Old 11-11-2019, 07:12 PM   #201
Vic1947
Vic1947's Avatar
Re: 57 Chevy Wagon - Californa Dreamin'
Originally Posted by mongocanfly View Post
yep....the easiest way to find something I misplaced is to buy a new one...then the old one mysteriously appears outta nowhere...
Originally Posted by Ol Blue K20 View Post
Nice smooth firewall. The column looks good too...I thought I was the only one that had that problem with lost parts.
Misplacing a part is only half the story. The thing that really gets me is how I can drop a small piece of hardware and it just vanishes into thin air. It may or may not reappear at a later date, but at that moment it's gone as if it never existed as soon as it leaves my fingers - no matter how far out I extend the search radius.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 11-12-2019, 04:07 PM   #202
Vic1947
Vic1947's Avatar
One of the design elements I'm planning to use is a knockoff of the Project X 57 Chevy grille bar. When the guys on HotRod Garage removed it to make way for a stock bar, I got a closer look at how it was made and realized I'd never be able to duplicate it, since it was CNC'd from a single block of aluminum as I'd suspected. I don't possess the programming skills, machining capability or the bankroll to make it happen. So I'm taking the poor boy way out...
I decided to use the grille bar that came with the car as my starting point. The chrome on it was blistered and it would have to be replaced anyway. So the plan was to cut away the round turn signal portion of the bar and replace it with a couple of pieces of flat stock formed to follow the curve of the bar.
I've had some Muggy Weld zinc rod for a long time and never used it so I figured it would be perfect for working with the pot metal. My first attempt was with 1/8" thick 5052 and was a spectacular fail. Called the guys at MW for advice and they said my flux was way too old to work. So I ordered a new bottle and when it arrived, I tried again, but with no luck. So I switched gears to something I knew would work - ultra formable 260 brass. The zinc rod took to it as easily as it did the pot metal.
I cut out the lower half on one side of the parking light bulge and fit the .094 brass stock I'd formed into the opening. Soldered both sides then cut away the top half and repeated the process. Took it slowly in steps and used a wet washcloth clipped to the previously soldered areas to sink away the heat. The last thing I wanted was to have the whole mess get too hot and fall off.
Once all the seams were soldered inside and out, I used a small air grinder, a bastard file and a D/A with 80 grit to prep it for All Metal. The picture with the yellow tape shows the cut line for the final width. Now I just need to repeat on the other side.
Victor
Old 11-12-2019, 10:01 PM   #203
mongocanfly
mongocanfly's Avatar
that turned out good Vic..!!!!!,,,are you gonna chrome plate it?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-13-2019, 12:34 AM   #204
Vic1947
Vic1947's Avatar
Thanks, Greg. According to the folks at Muggy Weld, the Super Alloy 1 can be chrome plated, but it requires a slow copper charge before the nickel and chrome. Right now, I'm leaning towards wrapping it or painting it body color. The lower half of the bar will need some work to correct the profile. I have limited options to do that. Lead or Lab Metal would require heating the part beyond what the SA1 can stand. So I'll probably use All Metal filler to get the shape I want, then decide.
There's a guy in KS I talked to a few years ago that does spray chrome. Don't know if he's still doing it, but I remember he wanted to do 100% of the filler and prep work himself to guarantee the job. IIRC, he wanted around $750 to do a bumper, not including the prep work. Irrespective of cost, I have a hard time handing off a half finished part to someone and trusting they can complete it the way I see it in my head.
Victor
Old 11-16-2019, 07:22 PM   #205
Vic1947
Vic1947's Avatar
The grille bar is ready for epoxy primer and filler. I sent a text with some pictures of it to the sandblast guy not too far from me. He wanted $250 to blast the remaining chrome off it. Took a pass. Instead, I used the DA to remove most of the chrome/nickel and then stuck it in the glass bead cabinet to rough up what was left. It hung out the end of the cabinet, but I draped a towel over the opening and it didn't make too much of a mess. Just some copper and pot metal left now. Epoxy will bond to it with no problem.
I did some research on spray chrome and I'm tempted to give it a try. The videos make it look easy (as you'd expect). They say the reflectivity is about 95% of actual chrome. For just the bar, which sits in the center of the grille all by its lonesome, it might just work.
