12-03-2019, 08:52 AM | #1 |
Seat belts
Going to be buying myself a new set of seat belts for Christmas. I’d like to grab two new three pointers and a lap belt for the middle. Is LMC pretty much the way to go?
12-03-2019, 10:13 AM | #2 | |
Re: Seat belts
https://www.seatbeltstore.com/product-p/jugmm3p.htm. And I have good things about this place also https://www.wescoperformance.com/seatbelts.html
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
12-03-2019, 10:28 AM | #3 |
Seat belts
12-03-2019, 10:51 AM | #4 |
Re: Seat belts
Don’t buy those, they do not have a cover over the retractor. I had these in my truck for about 4yrs, until I found a nice set of OEM belts to put back in the truck.
You can get them from here https://www.seatbeltstore.com/product-p/jugmm3p.htm
12-03-2019, 10:52 AM | #5 |
Re: Seat belts
Here’s another place
12-03-2019, 10:55 AM | #6 |
Re: Seat belts
I knew I posted once about this. Now I see why, you double posted the same question. Thought I was losing my mind
12-03-2019, 11:54 AM | #7 |
Re: Seat belts
TKCR - I have the same belts you posted in my truck. Do you find that the "short" side of the belt - the buckle side - is just way too long? I feel it is, the stock buckle side was much shorter than these replacements.
12-03-2019, 12:22 PM | #8 |
Re: Seat belts
Yeah they were, but they still worked. I know you can get different lengths on that side of the belt. I don’t remember what length I got, when I got these several years ago. And if someone should call before you order, they will make the adjustments. I found this out later. I called them about swapping the buckles, they were originally plastic, and I had them change them to the metal. The guy I talked too said any changes you want made to the belts, they could do that. And I should add, if someone has a sewing machine, that belt could be shortened up very easily.
12-03-2019, 12:27 PM | #9 |
Re: Seat belts
The OEM belts I found, did have an area were the belt was damaged. I just cut that section off and re-sewed it. So the same concept could be used with shortening up the belt.
12-03-2019, 01:13 PM | #10 |
Re: Seat belts
Thanks for this thread! Mine belts are totally thrashed and before I haul the kids too far I want to make sure they're good.
What about the mounting hardware (bolts?) The ones I have a definitely NOT the correct ones as they barely thread into the welded nut on the body. |
12-03-2019, 01:21 PM | #11 |
Re: Seat belts
There is a hardware pack that comes with them, or you can purchase separately. If you need some original bolts, I have some.
12-08-2019, 09:39 PM | #12 |
Re: Seat belts
Pry the @90 the bottom under the GM logo with small screw driver and med flat blade till it pops open. Sound like the spring clip pop out place or it broken you can fix the push button get nicer one put back together on the GM seat belts you can replace the webbing them to.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
12-08-2019, 11:36 PM | #13 |
Re: Seat belts
If your going for a bit of a custom touch. Aircraft style latches are a nice upgrade. I am using those on my Camaro project.
12-10-2019, 04:27 AM | #14 |
Re: Seat belts
I bought the LMC belts, and wouldn't do it again. Installation was so maddening that to this day I have yet to get around to the passenger side. For two years its been like that.
I figured the next time I would buy from these guys, someone posted this site awhile ago and they look pretty good. https://www.seatbeltplanet.com/produ...art/0/shipping
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
12-10-2019, 09:08 AM | #15 | |
Re: Seat belts
12-10-2019, 03:23 PM | #16 |
Re: Seat belts
I got my seatbelts from the SeatBeltStore.com, and yes the buckle side of the belt is way too long. I contacted them about getting a shorter one and was told that they were sold that length so that they wouldn't pull through the seat if you move the seat all the way forward. It bugs me some, but so far not enough to remove them and find someone with a sewing machine.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
12-14-2019, 03:20 PM | #17 | |
Re: Seat belts
Alex. |
