01-21-2020, 05:07 AM | #101 |
Re: the panelburb getting cut up
Grille hoops still available?
01-21-2020, 11:24 AM | #102 |
Equal opportunity joke ofender
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
03-12-2020, 07:40 PM | #103 |
Do you have Rh and Lh of the full cut from Front angle to bolt hole where the b-pillar locates?
03-12-2020, 07:57 PM | #104 | |
I will take a look tomorrow and let you know what i do have
03-13-2020, 03:25 PM | #105 |
Dwayne
Nothing left in that area. If I end up cutting up one of the others I will contact you. will send pm on the other stuff
03-13-2020, 05:30 PM | #106 |
Got the PM Richard
Thanks for looking. .
04-02-2020, 09:23 PM | #107 |
Are the bottom latches for the barn doors available?
Price on grille?
JIM PARKER GLENBURN, MAINE 69 BURB 4WD - 307/4SPD/YELLOW 69 BLAZER (ORANGE / 35" SUPER SWAMPERS) 1970 CUSTOM-10 |
04-03-2020, 07:56 AM | #108 |
Let me take a look, I think i still have a set left. The grill I will have to look at as well. I seem to remember it being rusty and I know the trim is gone off of it.
05-10-2020, 11:31 PM | #109 |
Active Member
I need one of the core support mounts thats riveted to the front of the frame
please pm me with price and PayPal address if you can help. thanks |
05-11-2020, 07:20 AM | #110 |
I do have some. Do you need 67-68 or 69-72? they are different
05-11-2020, 09:59 AM | #111 |
How much for the engine stands and power steering pump to Elberton ga 30635
05-11-2020, 05:38 PM | #112 |
let me get the pump pulled off and see if it will all fit in a large flat rate. You did see that there is no engine mount with the pump and the stands are big block, correct?
05-11-2020, 08:43 PM | #113 |
I Did, does the pulley have a part number on it?
05-12-2020, 02:34 PM | #114 |
Hey Richard - I am looking for both sides, tail light housings and around the side. Any good, straight, rust free ones?
05-12-2020, 02:46 PM | #115 | |
05-12-2020, 02:50 PM | #116 |
05-12-2020, 02:51 PM | #117 |
ok will pull them both out shortly and post pics.
05-12-2020, 03:08 PM | #118 |
Both of them have dents in the outer sheet metal but zero rust. I circled the dents with white pencil to make it easier to see. I also drew a line where I think you wanted them cut? The one has some rot out on the inner pillar section that is still attached to it but should not affect what you are needing. Let me know if you think they will work for what you want. If so PM me your address so I can get a full total of what they would run ya
Richard
05-12-2020, 03:08 PM | #119 |
couple more pics
05-12-2020, 04:13 PM | #120 |
05-19-2020, 10:37 PM | #121 |
Active Member
Did anyone take the 3rd door, do you have any of the 3rd hinges , I also read were you might be cutting another one up, id like to purchase a b piller for 3rd door
05-20-2020, 07:22 AM | #122 |
I do still have the door but the hinges are already gone. No B pillars at this time either, sorry
05-20-2020, 09:12 AM | #123 |
Do you still have the side marker lights?
05-20-2020, 05:48 PM | #124 |
3 of the 4 are still on the burb. Not sure where the 4th one got to but I can look around to see if I can find it. Honestly they are not in Very good shape. Will post a few pics later
05-21-2020, 06:48 AM | #125 |
here are pics of the mounts
