Old 05-20-2020, 10:11 AM   #1
bcoke
K30 / K5 Frankenstein: braking problem
My braking is super touchy right now because the back drums are braking way before the front discs. Turns out I have a master cylinder, proportioning valve, and front lines for a K5, but the axles have been swapped out (owner before me) to 1 tons, which I’m guessing are from a K30.
So looks like I need to go find an MC, prop valve, and line dimensions off a K30 to match the bigger axels, right? Anyone have any advice? Or done this before and been through challenges they can share?
Any help is appreciated!
bcoke is offline   Reply With Quote
Old 05-20-2020, 10:24 AM   #2
AZBuckHunter
AZBuckHunter's Avatar
Re: K30 / K5 Frankenstein: braking problem
You may just have a bad prop valve or air in the system. When I put tons on my K5 I didn't have to do anything but it was built into a crawler and not driven on the road much. An adjustable prop valve would probably be what I would do if I was going to be driving on the street.
AZBuckHunter is offline   Reply With Quote
Old 05-20-2020, 10:36 AM   #3
bcoke
Yeah that’s what this one is built into (457s in the front and rear and fully rhino lined haha). Great on the trail but hell on the street, and I’ve been trying to make it more of a driver lately.
That’s a good idea, I can start there and keep doing trial and error. Any in particular that you’d recommend?
Old 05-20-2020, 10:49 AM   #4
AZBuckHunter
I would get the best you can afford.
You got a pic of your rig on here?
Old 05-20-2020, 12:04 PM   #5
geezer#99
geezer#99's Avatar
You could plumb one of these into the rear line. Put it close to the master.
https://www.summitracing.com/parts/w...hoCyywQAvD_BwE
geezer#99 is online now   Reply With Quote
Old 05-20-2020, 12:11 PM   #6
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Could always run hyrdroboost.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-20-2020, 01:28 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
I agree. That and the hydraulic clutch are the two best things I’ve done to my K20. It’s really not hard to do.
Tyler
Old 05-20-2020, 04:33 PM   #8
WyoRoadDog
Page intentionally left blank.
WyoRoadDog's Avatar
My guess, and only because I’ve been researching as part of a swap I did, is you have the wrong proportioning valve ( and maybe MC). Was it originally a four wheel drum vehicle? Disc drum needs a different PV from that, and MC should have a front chamber (disc) that’s larger than the rear (drum).
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams
'67 GMC 4x4, 305 V6! Or all the parts for anyway...
'17 Subaru Outback.
'18 Toyota Tacoma TRD Off Road.
'99 Ducati 900SS.
WyoRoadDog is offline   Reply With Quote
blazer, brake conversion problem, brake fluid capacity, brake help, k30
