Old 01-13-2020, 05:22 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Different between 1/2 & 3/4 ton cab mounts.
For a 1969 GMC 3/4 ton.
Is it a difference in height or mounting? Do I have to get the 3/4 ton? Thanks.
desert-rat is offline   Reply With Quote
Old 01-13-2020, 09:02 PM   #2
PepperTreeGarage
PepperTreeGarage's Avatar
Re: Different between 1/2 & 3/4 ton cab mounts.
3/4 ton cab and core support mounts on our '72 C20. I had to refurbish and reuse some of the hardware. Hope this helps.
PepperTreeGarage is offline   Reply With Quote
Old 01-14-2020, 12:29 AM   #3
FirstOwner69
FirstOwner69's Avatar
They are significantly different. You'll need the 3/4 ton version. Here are links to the LMC catalog pages with illustrations of both.
1/2 ton- https://www.lmctruck.com/1967-72-che...ng-2wd-1-2-ton
3/4 ton- https://www.lmctruck.com/1967-72-che...wd-3-4-ton-4wd
FirstOwner69 is offline   Reply With Quote
