03-08-2020, 06:39 PM | #1 |
Replace rocker?
I've decided to tackle the body work on my 70 K20 restoration, and have zero experience with metal fabrication or body work. I'd like to learn how to do it, plus I don't really have the funds to pay someone else.
I'm thinking I will need to replace the driver's side rocker panel and both footwells, but I wanted to get confirmation from you guys to make sure I'm heading in the right direction. I plan on buying a mig welder and teaching myself how to do this. I was hoping I could get away with POR-15, but after closer inspection it looks like that won't be an option. Any advice would be appreciated. I thought I would start by flipping the cab on it's back and cleaning/POR-15 the bottom, and then flip it back up and start on the rocker. |
03-08-2020, 06:40 PM | #2 |
Re: Replace rocker?
More pics...
03-08-2020, 08:48 PM | #3 |
Re: Replace rocker?
Save the por15 for a bridge..you dont need it on your truck..
With no welding experience your gonna need lots of practice...thin body panels is not the ideal place to learn how.... 1st before you cut out anything is to x brace everything before you start cutting... Go to a body shop and get some old fenders to practice welding on... Looks like rockers and kick panels for sure..and probably floor pans before you get done.. You may find it better to pay someone to do all this before its done... all that metal needs replacing and epoxy coated..not por15... This can turn into a very big job before you get done..good luck with it..
03-09-2020, 09:54 PM | #4 |
Re: Replace rocker?
I am at the same point as you are. I bought a truck from California with very little signs of rust, it did have noticeable rust though in the kick panel area. The kick panel area is kind of 3ply. The floor pan/inner rocker, kick panel ,door pillar all pinch together here. So you may also have hidden surprises. One thing I would suggest , if adding bracing, do it so that you can mount and adjust doors properly. You will need to mount and adjust doors , checking gaps before final welding. Also rebuild your hinges first.
Collect all your parts, supplies and tools first, Do a bit of research and have fun. If it gets a bit frustrating , take a break and Consult the forum. Lots of great members here willing to help.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
03-13-2020, 09:52 PM | #5 |
Re: Replace rocker?
I'm in same boat. Purchased mig welder a few years back...practiced...
Finally getting to my rust-repair-restoration job...gonna be fun!
'72 Chevy K-20 Crate 350, SM465, 4.10's |
03-14-2020, 12:17 PM | #6 |
Re: Replace rocker?
Por 5 is pure snake oil and doesnt belong on anything.
Use the industry standard, epoxy primer over sandblasted or sanded bare metal or just leave it alone. |
03-19-2020, 10:00 PM | #7 |
Re: Replace rocker?
Read through lots of build threads and gather info. As mentioned welding thin gauge steel can be a challenge but when you get IT it feels awesome. The area where inner rocker, kick panel, rocker and pillar come together can be tricky. Good advise to brace everything before cutting. Only tack weld until door gaps are correct. Good luck!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
03-20-2020, 07:17 AM | #8 |
Re: Replace rocker?
What company are you guys getting your rockers from ????/
03-20-2020, 07:44 AM | #9 |
Re: Replace rocker?
I'd rejoice if all my rockers looked that good! need a tetanus shot before climbing over some of mine
as for your objective to learn how to weld and replace your own, if you have a decent mechanical aptitude, I vote go for it.. I've had the skills since putting expert builder lego kits together in the 70s, been a heavy junk mechanic all my life since.. cutting, fitting, and welding steel is part of my trade.. only thing stopping me is time, and rust doesn't really bother me my advice is similar to above, learn, practice, practice, practice.. practice cutting, fitting, and welding simple panels and slowly graduate to more complicated pieces.. if you have time, take some adult learning classes.. most community college classes are very affordable.. once you're confident you have the skills down, dive into your project.. and remember, you can make vast improvements although your first project may not be a show stopper.. these were production made trucks, they weren't perfect the day they left the factory.. and the joy of it all is that it can almost always be saved by more careful rework.. lots of threads here to guide you, may even solicit help from a neighbor or fellow enthusiast.. here's a fun thread caught my eye recently Budget Shortbed: welding, grinding, rust oh my good luck!
