Always on the hunt...
![]() Join Date: Sep 2006
4wd four piece NOS transfer case side support mount bushing set, you will receive two upper (thin) and two lower (thick) rubber cushions. $130. shipped via USPS. Will accept paypal, check or money orderl as forms of payment, if using paypal option add 3%. Thanks for looking, Mel
![]() ***Qty. Six NOS 4 piece T/C rubber bushing-cushion setups Sold/Shipped*** . Last edited by Classic Bowties; 10-09-2020 at 08:36 PM. Reason: updated availability |
“On The Hunt”
![]() Join Date: Feb 2018
Re: F/S GM NOS 4wd Transfer Case Mount Bushings
Mel, If it’s for a 205 transfer case I’ll take it
Hey Nic, yes these are correct for all 67-72 K/5-10-1500-20-2500 4wd's with both 3/4 speed manual and TH350/auto transmissions, the transfer case mounted support brackets themselves had differences over the years (see below manual pics) but the rubber bushings/cushions were the same. We currently have a few of these four piece NOS t/c rubber bushing setups available/on hand if you need more than one set, also if needed we can supply you with this pair of NOS t/c bushing steel spacers/sleeves (see below red arrows) for $35. Let me know and we'll get your combined total figured up on these and the NOS grill emblem from the other thread, Mel
More pics...
Funds received for one 4 pc. set of NOS t/c mount bushings and the added pair of NOS steel t/c bushing spacer sleeves, let me know when you're ready to finalize this shipment/order and we'll get it packed and headed your way. Thanks again on the multiple purchases, Mel
Just updated top post, we have two 4 pc. NOS t/c cushion-bushing setups remaining/on hand. Mel
Active Member
![]() Join Date: Sep 2007
I will take a 4 piece set and 2 steel bushings.
Active Member
![]() Join Date: Jul 2014
Do you have any bushings and and spacers left ?
Funds received on the NOS transfer case rubber bushing & steel spacer setup, your package went out via USPS first class on Thu. 02/13 and the expected delivery date is Tue. 02/18. Thanks again and let me know if we can help with any other 67-72 parts needs, Mel
The transfer case rubber bushings and steel spacers have been packed/shipped with your items from the other NOS parts f/s thread, the package went out via USPS priority on Fri. 02/14 and the expected delivery day is Tue. 02/18. Thanks again and let me know if we can help with any other 67-72 parts needs, Mel
The NOS t/c rubber bushings and steel spacer sleeves are under way, your multi-piece NOS parts order went out via USPS priority on Thu. 02/27 and the expected delivery date is this Sat. 02/29. Thanks again and let me know if we can help with any other 67-72 parts needs, Mel
![]() Join Date: Jul 2015
I'd better get a set too.
#15 |
#16 |
Rubber bushings for the transfer case .I looked at my old steel sleeves this A.M and think they will be ok.
#17 |
#18 |
![]() ![]() Join Date: Sep 2008
Do you have another set of upper and lower cushions?
#19 |
PayPal sent.
#20 |
#21 |
I'm in no hurry, so I will mail you a check.
#22 |
#23 |
#24 |
![]() Join Date: May 2003
HI Mel,
I'll take a 4 piece set of rubber mounts. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#25 |
I went ahead and sent PP for mine.