I also got started on the bumper bullets. I used the plasma cutter to remove the centers and then a carbide burr in a die grinder to get up to the line that was stamped in them. I put one up in the mill and used a boring head to open it up the rest of the way to fit the light (Dakota/Durango lamp). Next up will be to figure out how to attach the bullets to the bumper.
Victor
Old 11-17-2019, 06:48 PM   #206
Vic1947
Vic1947's Avatar
After carefully marking the new smoothie bumper, I took a deep breath and used a 3" hole saw to open up the necessary clearance for the new parking / turn signal lights. Normally, I hack away without regard to the consequences since I figure a Sawsall, welder and grinder will fix anything, but in this case I really didn't want to buy another bumper. 3" was probably overkill, but I had plenty of room and there wasn't any need to conserve the space. My current plan is to weld some threaded tabs to the bumper bullets (which will require chroming anyway) and drill holes into the bumper for the fasteners. Mulling over the best location for said tabs but the photo with the arrows shows a couple of potential spots.
Victor
Old 11-18-2019, 07:25 PM   #207
Vic1947
Vic1947's Avatar
Here's a look at how I fastened the bumper bullets to the smoothie bumper. I made some small threaded tabs and marked their location inside the bullets. Then I drilled two slightly oversized holes for the 1/4-20 fasteners that attach on either side. Mocked up the final location by threading the fasteners into the tabs and then set the bullet down in place. Used the MIG to tack the tabs to the bullets then removed the assembly and TiG welded the tabs more securely.
As you can see, the tabs draw the bullets down firmly in place and provide plenty of clearance for the backside of the lights. Found the correct pigtails for the 899 halogen lights on eBay and got them on the way. Still a long way to go before wiring, but that should give me more than enough time to misplace them.
Victor
Old 11-19-2019, 10:41 AM   #208
knomadd
knomadd's Avatar
Looking good Vic! I've been gone too long and had a ton to catch up on. You've done quite a bit since the last time I checked in on your build. Nice work! Keep it up.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-28-2019, 12:22 PM   #209
Vic1947
Vic1947's Avatar
Thanks, Duane.
And Happy Thanksgiving to everyone!
I know I have a lot to be thankful for.
Victor
Old 12-04-2019, 12:04 PM   #210
Low Elco
Happy Thanksgiving! I gotta come by and check on this!
Low Elco is offline   Reply With Quote
Old 12-05-2019, 10:48 AM   #211
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
It's all looking great. I vote on the chrome paint on the grill bar. That way you can tell us how it works and your thoughts on the process.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 12-05-2019, 11:51 AM   #212
Vic1947
Vic1947's Avatar
Thanks, Chip! You know you're always welcome whenever you're in the neighborhood. Reminds me, I need to give your ole dad a call.
Hey Dale, thanks for weighing in on the chrome paint. I think it will be better than body color. The combination of pot metal, brass and zinc weld ended up being impossible to chrome conventionally. So we'll see how this compares to the real thing.
Speaking of which, picked up the front bumper bullets yesterday from the plating company. This is the first chrome they've done for me. I've mainly had them do zinc plating previously. I thought they turned out really nice. Chrome can be a bit of a crapshoot so it's a relief they did a great job.
Victor
Old 12-13-2019, 07:35 PM   #213
Vic1947
Vic1947's Avatar
Been welding and grinding on the door edges to prep them for the filler I'll use to set the gaps. The patch panels I made for the bottom third of the doors didn't always end up where I planned, so a do-over is required. The gaps were pretty good from the factory on this old wagon, but there are always a few places that could be better.
I didn't like the way the dividers between the doors looked after moving the latch hardware around for the suicide rear doors. When the doors are open, you could see the recess from the stamping process on the backside. So I made a poster board template and transferred it to some flat sheet metal. With it welded in and ground smooth, it adds a ton of strength to the divider, plus it makes it look a lot nicer as well. The good news is, I'm running out of metal fab on the body shell and should transition to body filler in a week or so. I'll still need to do some fabrication work under the hood when I get the body on the frame and the front clip reassembled, but I can use the break.
