01-12-2020, 08:53 PM | #1 |
Anyone can buy an SWB...
Been away for a minute. Started my MTP a year ago, this truck is one of the goals along the way. Started as a bone stock BB/auto then i did a moderate resto-mod and enjoyed it for a few years. Ive been cutting and reworking a LWB chassis to get the perfect stance for this conversion.
01-12-2020, 09:05 PM | #2 |
Re: Anyone can buy an SWB...
01-12-2020, 09:52 PM | #3 |
01-12-2020, 10:10 PM | #4 |
01-12-2020, 10:15 PM | #5 |
Very nice truck. Clean work you are doing there as well!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-12-2020, 10:27 PM | #6 |
01-12-2020, 10:29 PM | #7 |
Thank you. Labor of Love...
01-13-2020, 01:46 AM | #8 |
01-13-2020, 01:53 AM | #9 |
01-13-2020, 02:04 AM | #10 |
01-13-2020, 02:25 AM | #11 |
01-13-2020, 03:04 AM | #12 |
01-13-2020, 03:08 AM | #13 |
01-13-2020, 03:38 AM | #14 |
01-13-2020, 03:42 AM | #15 |
01-13-2020, 10:55 AM | #16 |
Very nice. Suspension mods are clean.
01-13-2020, 01:26 PM | #17 |
Very nice work, how much did you section the front cross member? I like the frame mods to raise the steering box and centerlink.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-13-2020, 01:33 PM | #18 |
BlahBlahBlah
Very nice work ... What does MTB stand for?
01-13-2020, 02:15 PM | #19 |
01-13-2020, 02:24 PM | #20 |
Thanks. MTB is an acronym for mountain bike 😆. MTP is a massively transformative purpose. The short version: Changing your life and finding your real purpose in the time thats left. Living an examined life.
01-13-2020, 03:16 PM | #21 |
01-13-2020, 03:39 PM | #22 |
Motor/trans position is slightly higher, Output shaft is 2.8 degrees, carb surface is .1 degree off level at ride height of 5 3/8”. The BB CPP mounts were a terrible fit. Took reengineering to make them fit correctly. This and also needing the extra clearance between drag link n oil pan caused the z-bar position to change. Enjoy the Handsome bracket below !
01-13-2020, 04:18 PM | #23 |
Z-bar off a 6-cyl. Sectioned tube, made, moved & reclocked lower arm.
The throw is butter smooth and effortless. Upper pushrod is thin wall tube w/bolts welded at ends. |
01-13-2020, 04:29 PM | #24 |
Formerly- 1972SuperCheyenne
Totally awesome. Great work!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-13-2020, 05:29 PM | #25 |
Thank you Josh.
My experience with an aftermarket panel bed: i see this often on even some high end builds where the bed caps are level w/ the cabs upper bodyline and the lower bed line is 1/2 or better too high... i fixed this by sectioning the front stands and rear rail ends. The other 2 cross sills were sectioned to match. Dont know how one could live w/such a poor off the boat fit. |
