01-13-2020, 05:37 PM | #26 |
Re: Anyone can buy an SWB...
Outstanding stuff going on w/that clutch linkage re-work vs. going to a hydraulic set-up. I've been staring @ a box full of G-body linkage & facing a similar dilemma... Gusset it & use some red ends for an old-school 3rd pedal set-up? Or, buy-in for the 'upgrade' aftermarket set-up that's all hydraulic (and more expensive).
01-13-2020, 05:41 PM | #27 |
01-13-2020, 05:58 PM | #28 | |
I like the simplicity of a mechanical linkage. If you have the time n patience you can create a one-off setup that has good throw n smoothness no matter the vehicle. Im sectioning the arms and reclocking the pedal pads on my 68. Theres nothing that cant be made better with patience and focus. |
01-13-2020, 06:54 PM | #29 | |
Years ago I bought a 4spd g-body ElCamino just because it had all the parts needed. I swapped an auto set-up from a Malibu over to the Camino & the manual trans set-up over to the Malibu. Fast forward a 'few' years & now all the rage is an aftermarket hydraulic set-up. Sure tempted to stick w/the old school mechanical linkage & just make refinements where needed. After all, mechanical set-ups worked for a looooong time before the OE's switched to strictly hydraulics. Again, glad I came across your build. I like your style. I'm pretty sure I've seen your truck before in person as well @ a meet or show somewhere.
01-14-2020, 02:36 PM | #30 |
Cool. Glad to have you. Recognize your avatar. I Used to be on the forums a lot around 07-10.. Dino and Nathan were my truck building heroes.
01-14-2020, 03:32 PM | #31 |
MTP... I like it and I'm about 6 weeks away from my own MTP moment.
Great work and good luck in all you do, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-14-2020, 08:43 PM | #32 |
T-6 dom driveshaft
[ATTACH]1974146[/ATTAC Last edited by Inverter; 01-15-2020 at 12:54 AM. |
01-14-2020, 09:00 PM | #33 |
Drew up plans for this. BW did an excellent job
01-14-2020, 09:50 PM | #34 |
Killer work! Love the build!
01-14-2020, 11:47 PM | #35 |
I applaud your skills, awesome build. Wish I had a 1/3rd of your skills.
Definitely sub'd.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
01-15-2020, 12:38 AM | #36 |
I am Watching.
That is some Nice work. .
01-15-2020, 02:25 PM | #37 |
Excellent work going into this build. Nice fix on the bed body lines.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
01-15-2020, 04:29 PM | #38 | |
01-19-2020, 04:08 PM | #39 |
A guy with a truck
Very nice work here. I like where you’re headed AND how you’re getting there
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-19-2020, 05:06 PM | #40 |
Awesome build. If you don’t mind can you let me know the size of the tires and rim on the truck in your first post picture. Thank you.
01-19-2020, 09:05 PM | #41 | ||
Fronts: 15x6 - 235/70 Rears: 15x8 - 275/60 Both are 28” tall. |
01-19-2020, 11:49 PM | #42 |
[/QUOTE]
Fronts: 15x6 - 235/70 Rears: 15x8 - 275/60 Both are 28” tall.[/QUOTE] Thanks. |
01-26-2020, 10:41 PM | #43 |
It's refreshing to see some custom framework getting done. There are so many parts available nowadays that we just don't see too many one-off fabricated pieces being created.
Cleverly disguised as a responsible adult... |
01-27-2020, 06:08 PM | #44 |
Superb skills and build.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-04-2020, 09:57 PM | #45 |
Appreciate the kind words.
Wiring, plumbing wrapped up. I reroute and rearrange the wiring so its more eye pleasing.I like things to be linear and minimal where possible. [ATTACH]1980068[/ATTACH [ATTACH]1980071[/ATTACH [ATTACH]1980072[/ATTACH [ATTACH]1980075[/ATTACH [ATTACH]1980076[/ATTACH |
02-04-2020, 10:14 PM | #46 |
Bypass delete, using a fancy drilled thermostat.
[attach]1980077[/attach [attach]1980078[/attack [attach]1980079[/attach [attach]1980080[/attach [attach]1980081[/attach |
02-04-2020, 10:26 PM | #47 |
[attach]1980089[/attach
[attach]1980090[/attach [attach]1980091[/attach |
02-04-2020, 10:30 PM | #48 |
posting pics is frustrating.... I must be doing something wrong. I just want to pull a lever and have it happen.
02-05-2020, 09:43 AM | #49 |
Man this is great! Just in time for my build.. hope you don't mind me taking some of your ideas. Especially the entire front end build. I'm just starting and starting with a frame my self.
Where about in east Texas are you? |
02-05-2020, 10:59 AM | #50 |
