Old 12-29-2019, 10:13 PM   #1
67ChevyPickupMan
67ChevyPickupMan's Avatar
Question 327 pictures
Does anyone on here have pictures of an original 327 V8 with a 4 barrel Rochester carb, no AC, with power steering in a 67 Chevy C10? Lost the pictures we took of it when we got it home. Thanks to who responds.
67ChevyPickupMan is offline   Reply With Quote
Old 12-29-2019, 10:22 PM   #2
projectking
projectking's Avatar
Re: 327 pictures
I do, not original power steering though
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 12-29-2019, 10:26 PM   #3
projectking
Re: 327 pictures
Here’s one I had on the phone
67 Chevy C10 LWB
90 Mustang Gt
Old 12-30-2019, 10:54 PM   #4
67ChevyPickupMan
Re: 327 pictures
Thank you projectking
Old 12-30-2019, 11:00 PM   #5
projectking
Re: 327 pictures
NP, I’ll get more. Snows blowing like a ***** tonight and I went straight into the house!
67 Chevy C10 LWB
90 Mustang Gt
Old 12-30-2019, 11:01 PM   #6
projectking
Re: 327 pictures
You want to see it without the air cleaner?
67 Chevy C10 LWB
90 Mustang Gt
Old 12-31-2019, 10:16 AM   #7
Happy_dan
Happy_dan's Avatar
Re: 327 pictures
I can take pictures of mine if you need it but no PS or PB
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 12-31-2019, 04:27 PM   #8
67ChevyPickupMan
Re: 327 pictures
Ok, thanks. They should help out a little.
Thanks Jack.
Old 12-31-2019, 04:41 PM   #9
projectking
Re: 327 pictures
Here you go. I have a power steering pump and ram assembly as well as another 327 at the shop if you need something else
67 Chevy C10 LWB
90 Mustang Gt
Old 12-31-2019, 04:43 PM   #10
projectking
Re: 327 pictures
The gearbox setup on the pictured truck isn’t correct but works!
67 Chevy C10 LWB
90 Mustang Gt
Old 12-31-2019, 06:31 PM   #11
67ChevyPickupMan
Re: 327 pictures
Thank you for the pictures projectking. If I need anymore pictures I will give you a holler
Old 12-31-2019, 06:33 PM   #12
projectking
Re: 327 pictures
You’re welcome, Happy New Years!
67 Chevy C10 LWB
90 Mustang Gt
Old 01-01-2020, 11:07 AM   #13
Re: 327 pictures
Wasn't the alternator mount on the exhaust manifold in 67/68?
Old 01-01-2020, 04:19 PM   #14
projectking
Re: 327 pictures
Yes, the lower bracket bolts to the bottom hole and the alternator pivot to the top one.
67 Chevy C10 LWB
90 Mustang Gt
Old 01-02-2020, 10:08 AM   #15
Happy_dan
Happy_dan's Avatar
Re: 327 pictures
Thanks Jack.
I will do this when I get home from work today. I'll take some with and without the air cleaner.
2019 Silverado
2012 Camaro ZL1
Old 01-02-2020, 07:37 PM   #16
Happy_dan
Happy_dan's Avatar
Re: 327 pictures
Sorry, kind of dark, but got home late. Hope these help someone with something.
2019 Silverado
2012 Camaro ZL1
Old 01-02-2020, 07:38 PM   #17
Happy_dan
Happy_dan's Avatar
Re: 327 pictures
2019 Silverado
2012 Camaro ZL1
Old 01-04-2020, 10:49 PM   #18
67ChevyPickupMan
Re: 327 pictures
Thank you happy dan
Old 01-06-2020, 06:53 PM   #19
Furno68C20
Dan these pics are from a 67 right? Was the 68 327 Amy different? What is that black hose driver side from the exhaust man to breather?
Furno68C20 is offline   Reply With Quote
Old 01-06-2020, 07:51 PM   #20
Happy_dan
Happy_dan's Avatar
Re: 327 pictures
No sir, it is a 68. That tube helps warm the air when it cold outside. I am sure someone here has the official name. Maybe heat tube?
2019 Silverado
2012 Camaro ZL1
Old 01-06-2020, 09:58 PM   #21
Furno68C20
Re: 327 pictures
cool man. Nice truck. I thought it was a 68. is that engine original to the truck? if so what is your Suffix code? Last 3 letters of stamped on the block behind the water pump. Thanks
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Old 01-06-2020, 10:48 PM   #22
chewychevy67
Re: 327 pictures
67 is a little different. Closed pcv in 67 is in the oil fill tube and the carb is a 4jet, not a Quadrajet on a 67 327. Here is a factory 67 327. It has ac and air injection that yours may not have. 67 truck 327's in all designations had a thermostat bypass as well. The 67 327 would be manual choke but I added an auto choke to mine as well as adding larger valve heads from a car.
chewychevy67 is online now   Reply With Quote
Old 01-07-2020, 12:37 AM   #23
Furno68C20
Thanks for the info. How close is your bbl air breather to compressor? I have air too but I think it’s an aftermarket compressor and the stock bbl wont fit. Maybe the compressor can be adjusted?
Old 01-07-2020, 08:04 AM   #24
Happy_dan
Happy_dan's Avatar
Re: 327 pictures
Sorry, just realized the original post was looking for a 67! I am pretty sure the engine is original to the truck. I haven't had a chance to check the numbers yet. I will get the number as soon as I am home and remember.
2019 Silverado
2012 Camaro ZL1
Old 01-07-2020, 03:56 PM   #25
chewychevy67
Re: 327 pictures
It's quite a ways away. This is the oil bath breather. The paper element housing may be closer but wouldn't touch.
