01-12-2020, 05:54 PM | #1 |
Msd ready to run
Looking for input/opinions on the msd ready to run distributor 8360. With the blaster 2 coil. We are going to put it in our 383 build that is going in our 66 k20. We are concerned about the clearance issue near the firewall and this is why we are looking at this distributor. We did read about the issues with the coil but they were older posts. So any advice would be appreciated. Thanks.
01-12-2020, 07:27 PM | #2 |
Re: Msd ready to run
got one and it worked fine until i went efi from edelbrock .
still using the blaster 2 coil no problems . and the dist is in my parts stash for testing engines now or if someone wants it for a good deal
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-12-2020, 10:12 PM | #3 |
60-66 Nut
That is a small cap distributor. I don't see why there could possible be any clearance issues. In fact I have never had any issues with a large cap HEI in the '63-'66 trucks with a small block in the original factory location.
01-13-2020, 12:29 PM | #4 |
Me, I am always the critic. I wonder where the ball bearing is in that unit. I wonder what would happen when it goes out???
Polished steel shaft is QPQ coated and guided by a sealed ball bearing I know what happens when the bearing goes out in the Water Pump. |
01-13-2020, 08:34 PM | #5 |
Thanks everyone, we were under the impression that we needed a small cap distributor because of the clearance issue.
01-13-2020, 09:56 PM | #6 |
I have a ready to run MSD in my Jimmy. It's been there for 20 years now with no problem. I think I have an older Blaster coil on it.
On my kids Jimmy project we did the large cap HEI, and it is a TIGHT fit but you can make it work. These are both on '72 vehicles, so clearance is a little different.
01-14-2020, 03:25 AM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Have one tn my 72 with a big block for 5 years now Baster 2 coil, plenty of room...No ignition box necessary and a built in rev limiter...Love it!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-14-2020, 11:31 AM | #8 | |
I sent a message to DUI making an inquiry. I am replacing my Skip white(which has been good to me for the price so far), the cap needs to be replaced... so I will just pop in a (hopefully) better unit. I myself am looking at MSD Pro-Billet and DUI small cap ready to runs with HEI style caps (it what my wires are crimped for). DUI https://performancedistributors.com/...ower-ignition/ Have fun! j
White K20 |
01-14-2020, 07:50 PM | #9 |
Ya Jeff, that's another one were looking at. They seem to have great reviews.
01-16-2020, 10:22 AM | #10 |
[attach][/attach]
Only modified the firewall because I run a roots blower.
At my worst I'm at my best |
01-26-2020, 10:38 AM | #11 | |
01-26-2020, 12:58 PM | #12 |
Get an ecore ford coil from a 90s v8. Much cheaper and a hotter spark. Been running one on my 72 that is hard on plugs at idle. I had to make a simple bracket for it but now it's on the fender well away from heat.
02-03-2020, 02:27 PM | #13 |
Check out the Summit brand ready to runs. They use all MSD parts and are cheaper. Have a summit pro billet in my 427 small block and was in my vortec engine before that, not a single hiccup.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
02-03-2020, 09:33 PM | #14 | |
j
White K20 |
02-03-2020, 09:44 PM | #15 |
Went DUI HEI and never looked back !!!
