Old 04-14-2020, 06:44 PM   #126
88Stanger
88Stanger's Avatar
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
Originally Posted by SCOTI View Post
Oh yeah, you definitely want to be able to adjust/isolate each corner independently.
Since you have lowering blocks, OE style T/A's & larger diameter wheels, you can always do a taller block if you need more psi in the bag for ride quality. The taller block adds more drop so you add more air psi to get things back to where you were w/a shorter block.
It's not recommended on smaller diameter wheels because of Scrub-Line concerns but you should be ok since you're not using 15's/stock steel wheels.
Good info. Thanks again.
88Stanger is offline   Reply With Quote
Old 04-17-2020, 09:02 AM   #127
88Stanger
88Stanger's Avatar
So, this weekend i will have more updates.
After some great help and suggestions on this site, Scoti and CaptainFab, i have a long and bent pan hard bar coming, a new rack and pinion system, rubber snubs for axle, new rear shocks, battery, wires, and a few other minor pieces. I would love to have the frame mobile this weekend, God Willing.
Old 04-17-2020, 10:10 PM   #128
0ldSoul
0ldSoul's Avatar
Awesome. Looking forward to seeing what you think of that no frame modification rack and pinion setup, sounds intriguing..
My '63 Restomod Build
283/4 speed, 4.5/7 static c-notched drop, disc brakes, power steering
Instagram: in2engines
0ldSoul is offline   Reply With Quote
Old 04-18-2020, 02:20 AM   #129
SCOTI
SCOTI's Avatar
Interesting read.....
http://67-72chevytrucks.com/vboard/s...d.php?t=804452
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-18-2020, 09:16 AM   #130
Corts60
Just here to tinker
Corts60's Avatar
Excellent work! Very nice detail on everything. Just read through your thread; can't wait to see it all come together!
Old 04-25-2020, 03:23 PM   #131
88Stanger
88Stanger's Avatar
Thank you sir, i appreciate it. Hopefully i can help someone with what i am doing.
Old 04-25-2020, 03:28 PM   #132
88Stanger
88Stanger's Avatar
So, you were interested in how it went? Well it went as smooth as i could have asked for! I was amazed! 4 large bots and tada.... its in and done.
Now honestly, it took me about an hour to just get it installed, figuring out what holes to use for the mount. Basically, i was trying to make it alot harder than it was. LOL I Laughed at myself once i figured it out.
So, here are multiple pics of the install....
Old 04-25-2020, 03:29 PM   #133
88Stanger
88Stanger's Avatar
a few more bolt in power rack
Old 04-25-2020, 03:31 PM   #134
88Stanger
88Stanger's Avatar
a few more
Old 04-25-2020, 03:31 PM   #135
88Stanger
88Stanger's Avatar
last couple
Old 04-25-2020, 03:34 PM   #136
88Stanger
88Stanger's Avatar
The Rack and Pinion is a powered Rack that is truly bolt in. I got it from POL (Performance Online) and here is part number and link:
https://www.performanceonline.com/19...nd-Pinion-Kit/
Cost is just around $900.00 without hose kit.
Old 04-25-2020, 05:44 PM   #137
SCOTI
SCOTI's Avatar
Looks like a simple/clean install.
What rack model is utilized? Tie-rod ends?
Those are wearables that you need to know the ID for when you perform future service replacement work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-25-2020, 11:02 PM   #138
88Stanger
88Stanger's Avatar
great point, ill ask
Old 04-28-2020, 04:11 PM   #139
88Stanger
88Stanger's Avatar
ok, so i emailed POL on the rack and the parts associted and ask if i ever need to replace parts, what do i use, here i response:
Thanks for your interest in our products. It will be hard to replace direct as the inner tie rod ends are machined special.
Rack is from a mid 90's Dodge Dakota. Outer tie rod ends are for the 1963-70 Chevy c10
Old 04-28-2020, 04:30 PM   #140
SCOTI
SCOTI's Avatar
I would ask for clarification on this info (after you provide your purchase info so they don't think you're trying to scam them). Point being, this is a non-stock part that you're building your steering set-up around. Should POL go out of business somehow/someway, you need a Plan-B if yours wears or becomes compromised.
Just glancing, it looks like maybe they're using adapters as the sleeve between the inner/out TRE. Maybe that's what he was referring to & what you'd want to clarify.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-28-2020, 04:33 PM   #141
0ldSoul
0ldSoul's Avatar
Yeah that looks so good! Coming together very nicely!!
Old 04-28-2020, 05:02 PM   #142
SCOTI
SCOTI's Avatar
Quick look-up shows the inner as part of the R&P ('96 2wd model). Moog does show a replacement for inner & outer but the inners are a different deal vs. just swapping inner/outer TRE's on the original style steering.
My bet is they are just using a machined sleeve/adapter of the correct size/thread pitch that the correct C10 spindle outer TRE will thread into. Either modifying the inners length or accommodating the dimension into the adapter sleeve.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-30-2020, 03:58 AM   #143
Paul Y
Hi Jeff,
Good to see the chassis member in place and looks good powder coated in red.
Tried to respond to your DM but your mail box is full.
Want to arrange a good time to call.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 04-30-2020, 10:09 PM   #144
Captainfab
60-66 Nut
I think you are correct. IMO that aluminum sleeve looks a little thin where the outer TRE screws in. Plus I would think there would be a jamb nut there.
Old 04-30-2020, 10:24 PM   #145
SCOTI
SCOTI's Avatar
Yes. Adapters get a jam nut to keep the TRE's from moving/loosening once assembled & aligned.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-04-2020, 08:31 PM   #146
88Stanger
88Stanger's Avatar
Originally Posted by Paul Y View Post
Hi Jeff,
P.
should be good now. Sorry about that
Old 05-07-2020, 02:17 PM   #147
67C10GS
67C10GS's Avatar
loving this build, you're doing most of what i want to do to mine so i cant wait to see it done.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10”
67C10GS is offline   Reply With Quote
Old 05-09-2020, 04:09 PM   #148
88Stanger
88Stanger's Avatar
Well Thank you. If you have any questions please let me know.
Old 05-09-2020, 04:12 PM   #149
88Stanger
88Stanger's Avatar
ok, installed the front disc brake kit, all part of CPP lower kit. Also, trying to snug fit the air lines for the air bags.
Old 05-09-2020, 04:15 PM   #150
88Stanger
88Stanger's Avatar
New Rear Disc Brake kit from Master Brakes, great company, great stuff, perfect fit and good customer support
First couple pics of mounts, you will notice i have the the Driver side on pass and Pass on Driver... lol they were swapped.
Aslo, caliper are painted red of course