Victor
Old 12-13-2019, 09:44 PM   #214
mongocanfly
Looks great..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-14-2019, 12:38 AM   #215
Vic1947
Vic1947's Avatar
Looks great..!!
Thanks, Greg. I'll be glad to finish up the metal fab. Just suiting up for all the noise and dust generated by welding and grinding is a pain. I've learned the hard way, though, that I'd better not skip the dust mask, safety goggles and hearing protection. Not that body work is much better.
Victor
Old 12-14-2019, 05:18 PM   #216
swamp rat
swamp rat's Avatar
2 thumbs up!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-16-2019, 02:04 AM   #217
jlsanborn
jlsanborn's Avatar
MAAAN! I have some catching up to do. Looks incredible, Vic!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 12-16-2019, 09:00 AM   #218
Ol Blue K20
The bullets came out nice. I like the divider work too. It's looking great!
Dale
Old 12-17-2019, 12:35 PM   #219
LT7A
Hello Vic, I'm Chris. And as of now, I have read all of your threads. Thank you for the effort you make to take pictures and tell us about your projects with all of the ups and downs. With regard to your post above, I now think about suiting up with PPE as a little like gearing up for combat. Not to make any comparison to actually going to war, as many of our members here have served, but to think of the appropriateness of suiting up with the proper items as vital to the process. A sort of uniform for the work. It helps push away the "I wonder if I look silly right now" thought and replaces it with "I'm set up to get the job done". Much of that has come out from my experience with communicating the need for self-preservation in construction.
And since I'm just getting caught up, I also wanted to say that I hope and pray for the best for you and your wife through your medical difficulties. I assume that your vision has stabilized, and it sounds like your wife is a trooper and working through the medical treatments well. A little awkward to say all that, but it's well-meant and I hope you guys are blessed through Christmas and the New Year. Thanks again for making the effort to share your projects.
Old 12-17-2019, 07:07 PM   #220
Vic1947
Vic1947's Avatar
Originally Posted by swamp rat View Post
2 thumbs up!!
Thanks, Mike, hope the rat is staying out of the weather. Having lived in Woodinville, I know this time of year is the pits when you have limited space.
Thanks, John! Can't wait to see how your new shop gets set up.
Thanks, Dale, won't be long until I'm slingin' mud.
Originally Posted by LT7A View Post
Hello Vic, I'm Chris. And as of now, I have read all of your threads. Thank you for the effort you make to take pictures and tell us about your projects with all of the ups and downs. With regard to your post above, I now think about suiting up with PPE as a little like gearing up like gearing up for combat. Not to make any comparison to actually going to war, as many of our members here have served, but to think of the appropriateness of suiting up with the proper items as vital to the process. A sort of uniform for the work. It helps push away the "I wonder if I look silly right now" thought and replaces it with "I'm set up to get the job done". Much of that has come out from my experience with communicating the need for self-preservation in construction.
Hey Chris, thanks very much for your kind words, means a lot to me. 2019 is almost in the books and we're ready to turn the page. Kathy's most recent scan was 100% clear and she's already planning road trips for next year. So with all that in the rearview mirror, we can focus on getting the wagon done and ready for the road.
I'm trying to keep caught up on this thread without posting too much stuff that isn't newsworthy. The reason for the pictures is because I learn new stuff the best when I can see it. If someone tries to explain something to me verbally, it doesn't seem to sink in. But if you give me a demo, that's all I need to get started.
Victor
Old 12-17-2019, 10:23 PM   #221
mongocanfly
Great news about Kathy ...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-17-2019, 11:02 PM   #222
sduckworth13
sduckworth13's Avatar
Vic, It’s good to read that Kathy’s doing great. The project is coming along nice!
Scott
sduckworth13 is offline   Reply With Quote
Old 12-18-2019, 12:24 AM   #223
LT7A
Agreed, glad to hear!
Old 12-18-2019, 01:35 AM   #224
jlsanborn
jlsanborn's Avatar
Well said!
Old 12-18-2019, 09:08 AM   #225
Low Elco
Great to hear about Kathy. This car is gonna be awesome!