I started out with nothing - and I still have most of it |
03-21-2020, 09:22 AM | #10 |
Re: Replace rocker?
When it comes to maximum corrosion resistance nothing outperforms the aluminum pigmented moisture cured urethane. On projects that are in extremely corrosive environments project engineers usually specify two coats of the aluminum pigmented primer followed by an epoxy intermediate coat and then a urethane topcoat.My 55 is completely painted like this Here's a video that compares different products including epoxy in salt fog chamber.The title of the video is POR 15, KBS, chassis saver SP I epoxy and Mastercoat salt fog test. Who went the furthest?
03-21-2020, 11:20 AM | #11 |
Re: Replace rocker?
Be sure to get a welder that you can use gas with. I find the .025 wire is the best. Keep the gaps no bigger than the wire you are using. Tack, cool or dolly and repeat. Do not be in a rush to complete the work, or you will have a lot of warping. Odds are once you get into it, you will see more needs to be replaced than originally thought. Don't let that discourage you. As others mentioned, gather panels, add bracing on the inside and let er rip. When grinding welds, avoid excessive heat. Found best way is to use a cutoff wheel and slowly work the welds down, or get a good burr. Also do not forget the eye, hand, nose and ear protection.
03-22-2020, 05:31 PM | #12 |
Re: Replace rocker?
I purchased most of my repair panels 6or7 years ago for another project, but ended up not using them until recently. Probably from Summit or Rock auto .
The passenger side fit very well, with very little extra work, the driver side needed some work to make it fit better but not bad. Perhaps rockers have gotten better since 2013 ?
08-11-2021, 09:41 AM | #13 |
Re: Replace rocker?
I am also at the beginning of the rust eradication in the rocker area at the bottom of the "A" post. Can these repairs be done without cab removal? I'd like to remove the fuel tank, door, floor covering and seat only. Is it possible? My rocker is perforated from A post backwards about 6 inches underneath the rocker vanity cover. I have similar rust on the passenger side but not quite as much perforation.
08-11-2021, 10:41 AM | #14 |
Re: Replace rocker?
as mention do lot,s of research. Are lot,s of good u-tube videos like Milkcrate. I was the same ,didn,t know how to weld good , which panel to put on first, simple little tricks to help along the way but is was fun and a good learning experience .
08-12-2021, 05:07 PM | #15 | |
Re: Replace rocker?
08-17-2021, 12:17 PM | #16 |
Re: Replace rocker?
Go into this project with realistic goals. Yes you can do this, but there is a learning curve. Don't expect the first side to come out perfect or be easy. The second side will take about 1/2 as long as the first and will come out better. You may consider redoing the first side after the second side is done. The repair panels are not that pricey. I would only tack weld in the first side, then finish the second side, then finish the first side.
1. Check door gaps regularly with every test fitment before fully welding in the whole panel. Try to leave the doors on since removing it messes up the original adjustments that made it close and latch good. If you have to remove the doors, Consider marking the door hinge bolts first with a mist of primer so you can put the door back on in the exact same spot. 2. Only tack weld everything until fitment is good. Then increase the tack welds until they are only 1/2" apart, then stitch them together. Use a coat hanger for filler material at the end in places where there is over 1/8" gap, instead of just filling it with wire. 3. Don't weld longer than 1" in one weld. It will get the panel too hot and it will distort. Work around the perimeter alternating sides to keep the panel from getting too hot. 4. Minimize welds that are in areas that you can't clean up with a grinder. One tack weld then some seam sealer, then paint, will look way better than a big goober weld painted that you couldn't grind down. This is important around the door jambs where the finished product is painted and it shows. Realistically, your first repair job is not going to be perfect when done. If you are patient, it will look good at 5' and the doors will close good, and the gaps will not be too noticeable. Expecting show truck results is not entirely realistic. The next truck you do will be better.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
09-08-2021, 09:19 PM | #17 | |
09-08-2021, 09:20 PM | #18 |
09-08-2021, 09:22 PM | #19 |
