02-09-2020, 02:08 PM | #1 |
Tilt column
SOLD
$425 local, $475 shipped. Please respond in thread only per board rules, first "I'll take it" gets it. Selling a painted and converted motorhome tilt column. From a mid 80s GM chassis It has the straight shifter arm like a truck tilt Also has the metal gear indicator I moved the NSS down so it's a bolt-in for your 67-72; I used my multi-meter to adjust it, you may need to fine tune it after install. Turn signal and tilt levers are new from GMC Pauls Turn signal switch is new Includes the cancel cam The gray illumination wire is full length with the green end Includes a long pigtail for the Neutral Safety/Reverse switch Tilt mechanism is tight and smooth. The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight. Tilt pivots were cleaned and lubed when removed to tighten the bolts. The bottom bearing was cleaned and greased The upper bearings were cleaned and greased The shift indicator bulb was replaced and tested OK, it has the green shade on it. Shifter lever end (inside column) is good, pivot is good Shift arm has nice chrome, it shines up well. The finish on it is base/clear coat gloss black. The shift arm is metallic silver and includes the rubber bushing and metal sleeve New firewall and dash gaskets from GMC Pauls I will include a new GMC Paul's gear indicator Also can swap out the indicator lens for an OD version at the same price You will need to add your metal firewall plate.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 02-10-2020 at 04:00 PM. Reason: Item sold |
02-09-2020, 02:12 PM | #2 |
Re: Tilt column
More pics
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-09-2020, 02:15 PM | #3 |
Re: Tilt column
Last one
02-09-2020, 02:41 PM | #4 |
Re: Tilt column
I’m happy w/my tilt Clay restored. This shouldn’t last long. A great buy!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
02-09-2020, 02:43 PM | #5 |
Re: Tilt column
Thanks Troy
Are you sure you don't need a pretty one??
02-10-2020, 03:10 PM | #6 |
Re: Tilt column
im looking for a tilt floor shift for my 70 C10, local to you.
Thanks, Rob |
02-10-2020, 03:26 PM | #7 |
Re: Tilt column
I'll take it
02-10-2020, 03:57 PM | #8 |
Re: Tilt column
Sold to 4x41971swb
PM sent
02-10-2020, 04:38 PM | #9 |
Re: Tilt column
02-19-2020, 11:45 AM | #10 |
Re: Tilt column
Recieved this the other day and opened it up last night.
All I can say is WOW!! It looks amazing and thank you for the more than fair price! |
02-20-2020, 04:51 PM | #11 |
Re: Tilt column
My pleasure. I can’t take all the credit, my buddy Dave does great paint work.
Tags |
tilt, tilt column, tilt steering column |
