03-15-2020, 12:08 PM | #1 |
Back of tachometer OE
Does anyone have pictures of the back of stock GM tachometer. I found one out at the local junkyard but I think it is the 76-77 only trucks. The funny thing it came out of a 80’s truck. Does this look like a 1976-77 only tach combo?
79 Chevy 2wd BIG10 350 TH400 |
03-15-2020, 12:12 PM | #2 |
03-15-2020, 12:13 PM | #3 |
03-15-2020, 03:26 PM | #4 |
Re: Back of tachometer OE
Yes, the cluster shown at the top of your photo looks like a 76 or 77. It has a mechanical oil pressure gauge and a voltmeter.
The cluster shown at the bottom of your photo looks like a 73 - 75. It also has a mechanical oil pressure gauge but an ammeter instead of a voltmeter (as can be seen from the back by the difference in the terminal orientation). A 78+ cluster will look very similar from the back, but will have an electric oil pressure gauge. So it will have electrical connections (that look similar to the back of the temp or fuel gauge) on the back of the oil gauge instead of a tube fitting. The fact that you found a 76-77 cluster in an 80's truck isn't all that uncommon ... the tach clusters seem to be a fairly common swap. As for the back of the tach itself, they all look very similar as well. Although the 73-75 ones have a different meter movement that uses 4 round studs w/small nuts on the back vs. 3 studs for the later years. |
03-15-2020, 07:37 PM | #5 |
Well that won’t work for the 79 will it. Well I just bought a lose OE tach with a gas gauge and I will install in my existing gauge cluster. I have clock where emergency brake light used to sit. Can I splice emergency brake light wiring into the brake light that is under the speedometer?
03-15-2020, 09:49 PM | #6 |
Well, you could use one of those earlier year clusters in your '79 but it wouldn't be a direct plug-in swap like a '78+ cluster would be.
The tach with the fuel gauge at the bottom (originally used in medium duty trucks) is a good option for having both a tach and a clock. You might want to double check the location of your brake warning light though. Those were usually located at the bottom of the large fuel gauge, not the speedometer. Although it probably would be possible to swap the colored plastic filter to re-locate it there. And follow the traces on the printed circuit back from that bulb location to the cluster plug to see where you would have to re-locate the wire that activates the light. |
03-16-2020, 08:07 AM | #7 | |
#1, the e-brake lever had a switch that would ground out that circuit. #2, the brake proportioning valve had an internal switch that would ground out the circuit if there was a pressure differential between the front and rear brakes. #3, when the key switch was in the crank position, it would supply a ground to that circuit as a bulb test.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
03-17-2020, 08:29 PM | #8 |
Pretty Kool Tach been thinking if I add a factory one it would be one of them.
Because I got ride of the clocks prefer the VACCUME - Gauge so that style of factory Tach would work better for my gauge style set up would like. You got a head start with the to tach cluster most of the parts are there the rest on you truck cluster.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-22-2020, 09:50 AM | #9 |
I just tested my new tachometer and movement of needle seems slow. Can I just pull needle off and add some lube or will this screw up the tachometer. I already pulled needle off to reposition because RPMs we’re off. I put needle back on and it seemed to correct RPMs, I just didn’t add lubricant
03-22-2020, 11:54 AM | #10 |
A broken lager needle @ the eye let pressed against the shaft(just hold there not to hard) few drips on the needle will run down the needle shaft on the pointer needle shaft to lube it.( the broken needle eye let or cut should be all most the same size as 1/2 the shaft of the pointer shaft to work best.)
03-29-2020, 02:34 PM | #11 |
Question: these styles of tach if it had 4000 rpm this would have been out of a Disel right.
03-29-2020, 08:33 PM | #12 |
Yes, a 4000 rpm tach would be from a diesel. Some diesel tachs use the alternator windings as their signal source, but the diesel tachs used in the 70's/80's medium duty GM trucks were hooked up to a magnetic pickup in the bellhousing that senses the flywheel teeth. As a result, they use a different circuit board (on the back of the tach) as compared to the gas engine tachometers. And the diesel version has calibration jumpers to configure it for the different engine / transmission combos.
03-30-2020, 09:11 AM | #13 |
What year and model had the tach as well as a trip odometer?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-30-2020, 09:45 AM | #14 |
88-91 burb
05-23-2020, 03:27 PM | #15 |
Well sent tachometer off to have fixed with new circuit board. It cost 125.00 so now it works great but the gas gauge is stuck on 1/2 full. I used jumper wires to attach to my non-tach cluster. I need to check connections, hopefully that is the problem
