Old 06-07-2019, 02:22 AM   #251
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Show off your Wheels
Ridlers
sneakysnake is offline   Reply With Quote
Old 06-08-2019, 12:29 PM   #252
58 pache
Sweet ride sneakysnake.
58 pache is offline   Reply With Quote
Old 06-09-2019, 04:41 PM   #253
bowt1ed
Originally Posted by sneakysnake View Post
Ridlers
Hey SS, what size are those? Backspace on rear?
Cheers. Jim
bowt1ed is offline   Reply With Quote
Old 04-22-2020, 06:54 PM   #254
bosco
bosco's Avatar
Chrome smoothies 16x8 with 235/60 16 tires all around.
bosco is offline   Reply With Quote
Old 05-02-2020, 05:49 PM   #255
MiraclePieCo
MiraclePieCo's Avatar
With trim rings and without trim rings:
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 05-02-2020, 09:19 PM   #256
3757chevy
3757chevy's Avatar
I kinda like it without . How about you?
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-03-2020, 09:42 PM   #257
MiraclePieCo
Thanks, I left them off. It looks more utilitarian, like a panel truck should.
Old 05-03-2020, 10:33 PM   #258
3757chevy
3757chevy's Avatar
I went from rally wheels in full trim to rally wheels with no rings to steelies with stock 72 caps on my '67 just in the last year.
MIKE
Old 05-03-2020, 10:39 PM   #259
3757chevy
3757chevy's Avatar
Here's a recent pic . I know it's not a 47-59 b b but I couldn't help myself.
MIKE
Old 05-04-2020, 10:36 PM   #260
Axememan
15x8 chrome rally’s 235/75-15 all around
Axememan is offline   Reply With Quote
Old 05-04-2020, 11:11 PM   #261
MALIBLOC
MALIBLOC's Avatar
18x8 and 18x9.5
MALIBLOC is offline   Reply With Quote
Old 05-05-2020, 01:59 PM   #262
nikwho
nikwho's Avatar
Lotta good lookin trucks and wheels in this thread! Here's mine, with a few tire/wheels combos I have had. This truck has a '79 Camaro front clip, done the "No Limit way". It has the 10 bolt rear axle out of the same '79 Camaro
First picture: 18" Foose Legend wheels, 18"x7" in front (4" BS) with 225/40-18 tires. 18"x9" rear (5.25" BS) 275/40-18 BFG G-Force Sport Comp-2 tires. If you corner hard, there's no way that these would fit in stock tub opening. They'd be too close on inside and outside. With my '79 Camaro 10 bolt axle, I have good clearance to fender lip, but rubbed on bedside on both sides.
Second picture: 17" Boyd Coddington Junkyard Dogs, 17"x8" front and rear, 4.5" BS. 225/45-17" up front, and 255/45-17 Cooper tires. These fit, but rubbed while cornering hard. I found that out when I saw burnt paint on the inside of the bed sides. 1/4" spacers would have resolved this.
Third picture:
15" Cragar Chrome Smoothies. 15"x6" up front, with 3.5" back spacing. 15"x8" in rear, with 4.25" BS. BFG Radial T/A's 205/60-15 in front and 245/60-15's in rear. I bought a set of 275/60-15 tires, but would have needed a 1/4" spacer to make them fit without rubbing. This front wheel/tire combination is the only one that I have had that has not rubbed at all.
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 05-10-2020, 02:36 AM   #263
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by MALIBLOC View Post
18x8 and 18x9.5
Curious if your wheels rub and would like to know the backspacing BUT... I guess that wouldn't tell me anything unless I knew what rearend it has and the width of it along with what front suspension it has.
Looks nice though. I really considered those for mine.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-10-2020, 11:47 AM   #264
MALIBLOC
MALIBLOC's Avatar
here a thread I did awhile back a 275 tire would rub IMO. I have a uncut gm10bolt , just research things and measure .
truck gets tons of compliments on the wheels the lip and offset look great.
http://67-72chevytrucks.com/vboard/s...d.php?t=796833
Im located in tustin not far from you in you ever wanted to swing by and bolt them on
Old 05-10-2020, 04:02 PM   #265
DeuceTudor
My 51 GMC, Wheel Vintiques 6x16 front, 8x16 rear , powder coated in red with stainless steel trim rings and smooth baby hub caps,Name:  DSC_0197.jpg
DeuceTudor is offline   Reply With Quote
Old 05-10-2020, 09:26 PM   #266
edgeleycanuck
Originally Posted by DeuceTudor View Post
My 51 GMC, Wheel Vintiques 6x16 front, 8x16 rear , powder coated in red with stainless steel trim rings and smooth baby hub caps,Attachment 2013745
Hey 16 inch wheels! I keep thinking that is the size I would like as well but I have heard that some 16 inch rubber may not be easily obtainable? Anyone have thoughts on that? Thanks for the effort posting your pictures!
edgeleycanuck is offline   Reply With Quote
Old 05-10-2020, 09:59 PM   #267
roger55
roger55's Avatar
What you heard is inaccurate. There are many, many choices of tires in 16".
It's 15" that have limited choices.
roger55 is offline   Reply With Quote
Old 05-11-2020, 02:32 AM   #268
DeuceTudor
A lot of suv/ 4x4 run 16 inch wheels, I just spent a little time researching
to get the tyre size/ratio that I wanted,
Old 05-23-2021, 05:36 PM   #269
Johns327
Johns327's Avatar
I saw this truck at a show recently, had Keystones on it. Fifteen inch front and back, not sure of the rim width. Can’t say I’ve seen many Keystones on truck, but it looks good.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
Old 05-24-2021, 01:45 PM   #270
bosco
bosco's Avatar
Changed from my chrome smoothies (posted back in 2019) to these spoke style. Went from a 16x8 to 17x8 (235/55 17 tires).
Old 05-24-2021, 06:27 PM   #271
osaltyone
osaltyone's Avatar
Detroit Steel 20x8
osaltyone is offline   Reply With Quote
Old 05-24-2021, 10:06 PM   #272
Dan in Pasadena
I haven't come back to this thread in months (obviously). A very generous offer, thanks so much.
I bought some 17x7 & 17x9 smoothies I will be painting and using with '51-'52 car caps and narrow ribbed beauty rings. I need to test mount the to see how they fit first.
Old 05-25-2021, 01:01 AM   #273
layinrocker65
layinrocker65's Avatar
American Racing wheels
20x8 245/45-20
20x9.5 275/40-20
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 05-25-2021, 01:27 AM   #274
NorCalGal
NorCalGal's Avatar
20x8 245/45-20
20x9.5 275/40-20
That’s one nice looking truck there layinrocker65. Looks like you’re keeping us in the dark, we need more info on this build.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 05-25-2021, 01:32 AM   #275
NorCalGal
NorCalGal's Avatar
Oh, DUH! I see you do have a build thread...just have to open my peepers.
Jan's 53
