Old 06-07-2020, 07:18 PM   #201
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Old Girl (aka Project Underhaulin)
Video of the first start up...
First Start Up - YouTube
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 06-07-2020, 07:54 PM   #202
C10_ustacould
Video of a drive after the tune was done.
Tune Complete! - YouTube
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-07-2020, 08:19 PM   #203
C10_ustacould
We upgraded to Dakota Digital gauges and took advantage of the ability to run them directly off the OBS II port.
Couple shots of the engine compartment ...
One of the issues we had was push rod length. You'd think the experts would know what their parts need but it took 3 sets to get it right. This is Connor swapping in the final set.
We also swapped the power brake master/booster for a manual master cylinder.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-07-2020, 08:22 PM   #204
C10_ustacould
Here are a couple shots of the exhaust, 3 inch mandrel bends throughout and 3" Magna Flow mufflers. The QA1 track bar setup makes it really tight after the axle so we decided to turn them down in front of the axle until we figure something better.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-07-2020, 10:31 PM   #205
C10_ustacould
Just a pic I took for Instagram
Connor installing a weather pack connector on the Vintage Air trinary switch.
Next upgrade... 9 inch reared with a 3.00 gear will work much better with the gearing of the 8 speed automatic.
Changing from a 20x8.5 squared to 20x8.5 front and 20x10 rear to get a little more meat in the rear. Going to have to put a little tub in the step side bed to make it work but it'll be worth the work.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-07-2020, 10:38 PM   #206
C10_ustacould
Couple of shots of the trucks filling up before going to a local meet.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-07-2020, 10:43 PM   #207
DPowers
One foot in front of the other
DPowers's Avatar
Nice. Has been a long road.
DPowers is offline   Reply With Quote
Old 06-08-2020, 07:12 AM   #208
Very nice ride!
Old 06-08-2020, 09:08 AM   #209
cornerstone
cornerstone's Avatar
You fellas have done quite a nice job in your parts selection. The whole package looks like it could have been born that way. Seeing the rear cross member from Porterbuilt explains a lot. I bought one from CPP but it is going to need surgery to be able to work.
I’m doing a Gen V swap with an L83 ( the 6.2’s little brother) and a 6 speed automatic. I’m curious of your power output, did Texas Speed give you an idea of what the mods would produce?
I hope it gives you years of miles and smiles!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-08-2020, 10:43 AM   #210
aggie91
I'm just glad to be here!
aggie91's Avatar
Great upgrades! Nice work!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-09-2020, 10:35 AM   #211
smbrouss70
smbrouss70's Avatar
It all looks good guys!
Ernie, where did you source the cable clamps for the parking brake cables in the picture? The brass piece with the set screws. I'm having trouble finding some that will fit in the connector.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-10-2020, 10:26 AM   #212
SCOTI
SCOTI's Avatar
Nice updates!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-10-2020, 03:51 PM   #213
Custom 68
Custom 68's Avatar
looks amazing. I have the stock 6.2 in my newer GMC Sierra and man does it run nice. I am sure it is a blast in that truck. These new gen 5 motors are a couple steps above the previous ones.
You all have done a great job on this one.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-13-2020, 05:28 PM   #214
C10_ustacould
I think they came in the cable kit from Wilwood, I'll have to check. I think we cut these down to fit.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-16-2020, 12:58 PM   #215
siggyfreud
siggyfreud's Avatar
Looks awesome! I am very jealous of what's in the engine bay.
siggyfreud is offline   Reply With Quote
Old 06-16-2020, 01:05 PM   #216
siggyfreud
siggyfreud's Avatar
Hey I'm curious about your steering setup, specifically what u-joint, shaft, etc. you're using. I'm swapping over to a redhead steering box, and the connection between my Ididit column and the box looks hacked together by the previous owner, and I'd like to do it better. Any suggestions?
Old 06-19-2020, 01:08 AM   #217
C10_ustacould
Our stuff is all stock. We may be able to help if we could what you have, do you have a build thread on here?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-19-2020, 12:08 PM   #218
siggyfreud
siggyfreud's Avatar
I do, it's my "current build" in my signature. That said, I think I figured it out. I'm going from the Redhead box into a 13/16x36 ujoint, into a 1" DD collapsible tube, that turns into a 3/4"DD on the other end, into a 3/4"DDx1"DD coupler that will mount onto the Ididit steering column.
I found some videos about the right way to mount to the ididit column. They say not to put the 3/4"DD INTO the column, and that's exactly what the PO did. Instead, they say use a coupler that mounts over the column output, which is what I'll do next.
I appreciate the willingness to help. Your build inspired me to ensure my steering setup was better.
Old 06-20-2020, 07:04 PM   #219
C10_ustacould
I'm glad to hear you have it figured out!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-22-2020, 12:05 AM   #220
C10_ustacould
The latest mod is the 9 inch swap. We got it all mocked up this week end to check fit. I probably could have gone an inch shorter over all but I'm sure we'll be fine, may have to trim or roll the fender lip a bit. Next is powder coat and final reassembly. The 3.00 gear should really improve the drivability and turn it into a freeway flyer!
12 Bolt out!
Quick Performance 9 inch, Yukon Nodular Case, Eaton Detroit Truetrac, 3.00 gear, and billet 1350 yoke
9 inch in place
Another angle
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-22-2020, 12:13 AM   #221
C10_ustacould
Tubs have been dissected and tacked together, and the bedsides have been cut out.
One of the tubs mocked and sitting in place
Another angle of the tub after being tacked
Crappy pic but those are 305/35-20 on a step side
Tore it all apart and the housing is ready to go out for powder
9 inch punkin' just because
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-22-2020, 12:25 AM   #222
cornerstone
Those fat meats look amazing on there! How much narrower is the new 9 inch?
Brian
Old 06-22-2020, 01:29 AM   #223
smbrouss70
smbrouss70's Avatar
I can't wait to see it in person!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-22-2020, 07:20 AM   #224
Old 06-22-2020, 07:27 AM   #225
Happy_dan
Happy_dan's Avatar
Awesome job on this truck. Beautiful
Happy_dan is offline   Reply With Quote
