04-10-2020, 04:17 PM | #1 |
Re: **cooling system issue**
UPDATE**
So I got the truck running again and starts right away. FINALLY Now... it still smokes like a freight train. I'm hoping maybe it's just burning off oil and everything from when the engine blew but I have a feeling something else has happened. Stupid question but I'm asking anyway.... the intake manifold gasket has a small leak around the 2 and 3 piston. Would this cause the smoking? I don't think I tightened down the manifold bolts enough because I was afraid of doing too much to start. Going to run a compression test on the pistons this weekend and try to fix the manifold in hopes this is the cause and not something worse. |
04-10-2020, 04:51 PM | #2 |
A leak between the intake manifold and cylinder head will definitely cause heavy smoke. Oil is sucked into the combustion chambers.
04-10-2020, 05:10 PM | #3 |
Tags |
cooling, overheating, pressure |
