#951 |
![]() Join Date: Jan 2018
Re: What did you do to your Blazer/Jimmy today?
#952 |
Removed old gas tank as step one for installing the EFI kit and new tank. I also figured out why the Jimmy rained gas when I filled it up! I guess the PO thought JB Weld was a good idea?
Photo of my dog, just because he's mad that I have ignored him today.
72' JIMMY 454 ![]() Last edited by BIG BLOCK JIMMY; 02-01-2020 at 06:08 PM. Reason: Photos didn't show up |
#953 |
always amazes me what the PO's do, you found a new one
#954 |
Well I drove mine to work. Again.
'72 K5, known as 'the Fox.' |
#955 |
![]() ![]() Join Date: Mar 2016
I drove mine to work Today . It was melting and refreezing . Made for some crazy ground effects. (sorry for poor picture quality)
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#956 |
Bought mine!! Looking for a rear seat now.
#957 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Welcome to the K5 club!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#958 |
![]() Join Date: Nov 2014
First test drive between snow squalls. Finished a few upgrades and repairs including installing a rebuilt TH350.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 02-25-2020 at 10:37 AM. |
#959 |
Bath time. “0000” steel wool and CLR followed by a coat of wax.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 02-26-2020 at 11:27 PM. |
#960 |
Carpe manana
Pics please...
#961 |
Replaced a busted headlight retainer. The screws from LMC are incorrect, so reused the originals. Also replacing the gauge cluster. Going to order a connector so it won't be done today
#962 |
Active Member
![]() Join Date: Nov 2008
Put the new LT Motor/8l90 transmission in the Jimmy today. Not sure why the pictures are upside down and sideways?
#963 | |
for the life of me, can't figure out your backgroud, is it a truck part?
#964 |
#965 |
Carpe manana
Cluster swap/upgrade isn't too hard. It's a half day project. If your K5 wasn't equipped with a tach originally you need to plan where to route the tach harness - I've drilled the 0.75" firewall hole in the correct spot, it's easy and there are a few threads dedicated to this. Use a line wrench to loosen the oil pressure line if so equipped in order to avoid stripping the brass. Good time to swap steering column too if that's on the menu. If you need a tach/vac cluster check with Tbone Tom as he provides a good service.
#966 |
![]() Join Date: Aug 2012
I decided to tackle refurbishing a spare hatch I have. I separated the two sides and am starting to remove hardware that refused to come off. (One of the latches had the welded nuts break from the spot welds and I couldn’t get it off until the hatch interior was exposed.)
I can’t get the struts to come loose. Been spraying it with PB Blaster. Started drilling out one sides screws (those things are tough! Still haven’t made it through them yet). Sorta following this thread but with more miss steps... http://67-72chevytrucks.com/vboard/s...d.php?t=403730 Anyone know what these are? They were only on one side and I haven’t seen them on other hatches with the latches removed. |
#967 |
#968 |
The circle is around what looks like an anti rattle bumper. Mine had foam blocks stuffed inside the lower area where the latch rods are. That looks like it could be a stock piece.
#969 | |
![]() Join Date: May 2011
#970 | |
That’s a great idea for the strut bolts. I don’t have access to a welder but maybe I can have a local guy that does welding do it for me. I’ll make some calls. |
#971 |
Second day of stay home order, I got my new cluster wired up and installed. Still have to install the huge oil pressure sensor, which I am not looking forward to. But other then that, everything is hooked up.
#972 |
Had the wife and daughter sew up a makeshift seat cover so we can ride and enjoy as I wait for my ordered seat cover to come and finish getting restored.
#973 |
Hi, Changing rear end fluid Today. Then this weekend going to start undercoating the entire frame. Probably going to take awhile.
#974 |
Cleaning and painting/dyeing the Ochre K5s Parchment interior pieces.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 04-02-2020 at 06:29 PM. |
#975 |
Trim clean polish and paint.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
