04-14-2020, 06:44 PM | #126 | |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
04-17-2020, 09:02 AM | #127 |
So, this weekend i will have more updates.
After some great help and suggestions on this site, Scoti and CaptainFab, i have a long and bent pan hard bar coming, a new rack and pinion system, rubber snubs for axle, new rear shocks, battery, wires, and a few other minor pieces. I would love to have the frame mobile this weekend, God Willing. |
04-17-2020, 10:10 PM | #128 |
Awesome. Looking forward to seeing what you think of that no frame modification rack and pinion setup, sounds intriguing..
My '63 Restomod Build 283/4 speed, 4.5/7 static c-notched drop, disc brakes, power steering Instagram: in2engines |
04-18-2020, 02:20 AM | #129 |
04-18-2020, 09:16 AM | #130 |
Just here to tinker
Excellent work! Very nice detail on everything. Just read through your thread; can't wait to see it all come together!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-25-2020, 03:23 PM | #131 |
04-25-2020, 03:28 PM | #132 | |
Now honestly, it took me about an hour to just get it installed, figuring out what holes to use for the mount. Basically, i was trying to make it alot harder than it was. LOL I Laughed at myself once i figured it out. So, here are multiple pics of the install.... |
04-25-2020, 03:29 PM | #133 |
a few more bolt in power rack
04-25-2020, 03:31 PM | #134 |
a few more
04-25-2020, 03:31 PM | #135 |
last couple
04-25-2020, 03:34 PM | #136 |
The Rack and Pinion is a powered Rack that is truly bolt in. I got it from POL (Performance Online) and here is part number and link:
https://www.performanceonline.com/19...nd-Pinion-Kit/ Cost is just around $900.00 without hose kit. |
04-25-2020, 05:44 PM | #137 |
Looks like a simple/clean install.
What rack model is utilized? Tie-rod ends? Those are wearables that you need to know the ID for when you perform future service replacement work.
04-25-2020, 11:02 PM | #138 |
04-28-2020, 04:11 PM | #139 |
ok, so i emailed POL on the rack and the parts associted and ask if i ever need to replace parts, what do i use, here i response:
Thanks for your interest in our products. It will be hard to replace direct as the inner tie rod ends are machined special. Rack is from a mid 90's Dodge Dakota. Outer tie rod ends are for the 1963-70 Chevy c10 |
04-28-2020, 04:30 PM | #140 | |
Just glancing, it looks like maybe they're using adapters as the sleeve between the inner/out TRE. Maybe that's what he was referring to & what you'd want to clarify.
04-28-2020, 04:33 PM | #141 |
Yeah that looks so good! Coming together very nicely!!
04-28-2020, 05:02 PM | #142 | |
My bet is they are just using a machined sleeve/adapter of the correct size/thread pitch that the correct C10 spindle outer TRE will thread into. Either modifying the inners length or accommodating the dimension into the adapter sleeve.
04-30-2020, 03:58 AM | #143 |
Hi Jeff,
Good to see the chassis member in place and looks good powder coated in red. Tried to respond to your DM but your mail box is full. Want to arrange a good time to call. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
04-30-2020, 10:09 PM | #144 | |
60-66 Nut
I think you are correct. IMO that aluminum sleeve looks a little thin where the outer TRE screws in. Plus I would think there would be a jamb nut there.
04-30-2020, 10:24 PM | #145 |
Yes. Adapters get a jam nut to keep the TRE's from moving/loosening once assembled & aligned.
05-04-2020, 08:31 PM | #146 |
05-07-2020, 02:17 PM | #147 |
loving this build, you're doing most of what i want to do to mine so i cant wait to see it done.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
05-09-2020, 04:09 PM | #148 |
05-09-2020, 04:12 PM | #149 |
ok, installed the front disc brake kit, all part of CPP lower kit. Also, trying to snug fit the air lines for the air bags.
05-09-2020, 04:15 PM | #150 |
New Rear Disc Brake kit from Master Brakes, great company, great stuff, perfect fit and good customer support
First couple pics of mounts, you will notice i have the the Driver side on pass and Pass on Driver... lol they were swapped. Aslo, caliper are painted red of course |
