the hinge are worn out so I welded them shut and redrilled the holes with 15/64 so their nice and tight.
I made a form and stamped me and 8man a set. Since then I saw that the filling station has them.
Jan's 53
Old 12-05-2019, 11:20 PM   #213
joedoh
joedoh's Avatar
Re: Jans 53
beautiful work. you spend more time perfecting hinges than I do on most anything, there is something to be said for that kind of attention to detail! KUDOS!
Old 12-06-2019, 02:01 PM   #214
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Keep it going!
Here you go Robert
Jan's 53
Old 12-06-2019, 02:43 PM   #215
8man
Re: Jans 53
Those look great! Wish I'd thought to weld them from the back.
8man-aka Robert
Old 12-06-2019, 08:14 PM   #216
oldman3
oldman3's Avatar
Re: Jans 53
Very nice...Jim
oldman3 is offline   Reply With Quote
Old 12-06-2019, 08:45 PM   #217
olcarguy
Re: Jans 53
nice is right....
Old 05-11-2020, 08:47 PM   #218
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Sprayed a satin UreKem test color this weekend on an old fender I had laying around. It sprayed out great but not sure if I like it or not, thinking into the future I’m afraid it will fade over time into a pinkish red. Might look for a lighter color less prone to fade.
Jan's 53
Old 05-11-2020, 09:44 PM   #219
dsraven
Re: Jans 53
or just spray what you like and redo later if it it fades, haha
keep it indoors so less chance of fade
Old 05-11-2020, 11:38 PM   #220
NorCalGal
NorCalGal's Avatar
Re: Jans 53
I don’t know that I’ll have another paint job in me, all this sanding is hard on these old shoulders.
I can’t drive it around indoors.
Jan's 53
Old 05-12-2020, 09:34 AM   #221
8man
Re: Jans 53
Glad to see you back on the truck. The color looks good, but a little lighter could work too.
8man-aka Robert
Old 05-12-2020, 11:20 AM   #222
youngrodder
Re: Jans 53
The color looks great. I would even like to see it a darker shade. My friend painted his 2nd gen Camaro in a satin maroon/burgundy and I thought that it looked very cool.
Old 05-12-2020, 01:53 PM   #223
NorCalGal
NorCalGal's Avatar
Re: Jans 53
This is what I was going for, just not sure I want to deal with the downside of satin and reds.
Jan's 53
Old 05-12-2020, 02:51 PM   #224
8man
Re: Jans 53
That's a nice color. Shiny or satin, that's a personal preference.
8man-aka Robert
Old 05-12-2020, 02:52 PM   #225
mongocanfly
mongocanfly's Avatar
Re: Jans 53
I like the maroon...but I agree...there is a downside to anything buy gloss
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
