11-05-2019, 10:09 PM | #1251 |
Re: off it goes
If I remember correctly Cheyenne trim level would have trim rings without door pulls. Silverado trim level added the door pull straps.
Born and proudly residing in a Red State ! |
11-06-2019, 07:03 PM | #1252 |
Re: off it goes
11-16-2019, 06:03 AM | #1253 |
Re: off it goes
^^^^think
12-08-2019, 08:01 AM | #1254 |
Re: off it goes
So I have been holding off on posting pics of the motor in my truck just in case I had made it to Sema. But seeing as that never happened this year thought I'd let you see what we have been working on...
12-08-2019, 08:04 AM | #1255 |
Re: off it goes
inner fender install, getting lower parts of headers wrapped to keep heat away from paint...better safe than sorry
12-08-2019, 08:06 AM | #1256 |
Re: off it goes
Wilwood install, along with steering shaft cover
12-08-2019, 08:38 AM | #1257 |
Re: off it goes
I was definitely taken aback by the white and black engine! But I really like it!
Do you plan to remove the "wilwood" name from the master cylinder? It seems kind of glaring. Possibly paint the master cylinder lid in white?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
12-08-2019, 09:49 AM | #1258 |
Re: off it goes
Thanks man...we talked about Chevy Orange but it wasn’t period correct for this year of truck. From factory motor would of been blue which was definitely out with my colors. Then we talked brown to match interior which would of been cool but I didn’t want a ton of polished items in the motor so the brown with all black wouldn’t of had the wow factor...which by process of elimination brings us to White. I’m a neat and tidy detail freak so will have no issues keeping it clean, the motor has been fired and there’s not a drip anywhere.😃
12-08-2019, 09:32 PM | #1259 |
67-72 parts collector,…
Re: off it goes
Absolutely stunning.
12-08-2019, 10:20 PM | #1260 |
I have no time for this
Re: off it goes
I saw this on Kens IG page the other day but didnt think it was your truck because I didn’t see the cowl vent screens. I just noticed the bolt holes for them now. Your truck is bloody amazing.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
12-09-2019, 05:07 AM | #1261 |
Re: off it goes
thank you so much guys
12-10-2019, 03:39 PM | #1262 |
Re: off it goes
Good call on the white. It is certainly outside the norm and fits the truck well.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
12-10-2019, 08:49 PM | #1263 |
Re: off it goes
The white looks badass. Beautiful
12-10-2019, 09:39 PM | #1264 |
Re: off it goes
thanks
12-10-2019, 10:09 PM | #1265 |
At the body shop.
Re: off it goes
Sorta surprised the master cylinder didn't go in the dash or floor.
" That didnt make it any newer " " Dont antique the equipment " |
12-10-2019, 10:35 PM | #1266 |
Re: off it goes
no, still trying to keep it somewhat stock looking but in a much cleaner simpler way. I think sometimes the firewall can be to plain and bare looking if it has nothing on it
12-12-2019, 11:27 AM | #1267 |
Re: off it goes
Agreed. Same with tailgates using aftermarket flat panels....
12-12-2019, 12:09 PM | #1268 |
Re: off it goes
Exactly, some can look to plain...and then some guys can get to crazy with a bead roller and make stuff look to overdone. Just trying to stay somewhat in the middle
12-13-2019, 10:17 AM | #1269 |
Re: off it goes
Make it look like nothing has been done when a bunch has. You're too focused on the fact of how/why everything seems so tight & well fit that it takes someone telling you or several inspections to NOTICE the changes.
12-13-2019, 11:18 AM | #1270 |
Re: off it goes
Exactly
12-14-2019, 11:40 PM | #1271 |
Re: off it goes
Luckily my buddy owns a Hot Rod Upholstery Shop and he is just finishing up my seat and that will conclude all the interior, I kept it clean and classy...I think less is more on interior, just did a dark brown Relicate Leather with a tooled insert to match the door panels. Also decided to do something with the interior handles, a little sand and a quick polish brought them to life
12-14-2019, 11:45 PM | #1272 |
Re: off it goes
Beautiful work! And just think how easy it will be to narrow down where the oil leaks come from! Would never have even thought of a white engine - it looks gorgeous.
12-15-2019, 07:10 AM | #1273 |
Re: off it goes
lol,
motor has been fired....not a drop or leak |
12-18-2019, 09:59 PM | #1274 |
Re: off it goes
seat is all finished up
12-18-2019, 10:45 PM | #1275 |
Re: off it goes
That seat is amazing.
