01-19-2020, 02:16 AM | #1 |
Old member
C-30 brakes
I want to know if any body has ever ordered the emergency brake cables for a C-30 truck? If so where did you order from.
I need everything from the rear drum brake cables back to the handle inside the cab. I have nothing at all on the old ramp truck and would like to get the e brake system working again. I have the brake handle in the cab is all.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-19-2020, 03:33 AM | #2 |
Re: C-30 brakes
Obviously that's going to need some way to extend things.
https://www.google.com/search?q=68+c...=firefox-b-1-e |
01-19-2020, 10:13 AM | #3 | |
Old member
Re: C-30 brakes
Yes I have done all the normal searching. I sent a couple of request in to different company's will see who check back with me.
01-19-2020, 10:22 AM | #4 |
Re: C-30 brakes
I use Inline Tube for that stuff. You may be able to get the main cable special made to your length if you knew how much over it needs to be. They are very exacting at Inline Tube and if you don't have exact numbers they won't be interested. I had them make me longer rear cables for a lifted truck many years ago. It seemed like I was the first one to make such a request. They guy said they only do factory spec. It took some persuading, like saying "Just make them factory spec plus 2 inches" and "I accept that if this doesn't work I bought them anyway". Of course, you could always get standard length, cut, and clamp an extension in, which is how it was done originally on that frame stretch.
01-19-2020, 10:38 AM | #5 | |
Old member
Re: C-30 brakes
Tim, In-line tube is the main one I contacted. I hope to hear back from them so I can find out what they need. Hope I can get something done.
01-19-2020, 01:19 PM | #6 |
Re: C-30 brakes
There is a C-30 in the junk yard near me. I can look to see what is on it if anything. D
01-19-2020, 01:22 PM | #7 |
Re: C-30 brakes
Are you dead set on cable operated E-brake?, Might go through all that trouble with extra long lines and have poor results. I would use a hand operated trans brake or a line lock.
01-19-2020, 07:31 PM | #8 |
Old member
Re: C-30 brakes
I never thought about that, Hmm that maybe a way to go with a line lock.
01-19-2020, 07:50 PM | #9 |
Re: C-30 brakes
01-19-2020, 07:55 PM | #10 |
Old member
Re: C-30 brakes
Do you have any good info on a system. All the ones I see say not for E brake use.
01-19-2020, 08:03 PM | #11 |
Re: C-30 brakes
I am subbed for this one.
You could possibly use the lever to operate the line lock or Trans brake?? .
01-19-2020, 08:10 PM | #12 |
Old member
Re: C-30 brakes
Nothing is coming up that states use for E brake. I wonder how the wheel cylinders would hold up if I used the line lock for extended times.
01-19-2020, 10:01 PM | #13 |
Old member
Re: C-30 brakes
Found this one but I would have to run the brake lines into the cab so it works.
01-19-2020, 10:07 PM | #14 |
Re: C-30 brakes
I have an '85 C30 that has a hydraulic parking brake in the cab. It was a pipeline welders truck and it may have been required.
Would be cool for loading/unloading the ramp truck, but IMO, it's no replacement for the all mechanical parking brake. I don't think long term use of the hydraulics under pressure is a good idea.
01-19-2020, 10:24 PM | #15 |
Old member
Re: C-30 brakes
While we are talking about brakes on this I have another brake question.
I bought a whole front end out of a 86 3500 HD a while back with disc brakes. Can I just swap the ball joints and spindles out of the ramp truck to the 86 ones? Any thoughts and links threads on this subject?
01-20-2020, 12:16 AM | #16 | |
Re: C-30 brakes
http://67-72chevytrucks.com/vboard/s...68&postcount=4 |
01-20-2020, 12:51 AM | #17 |
Old member
Re: C-30 brakes
So all I need to do is break the 86 a part and swap the ball joints and spindles & rotors over to the ramp and hook up the new lines.
01-20-2020, 12:56 AM | #18 |
Re: C-30 brakes
01-20-2020, 01:07 AM | #19 |
Old member
Re: C-30 brakes
Yes I have all this off the 86 he wouldn't give me the pitman arm off the steering box but hopefully mine will work are I can find one that does.
01-20-2020, 09:30 AM | #20 |
Re: C-30 brakes
Did your C-30 come with a drum brake style parking brake on the back of the transmission?
01-20-2020, 10:19 AM | #21 | |
Old member
Re: C-30 brakes
That is anybody's guess. If it did it's long gone now. I have nothing under this truck as far as e brake stuff. Nothing at all. Heck I don't even know if the rear drums will have the E brake bar inside of them.
01-21-2020, 09:52 AM | #22 |
Old member
Re: C-30 brakes
In line said they didn't make custom brake cables!
